BB Machine Gun(NOT AIRSOFT!!!!!)
 by Ianman
Step 1: The parts
First off, this is not an easy build, it takes patience and craftsmanship to get it all together.
The parts I used on this gun are pvc pipes (rated at least 400 PSI!)Including the pvc drain trap and all reducers/splicers.
All of the brass fittings need to be npt(national pipe thread)I used 3/4".
As for the stock and the barrel, the came off an old pump action bb gun, but those were just to make it cooler.
The trigger is a blow gun, and the laser sight is optional.
The most important part of this is the VORTEC BLOCK, which itself takes some time to make.
Dr.Bill says: Feb 20, 2009. 2:14 PM
Well there's a lot of things that are different between our countries. You should come to Rye, NY and visit a place called "Play Land". Inside Play Land you can find a little booth to shoot co2 powered BB Guns that are machine guns but they are Co2 powered. A gas powered machine. No flaming powder. They are classified as AIR GUNS and as such do not use Fire. They shoot. However if you are talking expressely in terms of Silencers being Legal For Guns, the answer is No. Originally I thought there was discussion as to weather or not this BB Gun was a fire arm. Clearly it is not. It uses compressed to a tank gas to shoot. At any rate it looks like a fun Toy. You should not use a silencer with it. Rats will never know what hit them. Bye!
Ranie-K in reply to Dr.BillDec 9, 2012. 4:37 PM
My personal understanding is that you legally CAN suppress it in the US as long as the suppressing part is not removable.
freddysserpent in reply to Dr.BillApr 30, 2010. 5:19 AM
Dude if you want a silencer in the U.S. You can apply to the BATF for licencing. Its pretty much the same requirements as for manufacture of firearms.Or so I found while I was there. You can do the same thing here in Australia except the requirements are stricter. Also Australians beware airsoft and air/co2 powered weapons are legally classified as firearms so if you want to use this stuff please be on the lookout for the johnnies
mr.pizza says: Sep 1, 2012. 6:24 PM
im 13 i under stand all the cocepts and engineering of the design but due to my age some parts are hard to come by could i substitute some of the parts and maybe funnel the entrance for the bbs in the vortex to reduce jamming?
wcs873 says: Apr 10, 2012. 3:47 AM
Same project can be found at burntlatke.com. Hope this helps everyone.
wcs873 in reply to wcs873Apr 10, 2012. 3:51 AM
Sorry the path is: burntlatke.com ==> Build Your Own ===> BB Machine Gun (pneumatic)
Ianman (author) in reply to wcs873Apr 10, 2012. 8:47 AM
Which is mentioned in step 2.
Click on the hyperlink "vortex block".
TSC says: Apr 16, 2010. 12:56 PM
Nice 5stars!!!!!!!!!!!!!!!
Ianman (author) in reply to TSCJan 7, 2012. 6:34 PM
Thanks!
TSC in reply to IanmanJan 8, 2012. 1:01 PM
Your welcome!
Aron313 says: Jan 7, 2012. 9:11 AM
Make a video. Some guns that i made with plans offline didnt fire far or ran out quickly
Ianman (author) in reply to Aron313Jan 7, 2012. 12:11 PM
There is a video right under the main pic and description.
Aron313 in reply to IanmanJan 8, 2012. 6:05 AM
ok thanks
Billy mahony says: Sep 17, 2008. 12:11 PM
What did u use for your vortex block?
Ianman (author) in reply to Billy mahonySep 22, 2008. 2:13 PM
Bondo, read the inst.
Billy mahony in reply to IanmanSep 26, 2008. 11:33 AM
it looks like a solid chunk of copper or bronze.
