This instructable assumes that you understand basic sewing concepts.
Sewing tools required:
-scissors (good sewing scissors that can cut denim),
-a straight edge ruler
-marking tool (tailors chalk, or sewing marker - a regular pencil/pen can work too)
-seam ripper
-sewing machine with heavy duty needle (size 16, 18 or a denim needle)
-iron
Remove these ads by
Signing UpStep 1Determine desired length
I have turned the extra fabric to the inside. I placed a pin at the outside and inside seams of each leg to mark the length I want. Be sure you do this to both pant legs.
Take the jeans off. At this point you need to determine the line you will cut to shorten the jeans. Lay the pants out flat. Compare the insides of each leg. If your pins aren't exactly aligned, place a new pin half way between the original pin on both pant legs to find the average desired length.
Compare the outside leg seams in the same way, adjusting the pins to find the average.
i don't think its necessary to rip the old hem at the finishing too,
if you rip them you have to find the same yarn used for the outer sewing in the jean,and sometimes this is not easy.
i think maybe its better if you rip the secret sewing in the side of the leg of the jean a few inches kai you do the same in the cutted finishing and then sew them together.Then you just sew the hidden side again with any colour of yarn you have,cause is hidden and won't make a difference.
This way(if you rip the side),it will fit perfectly,because elseway if you fold the cutted finishing over the jean,it won't fit 100% right
This happens cause it's usually exactly the same width,and when you fold two round clothes with the exaclty same width,the inner part wrinkles/folds a little.
