Awesome Airsoft Grenade
 by AirsoftMan
This is a cool grenade that is very simple to make. Perfect for battles in forests.
Step 2: Attaching the filler
Attach the water balloon to the end of the filler but don't put it too far on.
Step 3: Filling the balloon
Put about 5-10 BBs in the back part of the filler. Then blow so the BBs go into the balloon.
Step 4: Finishing
Repeat step 3 about 3-4 times so the balloon about 1/4 full of BBs. Then bow up the balloon and throw it at someone.
1-40 of 104Next »
ahallstrand2 says: Mar 15, 2013. 1:59 PM
It works ONLY IF you put a little extra weight such as some water, a marble (I use a marble), a small stone, or a triple A battery as mentioned in an earlier comment. It is a bit hard not to rip the balloon during the process of putting extra weight in besides water. Overall though if you are looking for something easy this is good.
kry_knutt says: Sep 4, 2008. 4:28 PM
To be honest I don't see how this would work, maybe if you filled it with something that would cause massive expansion so the balloon would explode sending the BB's everywhere
solpredator in reply to kry_knuttApr 29, 2012. 8:06 AM
Don't ask why but if you put a AAA+ battery inside the balloon it will make it explode on impact.
Caml^Vacation in reply to kry_knuttFeb 3, 2012. 4:52 PM
i made one of thes a couple months ago and i just put some water in it. it worked pretty well. you just need to have it hit something hard.
mike11818 in reply to kry_knuttJul 2, 2009. 3:27 AM
thats very true, one idea is that when you mix vinegar and bicarbonate of soda, you get fix! (or a bang if in an enclosed space), so this may just work... idea for exploding balloons: *get a normal water balloon. *fill with desired amount of bb's (more bb's, the more coverage). *then put some bicarbonate of soda onto some toilet paper and tape.(don't tape all around or it wont work. *put this folded bong of paper inside the balloon and then fill with vinegar.... *then tie!.... *WHEN YOU HAVE THOUGHT OF A PLACE TO PUT IT (BUT BE QUICK!) PUT IT ON FLOOR AND SHAKE IT LIKE MAD.... AND RUN! *SHOULD BANG!
chardlz13 in reply to mike11818Jan 26, 2012. 2:46 PM
Wouldn't it be better to put the bag deeper inside the balloon (a little bit beyond where the knot would tie) then use a slipknot to hold the bag in place. Then pull the slipknot when you are about to throw it and the pressure takes about 3 seconds to build up enough to break the balloon. That way you can pull the knot and throw it down range to get a better combat effectiveness.
Redgerr in reply to mike11818Jul 15, 2009. 7:48 AM
thats what i was thinking, or do something like the stomp thing, seal some in a small baggie and somehow put it inside.. get water balloon get bb's and put in balloon put some vinegar in a little baggie and seal (maybe opposite? baking soda?) -- put in balloon-- put lots of baking soda in the balloon (maybe opposite? vinegar?) fill with very little air tie off balloon when you wanna throw it you just drop it, stomp on it, pick it up, throw
Redgerr in reply to RedgerrJul 15, 2009. 7:56 AM
35Timmy says: Feb 10, 2012. 3:27 PM
this is fool proof for those who can tie knots
Air_Assassin says: Dec 26, 2010. 8:26 AM
(removed by author or community request)
#1 boss in reply to Air_AssassinAug 18, 2011. 1:41 PM
i think so
Air_Assassin in reply to #1 bossAug 18, 2011. 2:37 PM
lol
XxyourshotxX says: Apr 14, 2011. 7:55 AM
how are you supost to blow it up?
XxyourshotxX says: Apr 14, 2011. 12:44 AM
i have done a similary one but how do you blow it up?
piedoom0 says: Oct 30, 2009. 5:34 PM
where do you buy your bbs?
