First: Stern warning / disclaimer... Don't try this at home. I am in NO way encouraging anyone to make a "worx bomb". I recommend suggesting the activity to a chemistry teacher or someone who will have the proper safety tools at their disposal. I am not responsible for any injury you may sustain during the recreation of this experiment. You assume all risk and liability. The chemical reaction involved generates a significant amount of heat along with an aqueous aluminum chloride solution, and can be dangerous if one does not take the proper precautions. Now let's have some fun!
This instructable will be submitted in both the Mad Scientist contest and the Teacher's Contest.
This experiment is perfect for the mad scientists out there because of the intense reaction. It is also perfect for science teachers because the materials are cheap and easy to come by (always a plus on an educators' budget), and the reaction that takes place is quite simple for students to understand.
Educational objectives can be modified for different ages and ability levels. NOT recommended for students younger than 8th grade.
Student will demonstrate ability to...
create a replacement reaction.
describe what happens during a chemical change and four possible clues that it has taken place.
apply the law of conservation of mass to chemical reactions
relate pure chemistry to applied chemistry.
describe the relationships among the temperature, pressure and volume of a gas
write a word equation.
write a balanced chemical equation.
Extension: identify areas affected by chemistry research
Remove these ads by
Signing UpStep 1Materials
Safety Goggles
Worx toilet bowl cleaner (20% hydrogen chloride)
Aluminum Foil
250 mL Flask
9 inch balloon
Scissors
Ruler
Binder Clip
Matches (now you know this is going to be awesome!)
You may want to have a fire extinguisher nearby just in case.
See why in the video (Filmed with the GoPro2... the room doesn't fill with smoke, it's just a little condensation on the lens. Check out step 4 for more video action).
For years I've wanted to make airborne soap bubbles with hydrogen inside so that when touched with a match would rupture with a good "pop". Any idea of how to accomplish that with these materials?
He would use electrolysis into a balloon to generate and capture an oxygen/hydrogen mix. then release the gas under soapy water to make the bubbles. When the kids trooped into the classroom, he'd be "washing" his hands in the sink, then, with a handful of bubbles, he'd "dry" them over a waiting Bunsen burner. Note, have your mouth open in a yawn before you ignite the bubbles!
Lance ==)-------------------
Your dad was a cool teacher; kids musta loved him.
Measuring, plotting, and explaining the difference in bouyancies of large vs. small bubbles could make for an fascinating class in itself. Such an effort could be complicated by membrane weight changes due to dripping & evaporation as well as gas weight changes due to hydrogen migration through the membrane.
Yeah, the kids loved him, and he loved the kids. His teams were the only ones the school district ever sent to national academic competitions; there was a budgetary line item just for them, since they took state almost every year. Unlike larger schools, his dinky rural school sent two teams to state, usually taking second or third in addition to first places. Unfortunately, he had to take early retirement for medical reasons and died early. The state student engineering society named an award after him.
He did cool stuff like firing a rifle into a ballistic pendulum to measure the speed of the the bullet (in the classroom!). I inherited a lot of his cool toys, like a 7' demonstration slide rule and a Super Ball look-alike that doesn't bounce (he loved switching it in as he passed a Super Ball around when they were doing a unit on elasticity deformation; frustrated the daylights out of the jocks). When the state required him to clean "dangerous" chemicals out of his storage room, a lot of them found their way home. He shot up an old bottle of picric acid on my uncle's farm; no BOOM!, unfortunately.
When I made mine, I used a beer bottle to hold the acid, and I used the pop tops from pop cans for aluminum. I would also dilute my acid a bit to slow the reaction, otherwise I tended to get a bubbling noxious mess that went out of control. I also found that I could slow the reaction by having the lower part of the bottle in a tub of water to cool it. It took longer,(~20 minutes to fill a balloon), but I found that I go less water vapor in the balloon and they would actually be light enough to float.
Another good source of HCL is just the straigh muriatic acid they sell in the paint departemnt. Only about $5 per gallon.
Again, good work. I like that you also point out the chemistry principles at play, so the students actually learn something too!
We filled the balloon with Hydrogen gas and put a match to the balloon.
We called it the Hydrogen Bomb Experiment.
Walter Bates will be remembered for that experiment for as long as we live.
Quite a legacy.
Just sayin.
That said, awesome experiment!
