Introduction: BB Gun Target
Make a target that shoots out flour when you hit it with your airsoft/bb/pellet gun.
Step 1: Gather Materials
Things you need:
aluminum foil
ping pong ball or a small ball
water bottle
flour
spoon
Step 2: Making the Mould
Take the ping pong ball and wrap it half way up in aluminum foil.
Then take the ping pong ball out without destroying the mould so you have a small indent.
Step 3: Adding the Flour
fill the indent with flour, then take the spoon and compress the flour as much as possible.
Step 4: Folding
Close up the flour hole by folding the aluminum sheet in half, then continue folding over...
then fold over the right side and then the left side.
you will then have a small packet, compress it as much as you can, the foil will withstand you pressing down on it.
once your done with all of that, at this point you can use it as shatter target, throw it up in the air and shoot at it, i'll explode if you have a high enough fps. the next steps make it a bit more stable and it wont explode as easily. but its a great target.
Step 5: More Foil
Take a samller sheet of aluminum foil than you used before, place the packet of flour you made and put it on top of the foil towards the top.
then fold over each side,scrunch up the strip haning off the packet, then fold that over 2 times, dont compress this part too much because you want a snug fit.
Step 6: FIRE!
set the stub of the packet inside the water bottle, you may want to fill the water bottle with water to make it stable and not fall over in the wind, then just shoot it and big puff of flour will come out, after you shoot it, you may want to compress the flour again to get another big puff of flour.
i couldnt get a picture of the puff of the flour but i got a picture of what it looks like after you shoot it.
