Autonomous Surveillance Camera
 by basil.shikin
Featured
I would like tell you about a DIY surveillance camera I have built. It is quite different from anything out there on the market. It works for up to a month on a single charge and emails surveillance updates over cellular network. All you need to do is send it an email and the camera would reply you with a picture of your home, country house or car.
Here is a video of how it all fits together:
The device checks pre-defined email mailbox once an hour. If a new email is received the camera takes a picture, saves it on a SD-card and emails the image to its owner.
Making of the camera was also an interesting journey I would like to share.
Step 1: Required Parts
I have used following basic components for the device:
MultiTech MTSMC-G2-IP
This GSM modem is great because of its built-in POP3 and SMTP support. Although these protocols are not very complicated to implement having them implemented saves some time.
LinkSpite JPEG Camera
This is a great little device. Built-in JPEG compression support saves a lot of development effort. The camera produces a 640x480 image. The image is around 50K; it is small enough to rapidly transmit over a cellular network.
Sparkfun's microSD Shield
Although there are a few SD card circuits available I decided to go with this one because it is very easy to work with both in software (Sparkfun provides great APIs) and in hardware (again, thanks Sparkfun for built-in voltage conversion).
ATmega 328P
This micro-controller was a natural choice. Arduino Uno uses this chip, so there are plenty of libraries and examples out there. Unfortunately, Arduino Uno itself consumes too much power when it is in a sleep mode, so I had to build a board with more efficient power supply system myself.
TPS2020 and LM2936
TPS2020 is a great power distribution IC. It allowed me turning circuit components on and off as I needed it. LM2936 is an awesome regulator with really low quiescent current. Combination of the two parts allowed my circuit to consume as little as 0.14mA in sleep mode. It stretches battery life for up to a month on a single charge; the camera is powered by 5V from two CR123A batteries.
Light_Lab says: Apr 14, 2012. 5:52 PM
This is a great piece of work and the ability to program it via the arduino makes it very versatile, perhaps more versatile than your final application of home surveillance requires.
It does make me wonder though, you say "....quite different from anything out there on the market..." it would help to see your design's advantages contrasted with a standard IPCam.
crackHacker says: Apr 6, 2012. 7:54 AM
you should paint it gray and put lines on it to make it really look like the deathstar. A+ just because it pretty much does thus far.
Dream Dragon says: Mar 26, 2012. 5:18 AM
I'm not normally a fan of the Arduino System, but this is a really good project that actually does need something like that to make it work. I particularly like the 3D printed project case. That's something I'm going to have to look into. How does it compare to "El Cheapo Project Box" from electronics retailer? No Doubt it's more expensive, but 2 or 3 times as expensive for an infinitely more appropriate and interesting package might be worth the additional expense.
Well Done and many thanks for sharing your project.
brokey says: Jan 4, 2012. 7:37 PM
I love this project, I wish I were this knowledgable and creative!
What changes would have to be made to use an iPhone 4 (or other cellphone) camera? It could theoretically output 5MP+ photos.
How about replacing the cellular radio with a WiFi module?
What would be needed to turn this project into an "HD IP Camera?"
megakacktus says: Jun 12, 2011. 10:08 AM
I want to see one that looks like HAL 9000.
"Open the pod bay doors, Hal."
"I can't do that, Dave."
jadronx in reply to megakacktusDec 24, 2011. 7:59 AM
love it!!!!!!!!!!
hjartland says: Oct 12, 2011. 10:28 PM
This is really cool! I am not at your level of techie, but I can solder w/ the best of them. :)
What would you suggest building for my problem.
I have a workshop in an area with a lot of break-ins.
I'd like to have a camera that would call and send me a photo every time the sensor is tripped. That way I can see the burglars and call the police!
Not just have a blaring alarm that no one will check out.
Great work!
Primeshaw says: Aug 11, 2011. 11:43 AM
This is a great for this project, Google Star Wars Death Star Projector.
pobturtle says: Aug 2, 2011. 4:21 PM
about how much does this cost???
basil.shikin (author) in reply to pobturtleAug 2, 2011. 5:20 PM
About 100$ for cell radio, 100$ for other electric components and 250$ for the body.
Q-ro says: Jun 1, 2011. 9:20 AM
This is amazing, too bad i cannot find any arduino stuff here, i wish i could "build" the parts, maybe then i could do this cam, also, it would be nice if you could integrate a motion sensor so it will email to you when someone pass by.
