Awesome paper plane!!
 by samando
Step 1: Step one,the base
For this plane you start with a piece of A4(foolscap)paper and fold a waterbomb base. If you know how to do this, skip this step.
first, crease from the top left or right diagonally down as if to make a sqare, and do the same on the other side, then turn it over and make a horizontal crease where the 2 diagonals meet, now if you turn it over again and press the place where all the creases meet it should pop up slightly, pull this popped up piece down so the top of the diagonal creases meet the bottom, there will now be triangular areas outlined by the creases and you should be able to push these in to the other existing triangle.You are now finished!
lime3D says: May 16, 2012. 11:13 AM
I've been making this design for years, with one small difference. If you make a few small tears at the rear of the wings, you can fold up flaps. If you set the angle right, you can launch the plane, and it will do a complete 360 degree loop. If you launch it sideways, it will come back to you like a boomerang!
inergy says: May 4, 2009. 5:37 PM
pictures
samando (author) in reply to inergyMay 4, 2009. 10:41 PM
sorry?
cstrike pwner says: Sep 15, 2007. 8:00 AM
yes i am not the only one that knows how to buield a pitpit!!!!! kewl first comment!!!
sora005 in reply to cstrike pwnerApr 11, 2009. 2:43 PM
a what?
cstrike pwner says: Sep 15, 2007. 8:03 AM
im make'n my first instructable it's the paper match rocket. i have seen'em go over 50 ft.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