Ianman (author) in reply to Billy mahonyJan 7, 2012. 6:49 PM
Copper BB's will discolor it.
skidoo says: Jan 30, 2009. 9:26 AM
Neat project and all, I guess. But 500 RPM? That's only like 8 shots a second. And what sort of muzzle velocity are we talking? I dunno, 24+ rounds-per-second (1440 RPM) is nothing for a decent airsoft gun shooting .25 gram BBs, and I don't see why you couldn't push steel BBs at the same rate. Especially if you're using an air compressor and a vortex block. More thorough instructions would be nice, so we could more precisely suggest how to improve your rate of of fire. "A" for effort though! :-)
Ianman (author) in reply to skidooJan 7, 2012. 6:38 PM
8 Shots a second sounds like to much?
Watch the video. And listen...
guitarmonk15 says: Jul 4, 2010. 1:35 PM
would a gravity fed magazine work instead of the vortex block? I'm thinking about a pen tube filled with bbs.
Ianman (author) in reply to guitarmonk15Jan 7, 2012. 6:32 PM
It is already gravity fed...
adrian09 says: Jul 12, 2010. 8:06 PM
do u hav a video of the whole process? or more detailed ones..
Ianman (author) in reply to adrian09Jan 7, 2012. 6:32 PM
Nope, going to have to use your imagination.
Billy mahony says: Jun 9, 2010. 9:11 AM
Does anyone have any ideas on running this off a CO2 tank, Making it more portable.I have no idea on how to regulate the flow? pressure, any help would be great.
Ianman (author) in reply to Billy mahonyJan 7, 2012. 6:31 PM
No, you need a high CFPS rate that only a big air compressor tank can accommodate.
guitarmonk15 in reply to Billy mahonyJul 4, 2010. 1:28 PM
Do you mean running it on something like a co2 bike tire inflator? Because I had that EXACT same idea. I'm guessing it would work pretty well, but I have never tried it.
Billy mahony in reply to guitarmonk15Jul 24, 2010. 11:43 AM
I was thinking something slightly larger (Paintball tank) but yeah, annything light and portable, how fast do you think the flow is on a tire inflator, my guess is pretty low, but it should work.
dla888 in reply to Billy mahonyOct 16, 2010. 12:26 PM
Get a CO2 regulator. Look on amazon, or ebay.
prop master says: Feb 1, 2011. 7:09 PM
could you modify this for airsoft
Ianman (author) in reply to prop masterJan 7, 2012. 6:29 PM
As long as the barrel was the correct internal diameter, but why wuss the gun up like that?
rocketman217 says: Jun 9, 2011. 2:27 AM
Hi, could i power this with 8 gram co2 catridges?
Ianman (author) in reply to rocketman217Jan 7, 2012. 6:28 PM
No.
besty1262535 says: Dec 14, 2011. 4:37 PM
were is the other part
Ianman (author) in reply to besty1262535Mar 28, 2007. 3:28 PM
Did you mean *where is the other part*?
What other part?
Football viking boy says: Aug 12, 2011. 1:33 PM
those pipes 400 psi ? WOW those must be bought online
coilsinamotor says: Dec 1, 2010. 9:58 PM
wow very clear drawing of the block 5/5
Ianman (author) in reply to coilsinamotorDec 2, 2010. 4:17 PM
Thanks, But not my doing.
six shot says: Nov 28, 2010. 6:58 PM
hey, if you put a wooden/cardboard/plexiglass body on that, you could make the wunderwaffe dg-2 from nazi zombies.
Nandthemountingplusman says: Aug 19, 2010. 12:04 AM
I remember using the ordinary and old style of airgun for bird hunting when i was young. I think i can enjoy more now by availing the benefits of technological developments. Is it possible to put a scope in my airgun like what i have seen that are connected to riffles such as the AR 15 Scopes? Are these kinds of rifflec accessories adaptable to airguns?
