3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Awesome Hard Drive Tower
I recently backed up all of my pictures to DVD. Having a fair amount of photographs this took up about 25 disks. I immediately started thinking of an alternative way of archiving my stuff. I already have an external hard drive that I use for "backups." the issue with that is that I leave it plugged into my computer almost constantly and its also likely to be stolen should my house be broken into. I wanted something that's faster then dvd's but not likely to be stolen. Rummaging through my massive amounts of computer parts I found a bunch of older hard drives of varying sizes and a usb to ide adapter. A few more parts from an old computer and my hard drive tower was born!
Step 1Materials
Materials
Here's a list of what I used:
7 Hard Drives of various sizes, from 80 gigs to 20 gigs
1 old computer power supply with it's own dedicated on/off switch
1 hard drive bay chassis (don't know what the proper name is) from an old computer
1 usb to ide adapter (the more the better)
a bunch of different screws
and for tools:
Drill with metal drill bits
screwdriver
all the materials, except for the usb to ide adapter can be found at a computer recycling place, the side of the road, garage sales, attics, etc. for free or for a very low price.
19 comments
Apr 5, 2012. 1:23 PMTheRealDutchOwner says:
You should add a power switch for every drive. It's kinda alot work, but will save power and reduce hard drive noise. You could also add a CD drive that has a audio jack and control buttons to add an extra use, CD playback! Add some (cheap) speakers to the tower and blast some tunes to drain out the time of copying, moving and deleting files! And ofcourse, you could replace the hard drives with CD/DVD/ect. drives to create a burning station.
Mar 28, 2012. 3:54 PMDustySeven7 says:
if you want to do a NAS or have eSATA check this little project that this guy did.
http://www.willudesign.com/BlackDwarfTop.html
Nov 1, 2011. 11:41 PMTystarr says:
http://aphnetworks.com/lounge/turn_on_psu_without_motherboard_the_paperclip_trick Quick way to make your PSU work for this project.
Aug 9, 2011. 7:32 AMkool1zero says:
you can use a more modern power supply, short the green wire going into the 20/24 pin connector to a black.
i found this in another instructable, it shows where to place a standby power and power LEDs, and even a power supply.
http://www.instructables.com/id/ATX--%3E-Lab-Bench-Power-Supply-Conversion/step2/Planning/
May 22, 2011. 1:13 PMtinker234 says:
cool looks like a simple vacum form case could make it a pro then agin i love the look of it as is just wow reminds me of strgate data crystals
Feb 12, 2011. 1:37 PMelectrolinks says:
Like this. Do most towers come with 7 power connections? How would you link the drives together so that theres only one interface for them? RAID? Now where will I find an old tower with a power supply with its own switch....
Feb 18, 2011. 7:20 AMPaul Chops says:
To answer your question yes you can get a PSU with 7 power IDE connections!
my old one had six, but you can always mod a PSU with a few more because the motherboard connection is not getting used so you can put like 10 HDD on a 250 watt PSU!
You can make a PCB Board that all the HDD can plug into maybe a little hard but is possible, ill have a look around for you at a place.
You can get oooollllldddd power suplies that have their own switch but then your talking 1990's stuff, i have a few but sadly they are 'as dead as a door nail'.
Feb 18, 2011. 9:04 AMelectrolinks says:
Hmmn I really want to build one. Might have to design it from scratch. Where's Woz when you need him?
Feb 18, 2011. 11:24 AMPaul Chops says:
If you are going to build this i would recomend using Serial ATA (SATA) HDD's.
SATA's are quite cheap, fast and you can get a 250g for really cheap!!
Also Sata would be easier building an adruino board for.!
Feb 19, 2011. 5:42 AMelectrolinks says:
Steve Wozniak, co-founder of Apple.
Feb 18, 2011. 11:20 AMPaul Chops says:
I can get one designed for you but that would cost big bucks!!!
Like hundreds, ($).
Sorry, i think if you build one from scratch it would cost alot cheaper, By the way who is 'Woz'!
Feb 19, 2011. 5:43 AMelectrolinks says:
Where would you get it designed?
Feb 19, 2011. 6:46 AMPaul Chops says:
i know a company who designs them. i think they have a branch in New Zealand and USA and South Africa
But i would recomend building your own one or designing your own with a program called 'Eagle Cad....'
Oct 28, 2010. 6:44 PMAdam Manick says:
You can get a 256 gigabyte flash drive for around 650 US dollars. So much memory i that little thing.
Jul 26, 2010. 6:43 PMDIY Dave says:
I'm planning to do this as soon as I get some more hard drives.
Jul 2, 2010. 2:51 PMrocketman221 says:
Now you just need to be able to put all of the drives into raid.
Jun 29, 2010. 12:48 PMddh1969 says:
I appreciate the fact this is a DIY project but this reminds me a lot of a DROBO from Data Robotics...but I guess this a neat and cost effective (basically free) alternative.
Jun 29, 2010. 12:36 PMmasterochicken says:
I've actually been wanting to do this but didn't know how. Thank you! 5 stars.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:fro fro
