Step 2The box
Use the hot glue gun to make them into a box. Leave off the last side for now.
Drill a hole in one side of the box, make the hole large enough for the button on the switch to be pushed through it.
n+d^3?
And how big does the sheet to cut from need to be?
Hope that helps.
Piece 5 and piece 6 (not visible) are (n-2d) x (n-2d).
b>Diagram is not to scale, btw. My pieces wont be that thick compared to length</b>
saved money, ;p
Just to help clear up the whole dimensions problem, as long as you use the diagram someone posted below then 4 middle peices should be the same, and the other 2 top and bottom peices should be the same.
The 4 middle peices should be (n-d) x (n-2d) ; n = the length or width, d = thickness of sheet.
If you so this then the top and bottom peices of the cube should only have to be n x n.
1. Where to buy that plexiglass?
2. Can i use a Super Glue instead hot-glue gun?
3. What resistor is best to use?
Also how thick was the plexiglass that you used and could it be easyly cut with a scroll saw?
i have heard that before and i have been born
I've got everything but the Metal (Soda Can)
And an LED (radioshack)