prodo123 in reply to NandthemountingplusmanSep 6, 2010. 6:57 PM
You're gonna go bird hunting with a fully-automatic machine BB gun with an Colt AR-15 scope? You're gonna explode the poor pigeon's brain
cyborgpigeon says: Mar 5, 2009. 3:49 PM
that thing is NICE! ive been wanting to try something like that for a while. I think ill try to run mine off fridge pumps and rechargable cylinders when i get around to it. i know 1 liter at @ 500 psi won't run a full auto bb gun for long but thats what im gonna try. only down side is i live really close to the local gestapo headquarters. im from the u.s. these things are legal but they are frowned at by the sheepel patrol. and no something that is compressed gas powered is not a fire arm! i feel that laws that say that are tyranical bs. if you want to see something similarly Evil!? go to spudfiles dot com and do a search for "DeathRay". just look through their site first before you start askin stupid questions. they have lots of info on how to make airguns. remember no one likes to spoon feed lazy people.
imthatguy1125 in reply to cyborgpigeonFeb 19, 2010. 3:54 PM
 those fridge pumps take forever to pump u a co2 cylinder to 500 psi ive heard , to slow of flow
cyborgpigeon in reply to imthatguy1125Feb 27, 2010. 12:03 AM
yes the small ones can be slow and tend to tap out at 275- 350 psi. example mini fridge compressor. but the big ones can be scary fast and dangerous. example full size fridge compressor or window air conditioner compressor.
do not ever attempt to use one unless you know what you are doing! its highly dangerous and not for beginners. they can output lethal pressures i cant stress that enough!  also the case around the pump is subjected to the overall system pressure. the cases can separate with potentially lethal results. there was actually a law suit where one came apart during a test at lower than the supposed rating. there has been at least one person crazy enough to do a max test on one. his was able to reach pressures in excess of 1000psi, needless to say that is an extremely dangerous thing to do. a long time ago i had one hit 750 plus psi in seconds. that was way too close to death for me. not a thing to be taken lightly in the least.
Gksarmy in reply to cyborgpigeonApr 17, 2010. 2:04 PM
so...if one were to set several of these up together in a series with spring caps calculated to release when the pressure was around 700 in each tank/compressor...death?
~Aeronous~ in reply to cyborgpigeonSep 15, 2009. 5:30 PM
damn it! the stupid web filter at my school actually works
Sundevils2234 says: Jun 2, 2008. 11:57 AM
To add a safety, just add a small valve in between the blow-gun and the vortex block.
Ianman (author) in reply to Sundevils2234Jun 2, 2008. 8:43 PM
Thanks for the input.
NEALP123 in reply to IanmanMar 21, 2010. 7:08 AM
can you ues a bicyle pump insteat of psi
max0506 says: Feb 15, 2010. 1:53 PM
why do you need a vortex block why don't you just have a tube with BB's in it a hole for the barrel and a hole for the airinput.
and do you need a pressure reducer so the air streems out slow or can you just place a ball valve and open the valve so the BB's slow the air down
(I use a pressure champer not a compressor or somthing its portable)
thax and a nice gun!
imthatguy1125 in reply to max0506Feb 27, 2010. 12:53 PM
 umm are you talking about a cloud chamber
Ianman (author) in reply to max0506Feb 26, 2010. 9:24 PM
Physics, you dont understand them. Therefore, please do not attempt to build any weapon or projectile launcher.
max0506 in reply to IanmanMar 5, 2010. 2:00 PM
don't be angry!!
and I already made a airgun for marbles or that kind of projectiles.
siggi says: Sep 16, 2009. 6:09 AM
can u make better blue prinnts so we can build are own gun thats as cool as this one. plz
covey12 says: Aug 26, 2009. 1:50 PM
i made a vortex-cap instead of a vortex block and mine shoots 60 bbs a second, and to much money to shoot it for a whole minute lol thats like a couple thousand bbs
~Aeronous~ in reply to covey12Sep 15, 2009. 5:48 PM
how/
~Aeronous~ in reply to covey12Sep 12, 2009. 5:31 PM
oh hey can you plz upload an instructable for this one and an instructable for the vortex block to? im stuck on this and Im not sure what to do.
andrebododea says: Apr 19, 2009. 6:02 PM
How much compressed air would u need to power this thing? Like you buy those cans of CO2, but how much would u need to attach at once? And you attach it to the end of the blowgun right?
