3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Awesome LED Edge-lit Desktop Nameplate
You'd be hard pressed to an office with a desktop that doesn't have a nameplate. This DIY project transforms the classic engraved vinyl nameplate into a high tech piece of art. It’s the perfect way to spice up anyone's desk at home or at work.
The concept of this project is simple; engrave a name on a piece of clear plastic sheet then shine a light on the edge of the plastic. The letters and edges are vividly illuminated whilst the clear material remains completely transparent.
To add a touch of color, use multicolored RGB LED's in conjunction with a microcontroller. This combination allows hundreds of different colors to be achieved. With just the touch of a button, transform the work piece from red, to green, to blue and anything in between.
This Instructable requires basic knowledge of wood working, hand tools, electronics, programming, and soldering.
Step 1Gather Materials
Gather Materials
  • last photo ←
Materials:
1 - Polycarbonate Sheet - 10.75in x 2in x 0.25in - local plastic supplier, $3
1 - Oak Board 24in x 5.5in x 0.25in - menards, $3.31
1 - Wood Glue, 4 fl. oz - menards, $3.88
16 - RGB LED's w/diffused lenses - sparkfun.com, $1.99ea
32 - 100 Ohm, 1/4W, 5%, Resistors - jameco.com, $0.02ea
16 - 180 Ohm, 1/4W, 5%, Resistors - jameco.com, $0.02ea
1 - 1K Ohm, 1/4W, 5%, Resistor - jameco.com, $0.02ea
1 - 560 Ohm, 1/4W, 5%, Resistor - jameco.com, $0.02ea
1 - 0.47uF Monolithic Capacitor - jameco.com, $0.12ea
1 - PICAXE 8 Pin Microcontroller - sparkfun.com, $2.95
1 - PICAXE 8 Pin Proto Kit - sparkfun.com, $3.95
1 - PICAXE USB Programming Cable - sparkfun.com, $25.95
1 - Darlington Driver 8-Channel ULN2803 DIP - sparkfun.com, $1.95
1 - 18 Pin DIP socket, - sparkfun.com, $1.50
1 - Mini Push Button Switch - sparkfun.com, $0.35
1 - 2.1mm DC Power Jack, Male - jameco.com, $1.49
1 - Break Away Header - Straight - sparkfun.com, $1.50
1 - Rocker Switch, DPST, ON-OFF, Black - jameco.com, $1.49
1 - Break Away Header - Right Angle - sparkfun.com, $1.95
1 - Wall Adapter Power Supply, 5VDC 1A - sparkfun.com, $5.95
4 - Multipurpose PC Board with 417 Holes - Radioshack, $1.99ea
22AWG Solid Jumper Wire, Various Colors - jameco.com, $6.95/100ft
5 - Hex Socket Cap Screws, 4-40 x 1/4in - mcmaster.com, $7.50 (100)
Tools:
Wire Stripper
Side Cutter
Needle Nose Pliers
Dremel High-speed Rotary Tool
Dremel Engraving Bit
Needle File Set
Sandpaper (600/800 grit)
Utility Knife
Mini Vise
Digital Multimeter
Third Hand Tool
Soldering Iron/Station
Solder
Drill
3/32 Drill Bit
3/32 Hex Driver
Vernier Calipers
Metal Ruler
Small Bar Clamps
Saw
Computer
Safety Glasses
47 comments
1-40 of 47next »
Mar 4, 2010. 3:38 PMclemsonguy1125 says:
 were do you buy your plexiglass
Mar 5, 2010. 12:42 PMclemsonguy1125 says:
 ok because the plexiglass at my lowes charges 20 bucks for a 2 by 2 foot sheet
Sep 15, 2010. 8:02 PMcdousley says:
WHERE DO YOU LIVE? I can get plexiglass cut any size for a few bucks at my local hardware store
Sep 17, 2010. 3:29 PMclemsonguy1125 says:
The US. this is at LOWES
Nov 6, 2010. 1:43 PMPatentPending says:
I got a huge square for less that $10.. You might be looking at Lexan which is more expensive.
Nov 7, 2010. 12:34 PMclemsonguy1125 says:
At Lowes?
Sep 17, 2010. 8:21 PMcdousley says:
wow!
Oct 11, 2010. 5:55 PMcoopgrl88 says:
Fantastic presentation! This is a great example of How to do a How to. Clear pictures and great outline and descriptions :) Thanks! You made this project even easier.
