Autonomous RC Car
Published
Introduction: Autonomous RC Car
With the rise of self-driving, autonomous cars today, I decided to take on the challenge of making one of my own. This project also served as my capstone project in my Engineering Design and Development and Robotics classes and received an award for best autonomous vehicle at a high school STEM competition.
Instead of starting from scratch, I opted to use an RC car that we already had and paired it with a RedBoard Arduino Uno board. I chose the Arduino due to its relative ease of use and programming.
For those wondering, this car has a Redcat Racing 03061 Splash-Resistant ESC with a brushed motor. The ESC was already programmed using the controller that came with the car. I have not tested this with a brushless motor since we do not have one on hand, but anyone is welcome to try this project with a brushless motor.
In brief summary, this car collects data from (5) HC-SR04 Ultrasonic sensors. This data goes back to the Arduino, where it makes decisions on how to move. The Arduino then controls the steering servo and motor accordingly. The program uses the standard Arduino servo library to do so, and no additional libraries are necessary.
The car is capable of variable speed control via a potentiometer and backing up from a wall when it hits one. In addition, the car can correct itself if it drifts too close to a wall by easing itself away.
Step 1: Parts List
Disclaimer: I am not including the parts needed for the car itself, only the additional parts beyond the car. An ESC, motor, chassis, battery, etc. will all be necessary for this.
You will need:
(1) Arduino Uno - knockoffs will work just fine
(1) Breadboard - for this project, I took the +/- rail from one breadboard and used another, smaller breadboard. Any size will do.
(5) HC-SR04 Ultrasonic Sensors
(1) Potentiometer - used to control the speed of the car
(20) Female-Male Dupont wires - I highly recommend having more to use as extenders for other wires if needed
Soldering Iron with solder
Arduino Power Supply - in this case, I used (6) 1.2v AA batteries wired in series. External phone and tablet power banks like this one will also work well when plugged into the USB port.
Tape, hot glue, and/or any other items used to fasten items together
(1) Toggle Switch (optional -- I use it to turn the Arduino on and off)
Step 2: Position the Sensors
First, you will want to correctly position and fasten the sensors. I have (1) sensor facing forward, (2) sensors angled about 45 degrees, and (2) sensors on the sides of the car. I 3D printed mounting brackets for the sides and front, and used hot glue to fasten the angled front sensors since hot glue is non-conductive. The mounting brackets for the sides and front can be downloaded and 3D printed.
Step 3: Add the Breadboard and Potentiometer
Next, you'll want to add in the breadboard and speed-controlling potentiometer before you begin wiring. This is where I used a small breadboard and the +/- from another breadboard due to space on the car's body, but a standard breadboard will also do just fine.
Step 4: Wire Everything
This one is probably the biggest step, and one wrong wire can cause the car to not function properly. Refer to the Fritzing diagram above for extra guidance.
Start by connecting the 5v pin of your Arduino to the positive rail on the breadboard and the GND pin of your Arduino to the negative rail of the breadboard.
Next, wire up the sonar sensors. The HC-SR04 sensors have each of their four pins labeled. They are:
VCC -- 5v power
Trig -- trigger to send an ultrasonic pulse out
Echo -- receiving pin that measures the duration of the pulse
GND - ground pin
Use female-male Dupont wires for this. Each of the VCC pins should be connected to the positive breadboard rail, and each of the GND pins should be connected to the negative breadboard rail. I used extra female-male Dupont wires as extenders for this part since I had an issue with some of the wires not being long enough.
Next, wire the Trig and Echo pins into the Arduino. These will be connected to the digital pins of the Arduino as such:
Front Center Sensor:
Trig -- pin 6
Echo -- pin 7
Left Side Sensor:
Trig -- 4
Echo -- 5
Right Side Sensor:
Trig -- 2
Echo -- 3
Front Left Sensor:
Trig -- 10
Echo -- 11
Front Right Sensor:
Trig -- 9
Echo -- 8
Next, wire the steering servo, motor ESC, and speed control potentiometer.
First, start with the steering servo. The servo on my car had red, orange, and brown wires. The colors may vary a little bit, but they will all be wired similarly:
Brown wire (ground) -- connect to negative breadboard rail
Red wire (5v power) -- connect to 5v breadboard rail
Orange wire (signal) -- connect to pin 13 on your Arduino
The ESC -- or Electronic Speed Controller -- that controls the motor is wired very similarly. In this case, the wires are white, red, and black.
White (signal) -- Connect to pin 12 on your Arduino
Red (5v) -- do NOT connect to anything. Due to a surge of electricity that flows backward when the motor stops, the 5v should not be connected. You could fry a USB port or, possibly, your Arduino.
Black (ground) -- connect to negative breadboard rail
Finally, wire the potentiometer that you put on your breadboard earlier. Small numbers are likely printed on it somewhere. It should be wired as:
1 (left pin) -- connect to negative breadboard rail
2 (middle pin) -- connect to pin A0 on your Arduino
3 (right pin) -- connect to positive breadboard rail
The wiring will look very messy, so if you want to do some wire management, now would be the time to do it.
Step 5: Powering the Arduino
Next, you will want to set up a power solution for the Arduino. Two separate power sources are used in this project: the battery for the car, and the battery for the Arduino. In this case, I used (6) 1.2v rechargeable AA batteries wired in series. Portable cell phone power banks will also work, just make sure to have a cable that plugs into your Arduino's USB port (such as mini-USB).
Please note that 9v batteries will NOT work with this project. Due to the way that 9v batteries are designed, the voltage is sufficient to run the Arduino, but the current coming out of the battery will cause it to die in no time. I also had issues with random reboots on the 9v battery.
If you choose to use the solution that I used, you will need:
(6) AA batteries (alkaline batteries work fine as well)
AA battery holders for all (6) batteries. This one would work great and doesn't even require you to use a soldering iron. For the supply that I made, I daisy-chained (3) two-battery holders together as pictured, soldered the positive/negative wires together, took the DC power plug from a 9v battery adapter, and soldered it to the end positive and negative wires. I then soldered a power switch in series with the power supply for ease of turning the Arduino on and off. This is completely optional.
Step 6: Upload the Arduino Program
Next, you will need to upload the program to the Arduino. Download the program here, and upload it to your Arduino through the Arduino IDE.
For those of you who might look into modifying the code, I have included some pseudocode explaining what each part does.
Step 7: Plug Everything in and Turn It On
Finally, you will need to plug everything in. First, connect the car battery to the car and turn on your ESC. The ESC should beep, indicating that it is ready to be "armed" by the Arduino. Next, power up the Arduino. The ESC should beep three times, and the wheels should begin turning. If the ESC beeps, but the wheels do not begin turning, turn the potentiometer to the right to increase the speed. If the car is moving too fast, turn the potentiometer to the left.
If the potentiometer works the opposite of the way it should, you can flip the positive and negative wires to solve this.
The video shows the car working, how to change the speed, and the order to turn it on in.
    • Clocks Contest
      Clocks Contest
    • Casting Contest
      Casting Contest
    • Planter Challenge
      Planter Challenge
    Very cool, thanks for sharing!!
