Autumn Embroidery Wall Hanging
741
24
6
Posted
Introduction: Autumn Embroidery Wall Hanging
Fiber Arts Contest 2017
Second Prize in the
I'm going to show you how to embroider a small wall hanging using just a few easy stitches.
Step 1: Supplies and Tools
You need:
- Embroidery Floss- I got most of these colors in a pack, so they don't have numbers. I just chose a variety of fall colors.
- Wooden Embroidery Hoop
- Fabric- The remnants section of your craft store is a great place to find very cheap fabric for embroidery since you only need small pieces. I used a silver cotton fabric for this project.
- Scissors
-Embroidery Needle
- Felt
Get ready by cutting a piece of fabric a little bigger than your hoop.
Step 2: Making the Tree
Start out by cutting a length of brown thread. I used about 3 arm spans for this. Fold it in half several times until it is about 4 to 5 inches long and twist it lightly. We will be attaching the tree with a modified couch stitch.
Lay the bundle on the fabric where the base of the tree will be.
Prepare your sewing thread by separating the floss. I used three strands for almost all the embroidery on this piece. Tie a knot at the end of the thread and put your needle through as close to the edge as you and slightly behind your bundle of thread that will become the tree. Finish the stitch by putting the need down through the fabric almost in the same spot it came up. It should go around the trunk of the tree as shown.
Step 3: Make the Trunk
Twist the thread a bit and make the second stitch about a centimeter away from the first.
Continue twisting and stitching up the trunk, shaping as you go. When you reach the first place you would like to have a branch, continue to the next step.
Step 4: Branches
Branches are made the same way the trunk was, but instead of twisting the entire bundle of thread, you will need to first separate the threads. I generally just divided them by 2 and continued with the same number on each branch.
Step 5: Ending a Branch
When you reach the end of a branch, make a tight stitch and cut off the excess.
On the back of your work, thread your needle back through your previous stitches. This will help keep the back neat.
Continue until you have all of your branches completed
Step 6: Leaves!
The leaves are very simple. Each leaf was about 5 or 6 stitches. The first two come from the same point and the rest of the stitches come from a point a little higher than the first.
Step 7: Changing Leaf Colors
As mentioned before, I'm using three strands of thread at a time. To change colors, I started with three yellow strands. I did a few leaves like that and then, swapped one of the strands for a light orange. I did a row of leaves like this and then added another orange strand. Check the annotations on the pictures for descriptions of what color combinations I used.
Step 8: Pumpkins
The pumpkins are a very small satin stitch. Since they were going to be less than a centimeter in diameter, I just did this freehand, but you could draw them in first. I also added some tiny leaves.
Step 9: Back Stitch Greenery
I wanted some more plant life in my scene, so I used a back stitch to add in some stalks for plants and a few sprigs of grass.
Step 10: French Knot Plants
Using a lighter green, I added plants around the stems. To tie a french knot, push your needle up through the fabric roughly where you would like the center of the knot to be. Wrap the string around the needle fairly tightly. (I use one wrap for smaller flowers and 2 for larger ones). Put the needle back down near where it came up and continue pulling the wrap part taught as you put the thread through.
Step 11: More Details
Using a Burnt Ochre color, I added some more backstitched plants and some flower petals. Using black thread, I gave each flower a french knot center.
Step 12: Finishing Touches
Using only two strands of the same brown as the tree, I gave the flowers stems, made some stalks for the pumpkins and added in a few horizontal brown lines for the ground.
Step 13: Hiding the Extra Trunk
Remove your embroidery from the hoop. Trim the trunk so that it will be hidden underneath the hoop and replace the hoop.
Step 14: Backing
Use another hoop (or do this first (I forgot)) and trace the inner edge of the larger ring onto felt. I did this using an exacto knife, but you could use a pen or marking pencil. Cut out the circle.
Step 15: Backing Cont.
Trim the fabric around the hoop, leaving about 1/2-1''. Loosely stitch with any color thread all the way around. Pull tight and tie off.
Step 16: Backing Cont.
Using thread that will blend into your felt, whip stitch around the outside.
Step 17: All Done!
You did it! Hang on a wall and enjoy!
  • Paper Contest 2018
    Paper Contest 2018
  • Sew Warm Contest 2018
  • Epilog Challenge 9
    Epilog Challenge 9
6 Comments
Stunning work! Voted :)
This is pretty awesome! You did an amazing job.
This is beautiful and I just LOVE how you did the color change in the leaves! The work you put into it is noticeable with the end result :)
The tree is brilliant, and really good tutorial!
