Awesome Binder Wings
392
5
Published
Introduction: Awesome Binder Wings
These wings may not help you fly, but they look pretty cool in motion! I discovered this project While thinking about what I could make with a binder. Pretty weird, right? Let me show you how to make them!
Step 1: Materials:
Paracord. One piece, 145cm, two pieces, about 80cm, a binder, and an X-Acto knife.
Step 2: Mark!
Mark a line with a straight edge (I used a meter stick) on the second ring. Then mark an “x” on the edge of the binder. Make sure to do this on both ends!
Step 3: Cut!
Use the X-Acto knife to cut a hole in the binder where the “x” is.
Step 4: Paracord!
Loop the cord around the edge and through the hole then tie it. remember to do this on both sides!
Step 5: Pull!
Pull the string through the bottom two rings.
Step 6: Cut! (again)
Cut holes by the top and bottom ring (4 holes in all).
Step 7: Arm Straps!
Thread the two shorter paracords pieces through the holes you just made. Then tie the ends together.
Step 8: FLY!
Pull the string on the back.
Tip: Use a lighter to bond the paracord together!
  • Casting Contest
    Casting Contest
  • Woodworking Contest
    Woodworking Contest
2 Comments