Oct 6, 2010. 7:09 PMrcisneros says:
I'm not that skilled with the heat source. I just used acetone (not nail polish remover) and carefully wipe down the edges over and over. They'll come clear. The best is methyl chloride, but it's very hard to find.
Oct 5, 2010. 4:15 AMninjanody says:
very nice instr..
Sep 19, 2010. 8:10 PMpantalone says:
How bright (mcd) do the LEDs need to be to make this look good? The LEDs you link to at Sparkfun are rated 2800, 6500, and 1200 mcd for the red, green, blue, respectively. Will the result be just as pleasing if using cheaper LEDs in the 600 mcd range?
Aug 13, 2010. 12:09 PMpilotniq says:
Is it possible to share resistors between the LEDs? If not, why not?
Apr 24, 2010. 6:23 PMhandyman29 says:
What program did you use to create the 3D image of the circuit board?
Sep 15, 2010. 8:00 PMcdousley says:
this is diffrent then his but it also renders images of circuit boards i have used it and i works great to
http://www.instructables.com/id/Render-3D-images-of-your-PCBs-using-Eagle3D-and-PO/
Aug 25, 2010. 7:46 PMCreativeman says:
Very impressive instructable! Beautiful work. It gives me ideas as I like to make signs as well. I picked up on a very un-nerving sight, though, when I looked at picture 4 in step 3. It looks like the saw is running in this photo, and your left hand is in front of the blade! This is extremely dangerous, and should never be done in this manner. That piece should have been ripped, using a rip fence. NEVER, NEVER, NEVER place a hand ahead of a blade as you have done here. Had that piece got in a bind and kicked back, your hand would be toast...er more like ground hamburger. And plastic is a non-standard material to be cutting on a table saw. I hate it when the "worried about your welfare police" chime in like I have just done, but this picture screams at me: NO NO NO.
Mar 31, 2010. 5:37 PMjds311 says:
 Do you have a schematic, as I need to down scale the board size?  Thank you
Mar 11, 2010. 9:51 AMvinniekins says:
 Nice project!
Wondering what software you used to draw out your circuits.  Is it NI Multisim?
Mar 3, 2010. 7:14 AMampeyro says:
good drawing, what have you studied?
Mar 8, 2010. 8:42 AMampeyro says:
now i understand, it's not comon to find quality in this webs
Mar 4, 2010. 7:18 PMogama8 says:
 where?
Aug 31, 2010. 1:49 PMhintss says:
Iowa state
Mar 5, 2010. 1:33 PMmathman47 says:
Wow, great idea and great execution.  Can't wait for the code, since I'm just learning about microcontrollers and it would take me awhle to do it myself. Ideas, ideas, ideas.  Thanks for a great instructable.
Mar 2, 2010. 10:31 AMRobot Lover says:
you could just use tape and a sand blaster. Good instructable!
Mar 5, 2010. 8:16 AMjeff-o says:
When I engrave plastic, I print out the pattern and place it under the plastic.  Then I go at it with a dremel and fine tip sanding/grinding bit.
Mar 5, 2010. 8:25 AMRobot Lover says:
when i engrave glass i used a sandblaster
Mar 5, 2010. 10:12 AMthepelton says:
You can also engrave glass with an Epilog laser.  I would probably use one of those rectangles of antique glass with the beveled edges for something like this.
Mar 5, 2010. 10:13 AMthepelton says:
one additional thing.  I would probably use an antique lettering font to match the glass.
Mar 4, 2010. 10:16 AMtcase says:
This is neat,
Now, I have an idea.. I want the pizza guy to find my house in the dark without turning on my light... what if we took this idea, put it to a small solar panel, with a small battery system, and added house numbers instead of a name?
This way with the solar panel, small rechargeable battery system, and a light sensor, it should charge during the day, and light up at night. showing the house number in place of the name....
I like your idea... thanks for giving me mine...lol
Mar 5, 2010. 8:15 AMjeff-o says:
I've seen commercial products almost exactly like this.  So yeah, your idea should work fine.
Mar 4, 2010. 9:45 PMshaneomacmcgee says:
 Very cool. Great project, great ible, just great.
Mar 4, 2010. 8:49 AMdunnos says:
tsss. cnc, you're such a show-off :P
Mar 2, 2010. 6:37 AMr-philp says:
That looks great!  Do you have any information on programming the microcontroller?
Mar 2, 2010. 7:58 PMlucasicecream says:
haha that circuit is wayyyy more expensive and complex then it needs to be:)
1-40 of 47next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:klbrockmann