~Aeronous~ in reply to andrebododeaSep 15, 2009. 5:26 PM
no. i just used some compressed air in a can. they cost about $5 but i modded mine so i pump it up again every 200 shots or so, and i attach it to the end of the barrel
siggi says: May 5, 2009. 2:49 PM
how does he load that thing.
~Aeronous~ in reply to siggiSep 15, 2009. 5:24 PM
easy. unscrew the lid and pour the bbs in
dmantha says: Sep 9, 2009. 3:31 PM
I wish to verify the legal definition of firearm for any that are wondering. The exact US Legal definition of Firearm by title 18,part I, CH 44, SEC 921 says:
(3) The term “firearm” means
(A) any weapon (including a starter gun) which will or is designed to or may readily be converted to expel a projectile by the action of an explosive;
(B) the frame or receiver of any such weapon;
(C) any firearm muffler or firearm silencer; or
(D) any destructive device. Such term does not include an antique firearm.
I got this definition from the database of cornell university law school at this web address:
http://www.law.cornell.edu/uscode/18/usc_sec_18_00000921----000-.html
This is the legal term for firearm. Because a air gun does not use an explosive, it does not fall under the term "firearm" by US federal standards. I do not mean to step on anybodies toes. I personally wanted a legal definition of firearm and thought I would share what I found.
~Aeronous~ in reply to dmanthaSep 12, 2009. 5:26 PM
is this techically legal?
dmantha in reply to ~Aeronous~Sep 14, 2009. 4:44 PM
If you mean "technically", then yes....as far as the laws about firearms are concerned. If there is any legal problems, it would be with a different law that would be over items other than firearms. Examples would be lethal weapons, alternative weapons, compressed gas weapons, or something of that nature. If a law only refers to "firearms" then it does not cover airguns since airguns launch projectiles through NON-EXPLOSIVE means and by federal definition firearms specifically use EXPLOSIVE means.
l3owzaaaah says: Jun 13, 2009. 5:21 AM
I want one, but where I am the pvc sizes are on a different system and I don't know metric to inches translation. Interested in a contract? Same build is fine but could the trigger be nearer the handle rather than the stock and give me an approximated price for one of that's okay. I have a compressor so it should be okay.
spman123 says: Mar 22, 2009. 9:31 AM
I'm guessing there won't be any updates on construction :(
Dr.Bill says: Feb 20, 2009. 3:06 PM
We do make the distinction in the US as to what a fire arm is. A fire arm uses gunpowder. Muzzle velocities start some where around 900 fps. The last pop gun I used that was that slow was a 22 cal cb short for killin rabbits for the freezer. My first BB gun was a crossman 760 and it would shoot a pellet at 900 fps. The difference is in USA a fire arm uses gun powder. Don't even think of even making a silencer for your BB Gun. The ATF will take it and you if they find you with one for any kind of gun mainly because it can be used on a real firearm also if it is made out of plastic it could be deemed a terrorist tool. Good Bye And Good Rat Hunting.......
knoxarama says: Dec 28, 2008. 1:01 PM
that is a firearm. A siencer is illegal to use with this. Anything that fires something is a firearm.
Dr.Bill in reply to knoxaramaFeb 10, 2009. 12:39 PM
seems an awful lot like an air gun. no powder, no fire.
knoxarama in reply to Dr.BillFeb 13, 2009. 2:12 PM
no, air guns are firearm. and they do fire. i think your thinking of the plasma fire, where is fire in this case is to launch as a projectile.
masterofsniping92 in reply to knoxaramaFeb 20, 2009. 6:48 AM
I agree with knoxorama to a degree. Legally speaking, airguns are considered firearms if their velocity exeeds 500 fps(at least in Canada). So, this COULD be a firearm if it had a velocity in excess of 500 fps. In that case, it would be illegal to put a supressor on it, as stated in my comment below. However, There is an exception. If you purchase an airgun with a suppressor already installed, such as the Gamo Whisper, it is 100% legal to use, so long as you dont take the suppressor off and make your own. Consult the BATFE for more information.