DrSpider says: May 31, 2011. 12:12 AM
I would think that by its very nature, being a surveillance camera and all, it would be autonomous. Great project and Instructable though. A bit too "techie" for my skills/talents though! Now if only someone could help me figure out where I put that Wild Turkey!!
tresspaser says: May 29, 2011. 2:34 PM
It looks like the Death Star from Star Wars.
photographer_ivan says: May 26, 2011. 7:14 AM
Прикольно :) уже читал про камеру на ХАБРЕ :)
Kasm279 in reply to photographer_ivanMay 26, 2011. 12:37 PM
I don't understand...
basil.shikin (author) in reply to Kasm279May 26, 2011. 9:30 PM
I think it might be a bad encoding of Russian characters. It says something like "Cool. I've already read about this camera on HABR". I believe it reffers to a Russian website where I published translation of the article.
leggomylegoeggo in reply to basil.shikinMay 28, 2011. 3:28 PM
oh, it looked like a random series of emotes to me...
Kasm279 in reply to leggomylegoeggoMay 28, 2011. 4:10 PM
Yeah, I thought it was someone trying to be 1337
DragonDon says: May 26, 2011. 6:56 PM
This is a really cool project. With the components, it can be used in any form really. A nice 'piece of mind' for those truly paranoid but can't afford the more expensive setups.
leggomylegoeggo in reply to DragonDonMay 28, 2011. 3:26 PM
I'm sure a zombie might like a "piece" of mind! Sorry, I just couldn't resist.
basil.shikin (author) in reply to DragonDonMay 26, 2011. 9:39 PM
These were exactly my thoughts when I was building it. You know, sometimes these paranoia moments hit me: "is home ok?", "did I unplug the iron?", etc. Everything is usually fine but pease of mind is priceless.
mastiffman says: May 27, 2011. 11:44 PM
Love it; well done
Lindie says: May 27, 2011. 5:29 AM
I love this! I wish someone Wouk make it for me....hint, hint. Lol
dhjshi says: May 26, 2011. 9:37 PM
All I can say is wow. One of the most well written and lucid 'ibles I've seen on this site. keep up the good work.
airrob says: May 26, 2011. 9:38 AM
I love your project and your willingness to share.
If you are looking for seed money with out giving up any interest in your business check out kickstarter.com. It is a place where people agree to fund a project and give you a jump start in exchange for recognition, a free product once it rolls out ... Great work, makes me proud to be apart of this community.
Take care,
RL
basil.shikin (author) in reply to airrobMay 26, 2011. 9:35 PM
Thank you for the advice. I think turning it into a small business is a very interesting idea. Do not be alarmed if you ever see a Death Star project on kickstarter.
bwoodfield says: May 26, 2011. 6:49 AM
Thats no moon.....
icefloe01 in reply to bwoodfieldMay 26, 2011. 8:07 PM
IT'S A TRAP!!
mdgnys in reply to bwoodfieldMay 26, 2011. 10:07 AM
My thought exactly.
NewYorkRob says: May 22, 2011. 7:25 AM
The device clearly looks like a camera. I would think an intruder would anonymously body-slam that thing onto the floor.
opiesan in reply to NewYorkRobMay 26, 2011. 2:06 PM
Since it looks so much like a DeathStar anyway, why not conceal it in plain site as a DeathStar? Paint it black, adjust the casing so the camera doesn't stick out quite so far, or even make the camera hole where the death ray would be. Add in some appropriately sized Star Wars toys around it and voila! Instant geek fan camouflage....."This isn't the camera you're looking for. Move along"
@apple_fan - Very cool project. When it comes to the GSM access, did you use a pay as you go chip or set up a monthly account?
opiesan in reply to opiesanMay 26, 2011. 2:10 PM
And nevermind about my question on what GSM chip/plan you used. I see you already provided that info in Step 8. Extremely affordable bandwidth.
Zovits says: May 26, 2011. 1:47 PM
It's not hard to see the Apple-influenced style ;)
burnerjack01 says: May 26, 2011. 7:27 AM
Pretty cool. Put some telescopic legs on it and you're pretty close to the robotic killer spider from Johnny Quest. Anyone else remember Johhny,Race and Haji?
