Step 8The Clamp Down
iImage Information
We supported the slats from the top and bottom (we did the same thing on the other end simultaneously) to keep the pieces even as we squished them together with pipe clamps. You should also keep some wood scraps between the clamp faces and where they meet the wood. If you're not careful you can end up damaging your project by leaving a depression if you clamp tightly. After you get the boards clamped from the sides be sure to remove the clamp and wood you used to keep everything in line (pictured), otherwise you'll end up with railings on your cutting board, which most users will find undesirable.
