The concept of this project is simple; engrave a name on a piece of clear plastic sheet then shine a light on the edge of the plastic. The letters and edges are vividly illuminated whilst the clear material remains completely transparent.
To add a touch of color, use multicolored RGB LED's in conjunction with a microcontroller. This combination allows hundreds of different colors to be achieved. With just the touch of a button, transform the work piece from red, to green, to blue and anything in between.
This Instructable requires basic knowledge of wood working, hand tools, electronics, programming, and soldering.
Remove these ads by
Signing UpStep 1: Gather Materials
Materials:
1 - Polycarbonate Sheet - 10.75in x 2in x 0.25in - local plastic supplier, $3
1 - Oak Board 24in x 5.5in x 0.25in - menards, $3.31
1 - Wood Glue, 4 fl. oz - menards, $3.88
16 - RGB LED's w/diffused lenses - sparkfun.com, $1.99ea
32 - 100 Ohm, 1/4W, 5%, Resistors - jameco.com, $0.02ea
16 - 180 Ohm, 1/4W, 5%, Resistors - jameco.com, $0.02ea
1 - 1K Ohm, 1/4W, 5%, Resistor - jameco.com, $0.02ea
1 - 560 Ohm, 1/4W, 5%, Resistor - jameco.com, $0.02ea
1 - 0.47uF Monolithic Capacitor - jameco.com, $0.12ea
1 - PICAXE 8 Pin Microcontroller - sparkfun.com, $2.95
1 - PICAXE 8 Pin Proto Kit - sparkfun.com, $3.95
1 - PICAXE USB Programming Cable - sparkfun.com, $25.95
1 - Darlington Driver 8-Channel ULN2803 DIP - sparkfun.com, $1.95
1 - 18 Pin DIP socket, - sparkfun.com, $1.50
1 - Mini Push Button Switch - sparkfun.com, $0.35
1 - 2.1mm DC Power Jack, Male - jameco.com, $1.49
1 - Break Away Header - Straight - sparkfun.com, $1.50
1 - Rocker Switch, DPST, ON-OFF, Black - jameco.com, $1.49
1 - Break Away Header - Right Angle - sparkfun.com, $1.95
1 - Wall Adapter Power Supply, 5VDC 1A - sparkfun.com, $5.95
4 - Multipurpose PC Board with 417 Holes - Radioshack, $1.99ea
22AWG Solid Jumper Wire, Various Colors - jameco.com, $6.95/100ft
5 - Hex Socket Cap Screws, 4-40 x 1/4in - mcmaster.com, $7.50 (100)
Tools:
Wire Stripper
Side Cutter
Needle Nose Pliers
Dremel High-speed Rotary Tool
Dremel Engraving Bit
Needle File Set
Sandpaper (600/800 grit)
Utility Knife
Mini Vise
Digital Multimeter
Third Hand Tool
Soldering Iron/Station
Solder
Drill
3/32 Drill Bit
3/32 Hex Driver
Vernier Calipers
Metal Ruler
Small Bar Clamps
Saw
Computer
Safety Glasses
Visit Our Store »
Go Pro Today »
http://www.instructables.com/id/Render-3D-images-of-your-PCBs-using-Eagle3D-and-PO/
Wondering what software you used to draw out your circuits. Is it NI Multisim?
Now, I have an idea.. I want the pizza guy to find my house in the dark without turning on my light... what if we took this idea, put it to a small solar panel, with a small battery system, and added house numbers instead of a name?
This way with the solar panel, small rechargeable battery system, and a light sensor, it should charge during the day, and light up at night. showing the house number in place of the name....
I like your idea... thanks for giving me mine...lol
DONE!
I guess it's kinda cool to do this with a push button but the micro controller is always on so that justs sucks your battery life.
Like chasing lights, multi-color fading, timer-to-off, or something? ANYTHING?
Since the led circuit is already set for 5Volt...then all you really need to do for "on/off" is to feed it power from a usb port, or cell phone wallwart charger, or as ogama8 says, batteries.
We'd like to hear from klbrockmann on this, before we dismiss it as a case of wildly over-engineered technobabble.
I think my biggest issue with this project right now is power consumption. Ideally, I would like power to be sourced from batteries or possibly USB. Right now the circuit running with all colors on (white) draws a little over 1A at 5VDC. 1A rules out USB and AA batteries won't last more than 1.5 hours. I haven't figured out the best way to cut down yet, but I'm working on it.