Kasm279 in reply to burnerjack01May 26, 2011. 12:36 PM
Best cartoon ever!
tinker234 says: May 21, 2011. 1:33 PM
any one still on i think that the cam is good can you make it autonomous to report
damage or intredurs
basil.shikin (author) in reply to tinker234May 21, 2011. 1:52 PM
I think it is a valid concern. I would try to embed a motion detection sensor in the next iteration of the device. My only worry is false positives: a light breeze might result in a large phone bill...
timsmith0 in reply to basil.shikinMay 26, 2011. 10:56 AM
If you put in a wifi chip could you use wifi network instead of phone network this would save you money and allow quicker sending of images or video (in future models) also you could put a power point on it and power from a wall socket. Obviously the above changes are for permanent placement like home or office etc. Cheers T
Scumm7 says: May 22, 2011. 12:31 PM
Really interesting build Apple_fan! Anyone with a little imagination could conceal this well. Have you considered salvaging a couple solar lights to recharge the cells when in sleep mode?
basil.shikin (author) in reply to Scumm7May 22, 2011. 8:24 PM
Thank you. I was thinking about including solar panels into the design, but I ended up not doing it, as the device would almost never be exposed to direct sunlight. It spends most time in middle of the living room and window shades are closed.
However, I would love to know if there are any really efficient solar panels available!
abraxas1 in reply to basil.shikinMay 26, 2011. 8:34 AM
Great project, and great write-up too.
there are some big advances in energy harvesting these days.
it's possible to switch to a tiny LiPO battery (greener then throwing away button cells) and at least extend life time with indoor ambient solar energy collection.
i'm anxious to test this myself. in reading it seems reasonable, need to see it for myself though.
try this article describing one LTC3588.
http://tinyurl.com/3d8y4pw
of course, your device could easily email you when the battery is low, and other status reports, like how the solar charging is keeping up with the usage rate....
Fun Stuff! well done indeed.
mike
nitai108 says: May 26, 2011. 8:30 AM
Well done!
It would be great if the camera had a motion detector and would send and save pictures every time it detects movement.
macgyverfan says: May 23, 2011. 6:23 PM
looks like an albino death star to me.
Very cool.
very
afrey says: May 23, 2011. 9:15 AM
I can see a great use for this..
From my time living in college dorms, it was always frustrating to walk to the cafeteria and not know how long i'd be waiting in line.
No-one wants to wait, so the times with lines and the length would fluctuate a lot.
With this device you could know how long the line is at a given instant.
rimar2000 says: May 21, 2011. 2:46 PM
This is a BIG PROJECT! Congratulations.
I have two suggestions, but I don't know how difficult is to implement them:
1) I think an hour may be too time at some situations. Maybe the problem are batteries, you must analize it.
2) You should enhance some photos. I reduced Gamma Factor to those of step 6 and could see some details not showed before. If you want them, I will send you by PM.
basil.shikin (author) in reply to rimar2000May 22, 2011. 8:22 PM
Thank you for your suggestions. Primary reason for hour intervals was to try to reduce on power consumption. I understand that this device can not detect robbery in progress, but at least it can calm its owner down if nothing has happened.
I have updated pictures for step 6. I hope they look more contrasty now.
rimar2000 in reply to basil.shikinMay 23, 2011. 3:34 AM
Yes, now they are much better.
tinker234 says: May 21, 2011. 4:35 PM
yah hey what about email it is free
Kiteman says: May 21, 2011. 10:51 AM
That's a great idea, not least because it looks like a Death Star.
(I wonder if a version could be created that takes a short video and emails that? Maybe as the camera pans from left to right?)
basil.shikin (author) in reply to KitemanMay 21, 2011. 11:41 AM
A video would be a great addition to this contraption. However, I am a bit concerned with an increase in power consumption; capturing video, sending larger file, powering motors might effect device's lifetime.
Kiteman in reply to basil.shikinMay 21, 2011. 1:06 PM
Good points.
I guess if you want a wider field of view, you just have more the=an one camera.
ntinumirov says: May 21, 2011. 11:16 AM
у меня нет логина на хабр, но тут я скажу!!
идея идиока от начала до конца!
зачем тебе Энергонезависимость на месяц? у тебя квартира без электричества?
корпус ценой с деловский лаптоп... это ваще запредельно..
basil.shikin (author) in reply to ntinumirovMay 21, 2011. 11:42 AM
C <# 5AOF 30 FC ?> indeed. I think there might be a problem with comment encoding.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
