BAS-39v3.5
2,776
15
75
Published
Introduction: BAS-39v3.5
I made a true bolt action gun. I have been talking about this gun a little bit. Fell free to mod it and do whatever you want. The only person that knew about this was Dsman192576 (sorry if I messed up the numebers.) So here it is.
Step 1: Magazine, Chamber, and Barrel
First Step:
Pics 1-4: Make this
5:Make This
6:connect
7:Make these
8:Connect
9:Make
10:Connect
Step 2: Body
Okay here it is.
1:Make
2:Make
3:Add the yellow connector
4-6:Make
7-9:Make handle
10:Connect
11:Connect
12:Connect
13-14:Add Barrel.
15:Make
16:Add
17:Make
18:Add
19:Make
20:Add
21:Add this
22:Add
23:Make this and attach put it into the grey connectors at the top of the mag.
Step 3: Extended Barrel and Bipod
Here is the barrel and bipod. Thhe bipod is Killerk's bipod with mods.
1:Make
2:Make
3:Make
4:Connect
5:Make
6:Connect
7:Make
8:Make
9:Connect
10:Make 2
11:Make 2
12:Connect
13:Make
14:Connect
15:Make
16:Connect
17:Connect
18:Done
Step 4: Stock
This is I Like It's stock with a couple of mods.
1:Make
2:Connect
3:Make
4:Connect
5:Make
6:Different View
7:Make
8:Connect
9:Connect
10:Add
11:Add
Step 5: Scope
Here is my scope.
1:Make
2:Add
3:Make
4:Connect
Step 6: Connect
Almost done
1:Stock and Body
2:Connect
3:Scope and Body
4:Connect
5:Extended Barrel and Body
6:Connect
7:Bipod
8:Trigger Rubber Band
9:Firing Pin and Bolt
10:Add Firing Pin and Bolt
11:Add Firing Pin and Bolt
12:Trigger
13:Add Trigger
14:Done!!!
Step 7: Loading and Firing
Last Step.
1:Take off scope
2:Insert rods into mag
3:Pull back Firing Pin
4:Push forward bolt
5:Bullet In Barrel
6:Bullet shot
    • Pets Challenge
      Pets Challenge
    • Planter Challenge
      Planter Challenge
    • Make it Move Contest
    75 Comments
    super but how does it shoot
    You don't know it but you're very lucky. I built your gun and I want to rate it. All I ask in return is for you to post a link to the rating on the front page of the gun. I already have 3 requests but I built yours first even though you didn't ask. If you want to see what I do look here. If you don't want it just say no, but please say yes.
    I really don't care whether you rate my gun or not.
    You do know I mean a detailed rating right. Not just a 4* or something.
    I know.
    Im making my own true bolt action rifle atm. I just finished the main barrel, the fake barrel, the mag, and the chamber. Its sorta based off yours, but mine doesnt use decapitated parts, and it uses less knex. also it shoots yellow rods and the firing pin and bolt are on rails.
    An orange or brown connecto cut in half
    Will it fire with the bolt back?
    Depends, if you just pulled it back no, but if you pulled it back pushed it forward and pulled it back again then yes, but it will have less range.
    Wow, a TRUE bolt-action.
    actually, true bolt action is pull back and then push forward pull back to move the "ram" (i forget what it is called) out of the way to load first bullet and then push forward to load bullet into barrel' then pull trigger to fire (there is more going on then just that but I am trying to explain a specific thing
    not only that, but in almost every bolt action gun the bolt twists before you pull it back (how it takes the bullet from the clip or magazine).
    yeah i know I saw it somewhere before but I forgot where so I couldn't give credit to anyone.sorry.
    -late reply- I think I've seen a stock distictively similar to the one on this on Dutchj's Assault Rifle.
    But its ok. You can leave it that way.