Ianman (author) in reply to knoxaramaDec 28, 2008. 5:19 PM
And what the heck is a siencer?
knoxarama in reply to IanmanDec 31, 2008. 9:05 AM
a silencer muffles the noise given off by the gun. It'sbasicly a little tube with some stuff in it.
masterofsniping92 in reply to knoxaramaFeb 20, 2009. 6:41 AM
The correct term is actually "suppressor", since it only suppresses the noise, rather than completely silencing the weapon.
Ianman (author) in reply to knoxaramaDec 31, 2008. 3:01 PM
Spell check, make friends with it.
knoxarama in reply to IanmanFeb 13, 2009. 2:13 PM
really, i just don't trust their spell check. it has nothing. i put in nuclear, just as i spelt it there, and it gave me neuron.
Dr.Bill says: Feb 14, 2009. 7:15 AM
The gun does not fire. It shoots. To say that it fires implies that it uses a propellant that is combustable. You have an AirGun.
knoxarama says: Feb 13, 2009. 2:14 PM
if it uses air to fire it, it is AIR SOFT!
Dr.Bill in reply to knoxaramaFeb 14, 2009. 6:42 AM
AirSoft is AirSoft This is just another AirGun
awaite says: Dec 21, 2008. 4:27 AM
Hey can you only use this with the air compressor attached or is it portable?
Dr.Bill in reply to awaiteFeb 10, 2009. 12:43 PM
CO2 expands 750 times its own volume out of an extinguisher. A 45 lb fire extinguisher will supply enough. You can even wear one on your back with a scuba pack.
Ianman (author) in reply to awaiteDec 21, 2008. 8:19 AM
Did you read anything on here?
legokevin360 in reply to IanmanJun 30, 2009. 4:24 PM
funny pic
Dr.Bill says: Feb 10, 2009. 12:36 PM
Power Ball Machine On Crack! Good Laugh!
gunsnroses says: Feb 3, 2009. 1:05 AM
hey nice gun but just one question: why is the trigger on the stock? wouldnt it be easier to fire from the shoulder if you put it on that 45 degree black tube further forward? again very nice gun and kudos to you
logann2292 says: Dec 4, 2008. 9:02 PM
This interesting. I am currently doing a project, and this is alot of help. I'm trying to use this same idea, but have a revolving quad barrell system. I think I am going to try to use one air compressor, and 4 vortex blocks, as I have a big air compressor, but I'm not sure if its possible with the vortex block being upside down at some point, and the big pvc drain tap. Any ideas anyone? Thanks.
Ianman (author) in reply to logann2292Dec 4, 2008. 9:54 PM
Im a bit confused. You are going to use a revolving set of four barrels and four v-blocks? if the barrel is revolving, how are you going to time the line up of each barrel to a v-block and the bbs not jam up? With the steady psi needed, you wont be able to controll when the bbs come out. As for the v-block, its doesnt have to be any specific shape, as long as there is an inlet, outlet, and a way for the bbs to enter the vortex. Before I built my 1st v-block, I made a mock one to demonstrate the theory. I used a scrap piece of a 2x4, drilled a 1 inch hole appx 1 inch deep with a forester bit ( so the hole was flat on bottom) and drilled the inlet and outlet holes in tangent and at right angles to each other. Then I put 5-8 bbs in the hole, clamped a piece of plexi over the hole and stuck a blowgun in the inlet hole. What you will see is the bbs spinning around the inside diameter of the 1 inch hole (hence the "vortex") and as soon as a bb lines up with the outlet hole, it escapes at a velocity corresponding with the psi applied and the snugness of the outlet hole and the bb coming out. I reccomend testing this outside of course and at a low pressure. This should give you a really good idea of the internal physical dynamics in progress with out the big build. Hope this helps, let me know. Thanks for the question.
logann2292 in reply to IanmanDec 5, 2008. 12:32 PM
Actually, what I think I'm going to try to do is drop the revolving barel idea. I'm going to made the vortex a little bigger, and drill 4 holes for 4 barrels into the vortex. I have a powerful air compressor, so it should be fine. You think this will work?
