3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Awesome-ifying Your Facebook Profile
Facebook changed layouts recently, adding a row of 5 images (the 5 images you were most recently tagged in) at the top of the profile page. Using Photoshop (or G.I.M.P. or MSPaint if you'd rather), you can make mini-images to fill this space and show off your creativity.
Note: Check this out for the awesome inspiration behind this and more ideas
Step 1Making Mini-Images
Making Mini-Images
  • last photo ←
If using the template provided here (as a PSD and a PNG), you can skip ahead to #3. Note that depending on the amount of information in your profile above the 5 images, you may need to make some adjustments if you are including your main profile image in your awesome design as this template is based on having three lines of text at the top (having more or less text at the top of your profile can shift the orientation of the line of 5 mini-images slightly).
  1. Take a screenshot of your profile. I'm a huge fan of Snagit (which is available for both Mac and PC), which is awesome for taking screenshots. Alternately, if you're using a Mac, you can use Grab or if you're using a PC, you can use the Print Screen key on your keyboard
  2. Open your screenshot in Photoshop (or other photo editing program)
  3. Select and delete the areas where the 5 tagged images are (and your main profile image, if you'll be replacing it also)
  4. Create a new layer and place it behind the existing one
  5. Select an image (or images) you'd like to use and paste them onto this new layer
  6. Resize the image and make adjustments as needed so that it shows through panes in the way that you'd like
  7. Select the areas for each of the mini-images, and cut and paste each into a new document, and save
  8. If you're creating a main profile image to go along with the mini-images, select, cut and paste, and save the same way to create that image
175 comments
1-40 of 175next »
Dec 24, 2011. 2:03 AMAntzyP says:
Well I'm commenting again but I had to share this image. This is "not exactly" what this instructable shares but it has spun off from this idea only... Its an album composed of a single image. Hope u guys like it...
Dec 28, 2011. 1:37 AMAntzyP says:
Thanks :D
Oct 22, 2011. 2:25 PMymagination says:
Well, as others said, is really nice, once ou get it, but, just refresh the page, and all gets shuffled...
Press [F5] several times, and you will see all your effort and illussion go thru the window... :-S pitty... it was nice...
Mar 23, 2011. 9:46 AMhhermann schou says:
Every time I refresh the page the images are being shuffled randomly. Is there a fix to this?
Sep 14, 2011. 11:04 PMzonewarrior says:
The same happens to mine - is there a fix ??
Mar 4, 2011. 12:42 PMMotaKun says:
i dont understand the 5 and 6 steps, how i tag the fotos, Wat name i tag it? my fotos dont appear.. im sad, i cant do that.. little help please..
sorry my English and ignorance...
Feb 12, 2011. 5:28 PMTomcat94 says:
On a Mac, you don't need a program to take a picture of your screen.
Use this keyboard shortcut:
"Command (the key with the apple on it)" + "Shift" + "4"
Then you can click and drag across the part you want to capture.
Very good instructable-- I'm going to do something similar for Valentine's day. It'll be five images with one word on each one that says: "HAPPY VALENTINE'S DAY (my girlfriend's first name) (my girlfriend's last name)" Either that, or I'm going to put "I LOVE YOU" instead of happy valentine's day.
Mar 3, 2011. 4:12 PMhelifino says:
on winblows, you can hit the 'print screen' key to copy your current view to the clipboard...
Feb 7, 2011. 2:49 PMlaxap says:
Your Instructable + Gimp + cartoon effect + drop shadow = this:
Feb 20, 2011. 7:40 PMZDress says:
I love the drop shadow effect. I'll have to try it out soon.
Feb 14, 2011. 1:51 PMthing 2 says:
There is a website called fbanners.com that makes this easy!
Feb 14, 2011. 2:06 PMthing 2 says:
I liked the pic of the person who used the 5 small ones for his eye and for head and the side for the side of his face!
Feb 14, 2011. 2:05 PMthing 2 says:
Thanks for this sweet 'ible!
Feb 12, 2011. 6:15 PMTomcat94 says:
I've already commented on this instructable enough times, but I had to show what I did.
Feb 13, 2011. 6:06 PMTomcat94 says:
Perhaps I should blur out my name as well... I completely forgot to do that... :/
Feb 10, 2011. 5:56 PMo_grande_rei says:
My pictures are tagged in the correct order, but every time i visit the page, the order changes. the order is different every time. Anyone else encounter this?
Feb 10, 2011. 2:51 PMsputrea says:
Thanks a bunch! I hate the new profile--I even hate having a profile picture. My friend was getting on me for appearing blank, so this solved that problem.
I really love the idea!
Feb 3, 2011. 3:35 PMseanathon says:
Can someone try to make an mspaint template? I can't download photoshop.
Feb 9, 2011. 5:03 PMemmarocket says:
Hey! you could try "gimp" if you can't get photoshop - here is the link :)
http://www.gimp.org/
Feb 10, 2011. 1:08 PMseanathon says:
Thanks so much for all your help! after dividing and splicing, I've finally done it!
Feb 3, 2011. 4:13 PMseanathon says:
Thank you so much!!! Giving you five stars!
Feb 3, 2011. 4:45 PMseanathon says:
I'd love to post it, but unfortunately, am younger than the average user on the site and I do like to keep my work private. I will try though, I promise! :D
Feb 7, 2011. 6:19 PMthisisvlad says:
Every time that someone tags a photo of you, you need to go t your profile and x out those new images? so, possibly you will have to do this every day multiple times? wow, that sounds fun.
1-40 of 175next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
283
Author:shesparticular(Sometimes I tweet about stuff)
Learn more about me here: http://www.instructables.com/id/Featured-Author-shesparticular/ or follow me on Twitter (@shesparticular) (if you're into that sort of thing).
