Axel Chakrams Tutorial (For Cosplay)
 by Amatero
So hello.  In this tutorial I will show, how to build the weapons of Axel ( from Kingdom hearts)  for cosplay.
Step 1: Let´s begin...
First you need some stuff to build them^^
Stuff you need ( for both Chakrams):
·          4 X Sticks out of wood (Length: ca. 12 inch ; bore: Not important you should be able to grab it.^^)
·            8X Circles of styrofoam (caliber:  ca. 8 inch)
·            Printer paper (it should be pretty thick cause we will made the blades out of them. And they will be hollow inside.)
·            A lot of old newspapers
·           Glue
·           Wire ( for the external circle)
·          Tape
·          Paint ( you need just two colours   Red and silver. Use that kind of colour you prefer. I used a combination of Spray and normal wallpaint. )
·          1 X Deco - marker  from Edding ( not necessary but it was helpful to correct the paint. You never be able to paint it completely perfect.  ;)   )
·           Some stain to make the whole thing water-resistant
·          Three rolls of  Tennis grip band
Tools you need: (well the tools I used ^^)
·        Saw
·         Brush
·         Cutter
·        Ruler
·         Chisel
·        Hammer
·         Rasp
·        Pincer
·        (And some workspace)
Ok. Now let´s start’: (with one Chakram)
1.
At first you have to mark the middle of your sticks. Then you should cut a slot like in this picture.  The slots are as long as the sticks thick. Try to do straight slots. When you put two sticks together it should be a cross.
2.
Stabilize the cross with tape. Don´t worry, later you will not see the tape. So you can use a lot. But you should be able to grab it later too ;3
Then add the Styrofoam circles also fix them with tape. For a better hold you can also make some slots in the rings. But careful they are fragile.
skymhsmhfskyrs says: Apr 9, 2013. 6:05 PM
Awesome!! Love kingdom hearts! 1000000000000/5
Kain...! says: Jun 6, 2012. 7:00 PM
very cool guy , i need to make one !
sry for my bad english , i am brazilian.
Dusk Shadows says: Apr 24, 2012. 5:52 PM
WOW I LOVE KINGDOM HEARTS AND AXEL IS MY FAVORITE CHARACTER
BUT THE ONLY PROBLEM WITH KINGDOM HEARTS IS ALL THE TALK ABOUT LIGHT AND DARK AND HEARTS I THINK IT KEEPS ON REPEATING ITS SELF
(YOU'VE GOT MY VOTE)
Amatero (author) in reply to Dusk ShadowsApr 25, 2012. 2:04 PM
Thank you very much! ^^
Tomcat94 says: Apr 23, 2012. 11:42 AM
Not bad! I like them. :)
5 Star'd and Fav'd.
Amatero (author) in reply to Tomcat94Apr 24, 2012. 2:31 PM
And also thanks a lot for the stars and fav ^^
Tomcat94 says: Apr 23, 2012. 1:57 PM
You might want to separate this step into two steps, like this:
Step 1 Materials Needed
(Picture of just the materials you need)
First you need some stuff to build them^^...
... (And some workspace)
Step 2 Let's Begin!
(Pictures of the first few building steps)
Ok. Now let´s start: (with one Chakram)...
... But be careful, because they are fragile.
Most readers skim through the materials needed section and go on to see the build process, so by doing this, it's less likely for your reader to miss the important first steps of making the chakram!
Hope this helps. :)
Amatero (author) in reply to Tomcat94Apr 24, 2012. 2:30 PM
Thank you. That´s a good advice. I will edit the Instruction when I have the time. ^^
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