Ianman (author) in reply to logann2292Dec 5, 2008. 8:56 PM
Glad you are dropping the revolving barel idea, though it would look fricken awesome. As for the 4 holes in the vortex block, It might work, but you will be losing a lot of air and pressure. Think of it this way... In the split second that a bb enters the outlet, it causes the internal pressure to build a bit (resistance), thus producing more force propelling the bb. With 4 holes, even if 3 bbs are expelled at the same instant; the 4th one is just spewing air and reducing the power behind the other 3. Sorry to sound like a bummer on your ideas, it would make an awesome gun, but it would take alot of very precise engineering and tight tolerences to make it work perfectly. Even with my single barrel, it can jam, the v-block wears out, and the bbs in the vortex are extremly chaotic and impossible to predict when they will come out. Im blabbin, so ill stop.
Billy mahony says: Sep 26, 2008. 11:42 AM
is the stock from an old pumpmaster 760,(by Daisy)?
Vertigo666 says: Mar 31, 2007. 9:20 AM
does it fire at a constant speed? like do the bullets come out at regular intervals?
Ianman (author) in reply to Vertigo666Mar 31, 2007. 4:06 PM
Fairly constant, probably around 10-15 per second. Sounds like a quiet machine gun, though it does jam on occasion, but a quick shake clears it up. Ill try to add a video
irwinner in reply to IanmanMar 31, 2007. 10:47 PM
10-15 a sec is nothing i made one of these that shoots 50 - 100 a sec, was just using it i an airsoft game yesterday and it didn't jam once. the problem with yours is you don't have a shroud on your vortex block, if you don't have one it slow the rate of fire and makes it jam easier and those pieces are definitely not rated to 400psi, if you believe that you obviously haven't done much research, for example the tee your using as a bb chamber is NSF-DWV, as in drainage pipe. its only certified to 60psi (although i have pushed one to 115psi with out failure a few time). the clean out and bushing your using are also DWV. and you don't need an air compressor to use one of these all you need it a 5 gallon air tank, or a regulated co2 setup so you can make it portable pretty easy
Billy mahony in reply to irwinnerSep 17, 2008. 12:16 PM
could u explain the CO2 setup, with pics plz.
Ianman (author) in reply to Billy mahonySep 22, 2008. 2:12 PM
It does not use Co2, it uses compressed air.
Billy mahony in reply to IanmanSep 26, 2008. 11:36 AM
i was commenting irwinner, sorry for the confusion.
bigal77 in reply to irwinnerJun 11, 2008. 12:56 PM
What psi do you have your compresser at
Ianman (author) in reply to irwinnerApr 2, 2007. 4:02 PM
rwinner, thanks for your comment. First off I did put the shroud on the vortex block, Its lying next to it in the pic for clairity. Other than that all of the PVC I used ARE stamped with the psi rating, and I guess your just better than me!
knexer1 in reply to IanmanApr 14, 2007. 7:33 PM
Thats true, all of the schedule 40 pvc pipe that I have seen is rated to at least 400 psi.
Ianman (author) in reply to IanmanApr 2, 2007. 9:13 PM
Also an air compressor IS nessary because any air tank is a major pain if you have to drive down the gas station to fill your tank with air every 2 min worth of shooting. And remember folks, If there is a constant airflow through any chamber, it will only reach less than half of the PSI applied unless you stick your finger in the end of the barrel and apply pressure.
irwinner in reply to IanmanApr 3, 2007. 10:25 PM
ill admit the 5 gallon tank is a pain in the a$$ to lug around but the gun is insane, the equivalent to having a Gatling shotgun, sure i can only fire for few min straight but the guns fire rate is worth it. i can get around about 3000 rounds off on one 115psi tank (and still have 40 psi left). and i can refill the tank with a bike pump a 5lb co2 setup is much better you can get 25000 to 30000 rounds off in one tank (regulated to 110psi) the tank and regulator are about 15 lbs and can easily fit in a back pack. i believe i know why your RoF is much lower than mine, it seems you used a 2" chamber, mine is 1.5". so because there is a smaller area to pressurize the pressure increases and the bbs can shoot harder/faster i do have to admit your gun looks ALOT nicer than mine, but you should seriously consider a co2 setup, a gun like this on an airsoft field is unstoppable
bigal77 in reply to irwinnerJun 11, 2008. 7:26 PM
Would u recomend a specific type of regulator?
