Introduction: Awesome Lego Figure Shelf
Picture of Awesome Lego Figure Shelf
Everything is awesome!
My son has quite a lot of lego figures. I made this shelf for him to play and show the lego figures. It's fun and handy. No more lego figures messing around.
An eye catcher for his friends,
Very easy to make with simple tools!
If you like this, please vote in the upper right corner of the screen.
Step 1: What Do You Need for This Project
Picture of What Do You Need for This Project
Lego compatible ground plate
First of all a 3d printed lego compatible ground plate. In this example a 3x20 nops is used. But you can also use 2x20 or even 4x20 nops.Print it with your own 3D printer or choose a hub in your neighbourhood on www.3dhubs.com.
Piece of wood
A piece of wood. I used a 18x27mm piece of wood for this project
Adhesive tape
Double sided adhesive tape to glue the lego compatible plate to the piece of wood
Screws
Finally the screws to mount the lego shelf to the wall.
Step 2: Lego Compatible Groundplate
Picture of Lego Compatible Groundplate
PRINT!
Print as many ground plates as you need. In this project I made two lego figure shelfs with each five 3x20 nops plates. But you can vary this as you like.
The .STL files for 3D printing of 2x20, 3x20 and 4x20 ground plates are provided with this instruction. With the openscad file you can change the dimensions of the ground plate to whatever you like,
The plates have a flat bottom, so the adhesive tape will stick to it.
If you don't have a 3D printer, find a hub in your neighbourhood on www.3dhubs.com.
Step 3: Cut, Paint and Glue
Picture of Cut, Paint and Glue
Cut the piece of wood in the appropriate length.
If you want two screw the shelf to the wall drill the holes before painting.
Paint it in the color you like.
Glue the lego plates to the piece of wood with double sided tape.
Use lego blocks to connect the lego plates to each other before glueing. In this way the plates are automatically in the right position.
Step 4: Ready
Picture of Ready
Enjoy the result!
ashleyjlong (author)2015-04-17
I know a collector who just might need one of these--thanks for sharing the files!
cozmogeek (author)2015-04-17
This is a cool idea. It makes me want to design one that is entirely 3d printed including the wall mount mechanism.
mhenderson17 (author)2015-04-17
Another option for those without 3d printing option could be to glue pieces together, using a base plate to keep their alignment proper. Just be careful to keep the glue from touching the base plate, and continue the chain once the first bit sets well. Then you could just have a long line of 4x2 blocks make up the shelf. Great instructable, very neat idea!
sibren (author)2015-04-17
This looks super awesome! Nice job!
tomatoskins (author)2015-04-17
That shelf turned out looking great! Thanks for taking the time to share and welcome to the community!
About This Instructable
1,231views
31favorites
License:
More by ChrisT18:Electric tooth brush organiserAwesome lego figure shelf
Add instructable to:
