Awesome iPod Touch (1st gen) Game Boy Color Case by mr_goodbytes
Step 1: Opening the GameBoy
because those bastard at nintendo are so afraid people will tamper with the gameboy's insides, they decided to be total losers and make the screws, not an X or I, but a Y (grrr)
because of this unfortunate circumstance, we will have to make our own special screwdriver for this special screw. (that is, of course, assuming you dont have a compatable screwdriver)
what you need:
a dremel
a rough sander attachment
a vice is extreemly useful
a well lighted area (the cuts are going to be small)
a high attention span
a gameboy color
a small (really small) hex wrench
Step one
clamp the hex wrench in the vice REALLY tightly. make sure your dremel is on the lowest power setting, and insert the rough-cut sander attachment.
Two
sand the tip of the hex wrench down to a triangle, each of the three corners matching up with the notches on the screw.
Three
put on the fine-cut sander bit and sand the SIDES of the triangle inward, untill the wrench fits into the screw notches.
CaptainRainbowz says: Apr 18, 2013. 4:09 PM
I would still steal that cause its a freakin gameboy
Survivor#1234 says: Nov 3, 2011. 3:36 PM
I have all of these tools but,NO GAMEBOY!!!!!!
Oh the irony!
Madrias357 says: Jan 11, 2010. 3:02 PM
I hate asking this kind of question, but seeing as you left all the guts in there, does the Game Boy still work?
Oi23 says: Sep 24, 2011. 7:18 PM
They cut out the battery area. So no,probably not,but if you were to get a AAA or AA battery holder,run the wires to the points where the Gameboy accepts the battery's energy,and put batteries in the holder,it'd probably work.
smonokoppa says: Jul 11, 2011. 7:14 PM
That's ultra-cool! However, I have a few comments...
- A triwing screwdriver isn't that expensive!
- When you screw everything back together, you can replace those pesky security screws with regular Philips screws. A trip to the hardware store and a few bucks would save a headache later, especially if you stripped the screws.
- To paint the GBC (or any handheld), one can use vinyl dye as well. It is a special paint for plastics that won't chip and actually seeps into the plastic instead of making a layer above it! Cool, right? Krylon Fusion is also a good option. (I don't think it's a true vinyl dye, but for this application, it should work.)
Cool stuff!
greenranger89 says: Aug 7, 2010. 8:49 AM
i do this all the time for my friends, but for the ipod touch i used a Game Boy Advance, and for the the ipod video or "classic" i used a gameboy pocket. I will post it up soon. It will be epic and blow your mind. still needs a few things to make it perfect. greenranger will save the day.
mr_goodbytes (author) says: Oct 18, 2009. 10:44 AM
or you could make one in ten minutes and buy an ice cream cone from dairy queen with that $2 :)
Kasm279 says: Jul 4, 2010. 5:56 PM
For me, who collects and cleans the internals of the things, they help a lot. Now i need the two gamebits for the N64 and the various carts...
Lance Mt. says: Nov 27, 2009. 4:52 PM
 Could you make the coice any easier? Ice-cream it is!
chainfire95 says: Aug 16, 2009. 11:58 PM
Or you could spend $2 and buy the correct screwdriver online.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