Ianman (author) in reply to irwinnerApr 14, 2007. 8:06 PM
Thanks again for the comments and compliments! I do have a question though.... Are metal bb,s allowed on an airSOFT field? If so I could really piss off some people when their kids go to the hospital. HEHEHEHEHEHE ( snide grin; pinky on lip) Because this doesnt shoot those plastic ones.
irwinner in reply to IanmanApr 15, 2007. 6:25 PM
sorry but their is no way they would ever let you on an airsoft field with metal bbs, cause they could be held responsible for anything stupid you do, and with the way modern America works they will get sued. the short answer no
Ianman (author) in reply to irwinnerJan 7, 2009. 9:58 PM
You really understand scarcasm dont you!
irwinner in reply to irwinnerMar 31, 2007. 10:49 PM
you can check it out on my website
http://home.comcast.net/~irwinner/airsoft.html
brookech in reply to irwinnerOct 30, 2007. 6:50 PM
Awesome dude. thanks for the info much easier to under stand than burntlatke!!!!!!!!
Ianman (author) in reply to irwinnerApr 2, 2007. 4:09 PM
Looks just the one from burntlatke.com. but I dont remember the electrical tape on the handel. I got the Idea from the same place too, I just tried to improve upon the asthetics a bit, along with the construction. Thanks again.
Vertigo666 in reply to IanmanMar 31, 2007. 10:14 PM
hmm... 10-15 p/sec... 10x60...15x60...400/60...NICE! my stock P-90 full auto is 400 p/minute
bruce911 says: Nov 19, 2007. 2:09 PM
Whn will you be done with the construction process?
Ianman (author) in reply to bruce911Nov 21, 2007. 10:28 AM
Its been done, theres a vid on here too.
bruce911 in reply to IanmanNov 21, 2007. 3:03 PM
Where do you get the Blowgun trigger handle thingies.
MisterHankie in reply to bruce911Jul 8, 2008. 3:42 PM
You can buy the blowgun from a hardware store.
Nitornos in reply to MisterHankieSep 7, 2008. 11:30 AM
Jeez, seems like you have to get everything on an instructable from a hardware store.
Ianman (author) in reply to bruce911Nov 22, 2007. 5:38 AM
If you have to ask, you dont need to build one of these.
xxaaron1015Xx says: Aug 19, 2008. 5:13 PM
I know how to make a extremely powerful be gun for only $2 i live in nsw (Australia) and there banned so 1 day i got bbs and i was bouncing em they landed in the barrel of 1 of my bros toy guns so tried it and i can fire it with high possibility of hitting. as i set up red bull cans and shoot i can get up to 20m away and still nail em. contact me if you wish 2 know how to make :D
Ianman (author) in reply to xxaaron1015XxAug 21, 2008. 4:12 PM
Good for you, lay off the red bull.
purpledog22 says: Aug 17, 2008. 7:56 AM
dude soooooo cool can u tell me like all the pieces like everything plz????????????
Kainon03 says: Aug 14, 2008. 1:29 AM
i want to build this but i am wondering what exact fittings you used and what type of tubeing and where you got it. thanks
xxaaron1015Xx says: Aug 12, 2008. 4:40 AM
can u add a detailed instruction on Instructables like how long what pieces glue or what material to make barrel and vortex as my dad is a electrical engineer and owns a business (cnc teknix) I can make the vortex with ease but i need length or the pvc piping add me on msn or just message me on here if u want to add me on msn contact me in email over instructables
hvac2010 says: Aug 3, 2008. 9:00 PM
I'm confused...wuts the point of the vortex block?...couldent you make a more powerful gun by having a strait barrel with the air coming from the back and BBs just falling in a hole in the top of the barrel?
