Azkaban Prison Sign
Published
Introduction: Azkaban Prison Sign
About: I am a software developper, addicted to props
Today, I will show you how to do an Azkaban Prison Sign from Harry Potter for cheap and fast.
You will need :
  • Cardboard
  • Pen
  • Hot glue
  • Paint
  • Xacto
Step 1: Trace the Model
First, trace the model of a box in 2D on the cardboard. This step is pretty simple. You simply have to measure everything. Just for your information, my Azkaban sign dimensions when assembled:
  • 30 cm Width
  • 17 cm Height
  • 3 cm Depth
So for the dimensions of the model on the cardboard you will have to draw according to these measurements.
Step 2: Cut the Model and Cut Rectangle Shapes
Next, simply cut the model you traced. On the cut part, trace and cut 5 rectangles of same dimensions and 2 long rectangles at the bottom of them. You will have to cut multiple ''middle part'' to add depth effect to the holes you've made. You can glue them together when finished.
Step 3: Trace and Cut the Depth Part
You will have to cut a plain rectangle about the same size of the top part. This will be the white part of the sign that you will glue with the other parts that you used to add a depth effect.
Step 4: Assemble the Box and Paint the Signs
To assemble the box, I used hot glue that I applied to the different corners. It's really easy to assemble, just follow the pattern. For ''damage'' effects, I used black and grey paints and then I sand everything.I (try to) reproduce the numbers/characters/shapes from a picture I found on internet.
Step 5: Final Result
An easy DIY project for everyone who likes Harry Potter. It cost me nothing, it looks very good and fits perfectly with my other props! Hope you enjoyed it, any comment is welcome.
  • Oil Contest
    Oil Contest
  • Stick It! Contest
    Stick It! Contest
  • Make it Move Contest
