Availability Indicator
Published
Introduction: Availability Indicator
Since i work at my home office, my wife asked me a way to quickly know if i'm available or not.
So i built a small availability indicator, controlled remotly by Bluetooth.
For this, i used :
  • Teensy v2
  • a HC-05 (Linvor) bluetooth module
  • a servo motor
  • some wires
  • a piece of wood
  • paper, scissor, glue, tape etc...
Step 1: Hardware
It's quite simple, just connect as shown.
I used a Teensy without header pins, so the wires are directly soldered on the board
Step 2: Frame
The servo is blocked by nails, on the top of the wooden piece.
Use the attached pdf file, print it, and glue it on a piece of cardboard, then cut . On the top the board, a hole was digged to allow the servo axis.
Same for the arrow (print, glue, cut), and it was fixed on the servo arm with tape.
Step 3: Software
There is two pieces of code : one for the Teensy, and one for the computer
Teensy
The Teensy code is Arduino compatible. We manage the Bluetooth module with the HardwareSerial library
#include
#define MOTOR_PIN  4
HardwareSerial bt = HardwareSerial();
Servo myservo;
char c;
int pos = 0;
char intBuffer[12];
String intData = "";
int delimiter = (int) '\n';
void setup()
  Serial.begin(9600);
  myservo.attach(MOTOR_PIN);  // attaches the servo on pin 9 to the servo object
  bt.begin(9600);
  bt.println("Start !!");
  myservo.write(130); // Force 'Free' position at startup
void loop()
      while (bt.available() ) {
        delay(3);
        int ch = bt.read();
        if (ch == -1) {
            // Handle error
            Serial.println("No Data");
        else if (ch == delimiter) {
            Serial.println("delimiter -> break");
            break;
        else {
            intData += (char) ch;
      if (intData.length() > 0) {
        // Copy read data into a char array for use by atoi
        // Include room for the null terminator
        int intLength = intData.length() + 1;
        intData.toCharArray(intBuffer, intLength);
        // Reinitialize intData for use next time around the loop
        intData = "";
        // Convert ASCII-encoded integer to an int
        int pos = atoi(intBuffer);
        if(( pos > 0 ) && (pos <= 200 ) ) {
           //Serial.print ("go to pos : ");
           //Serial.println(int(pos) );
           myservo.write(pos);
           pos = 200;
Desktop
I've built a small app in Python / Gtk, using the bluetooth librairy. It's rn under Linux box.
I sent the servo position manually from the python code. Mine was 130 for 'Free' position, 70 for 'Work', and '25' for 'Phone'. You can calibrate it using a serial app (like cutecom).
You must insert your Bluetooth module MAC adress. You can obtain it with hcitool command
user@laptop:~ > hcitool scan
Scanning ...
        00:xx:xx:xx:12:80       HC-05
user@laptop:~ >
As we use RFCOMM, we need to setup the linux box
user@laptop:~ > cat /etc/bluetooth/rfcomm.conf
# RFCOMM configuration file.
rfcomm0 {
   bind yes;
   device 00:13:03:19:12:80;
   channel 1;
   comment "BT-001";
user@laptop:~ >
user@laptop:~ > cat /var/lib/bluetooth/<your_BT_adapter_addr>/pincodes
00:13:03:19:12:80 1234
user@laptop:~ >
Step 4: Final
The indicator is action !
    • Clocks Contest
      Clocks Contest
    • Make it Move Contest
    • Planter Challenge
      Planter Challenge
    2 Comments
    Oh MAAAAN do I ever need one of these.
    That is so damn COOL.