Are they any good for AEGS?
dudemanclc in reply to piedoom0Mar 12, 2011. 6:57 PM
bioval biodegradable bbs they dont have powdery stuff on them
from www.airsoftextreme.com
KritoPerf in reply to piedoom0Feb 13, 2011. 3:52 PM
you need seemless BB's for AEG's you dont 'need' them but cheap walmart, dicks, etc brands have a seam all the way around and a little bump whil seemless are smooth, most gun return policies do not accept jamming by use of poor quality BB's like 'evike, airsplat, airsoftmegastore (my choice), etc' and you can get 10,000 bbs for like 20 dollars, like tracers for good quality and worth the money
superawesomekid78 in reply to piedoom0Dec 28, 2010. 10:22 AM
you can buy bbs at dick's sporting goods or offline on amazon or Evike.
sweetchild123 says: Feb 7, 2011. 4:45 PM
does it even work
llamma1010 says: Mar 16, 2010. 9:40 PM
u spelled blow wrong
Air_Assassin in reply to llamma1010Dec 31, 2010. 8:06 AM
no he means tie the top of ballon
Air_Assassin says: Dec 23, 2010. 4:05 PM
gytigcfry7sdgftvxc fyhugtrfwe4567ujmftn gserty76ukmjytnr se56yujhnbvgraqWE45TVGFC QWe4grbvc wEerty5edaszssdftry
jamboo754 says: Aug 16, 2010. 8:12 AM
doesnt work ive tried to make a ton of things like that including your design and they all dont work the only way to make a gernade that will actuially have a chane at hitting something is if you use explosives fire crackers or something like that
Dread_Neck in reply to jamboo754Dec 15, 2010. 9:29 AM
Dont do this, use 10-20 BBs, fill it up with water (not too much) and throw. the less space, the better. i live in cali, and im going up tho mammoth mountain (ski resort) with my buddies. were gonna stop in nevada, get some M-10s, And do the easter egg thing.
Toomuchtime5798 in reply to jamboo754Oct 3, 2010. 2:03 PM
That's not necessarily true. While firecracker grenades are the best, they aren't the only ones that work. Although decent non-explosive airsoft grenades are few and far between, that doesn't mean they don't exist. Here's a decent spring loaded one I just found. It's only noticeable issue is that it doesn't have a 360 degree radius.
http://www.instructables.com/id/Reusable-Airsoft-Grenade-No-Explosives/
jamboo754 in reply to Toomuchtime5798Oct 4, 2010. 2:40 PM
your right but 99% of the time they don't work but there are a few out there that work. i just stick with explosivies because there great and i know they work
Air_Assassin says: Dec 13, 2010. 6:17 PM
that is awesome
tomm0505 says: Jul 22, 2009. 5:32 AM
How are you supposed to blow them up?
spartan 2209 in reply to tomm0505Aug 24, 2009. 12:26 PM
ummmm....throw it?
tomm0505 in reply to spartan 2209Oct 31, 2009. 5:03 AM
I ment as in inflate. (I think it's spelt that way)
spartan 2209 in reply to tomm0505Feb 19, 2010. 4:20 PM
Oh, my bad. Haha, you just blow it with your mouth.
cdousley in reply to spartan 2209Jul 6, 2010. 10:45 AM
Thats what she said! :)
bobandthemonkey in reply to cdousleySep 5, 2010. 2:12 PM
ZING!
poper123 says: Aug 4, 2010. 5:10 PM
i live in donwtonw atawa in a condo
cdousley says: Jul 17, 2009. 6:44 PM
this will blow up if u run
tomm0505 in reply to cdousleyJul 6, 2010. 9:08 AM
KAMAKAZIE!
hhhttt says: Mar 19, 2010. 6:04 PM
add some Ramen noodle flavor packs, hide it in or on a tree, and shoot it. BOOM they are out. but make sure it is totally filled with air, or it wont pop and you give away your position
airsoftbeast40 in reply to hhhtttApr 27, 2010. 4:03 PM
why ramen noodle packs?
hhhttt in reply to airsoftbeast40Apr 27, 2010. 4:44 PM
because it makes their nose really irritated and mkaes them too busy with their nose than with the gun i do it all of the time try not to get it in their eyes tho
airsoftbeast40 in reply to hhhtttApr 27, 2010. 7:18 PM
oh ha ha thats good i thought you meant there was a chemical in it or somehting that made it explode =)
1-40 of 104Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