Ianman (author) in reply to hvac2010Aug 4, 2008. 7:28 AM
Without the vortex block, the bb's would just jam up very easily, it keeps them spinning and in line to go out the barrel. Also, if you tried to drop bb's into a pressurized tube "From the top" as you stated they would be blown away and never go into the tube in the first place. Hope this helps.
maxidk8000 says: Aug 1, 2008. 12:59 PM
i still need to know where the brass fittings go can you show me where exactly? i have everything else though
Ianman (author) in reply to maxidk8000Aug 1, 2008. 2:08 PM
the only fitting you cant see goes into the base of the V-block, through the bottom of the rounded pvc cap.I used one like this...just get the size you need.
avwos says: Jul 1, 2008. 10:09 AM
(removed by author or community request)
Ianman (author) in reply to avwosJul 1, 2008. 5:38 PM
No.
legokevin360 says: Jul 18, 2008. 4:46 AM
when i figured this out THIS IS BEST BB GUN EVER all my friends are jelus that i have a bb gun like this!
MisterHankie says: Jul 8, 2008. 3:48 PM
You know the pipe on the top of the gun with the awesome paint job? Is that just extra space to put more BBs in?
Ianman (author) in reply to MisterHankieJul 17, 2008. 8:30 PM
Nope, its empty. Holds a maglight though.
MisterHankie says: Jul 8, 2008. 3:53 PM
What sort of mechanism did you use to distribute the air to the barrel and the vortex block?
Ianman (author) in reply to MisterHankieJul 17, 2008. 8:29 PM
That is a blowgun.
legokevin360 says: Jul 8, 2008. 7:28 AM
aculy this is great
Dr. Explosion says: Jun 17, 2008. 11:20 AM
This is awesome
bigal77 says: Jun 11, 2008. 1:02 PM
What kind of blowgun did u use on your gun?
Ianman (author) in reply to bigal77Jun 12, 2008. 10:41 AM
Just what home depot had cheap.
bigal77 in reply to IanmanJun 12, 2008. 11:09 AM
thanks, But what is the barrel length (top "barrel too) and diameter, and if u had the materials and machines could u make the block out of metal (aluminum), one last question, could that blow gun hold up to the pressure of a co2 tank? thanks sorry for being a bother
legokevin360 says: Jun 11, 2008. 4:56 AM
It doesnt work!
Ianman (author) in reply to legokevin360Jun 11, 2008. 5:22 AM
Then you did something wrong, nice comment.
Wingmaster700 says: Apr 30, 2007. 11:58 AM
did you use a hop up and how did you plug the suppoprt barrel to keep air from flowing Sry for so many questions, it's an awsome project
JamesRPatrick in reply to Wingmaster700Oct 28, 2007. 12:09 PM
I hate when people mistake BB for airsoft. It drives me nuts. Hop up is not necessary with metal projectiles.
Wingmaster700 in reply to JamesRPatrickMay 16, 2008. 4:09 AM
sry, just asking a question. is it against the law
gotja in reply to Wingmaster700Sep 22, 2007. 7:32 AM
this is a bb gun and adding hop up is basical making a back spin if u do it with a bb gun it will destroy the hop up and bbs are much heavyer than arisoft bbs so it doesnt need hop up cuz it has momentum to mak it go straight (i think there some rifled bb/pellet guns though like a real gun)
_soapy_ in reply to Wingmaster700Sep 9, 2007. 2:42 AM
It's not hop-up, that's airsoft. This is a BB gun.
Ianman (author) in reply to Wingmaster700Apr 30, 2007. 12:02 PM
I dont know what a hop up is, but the end of the trap where the upper barrel comes out has a thick piece of lexan JB welded and siliconed inside.
Wingmaster700 says: May 14, 2008. 5:39 AM
I built one just recently and im wondering if you can attach a paintball tank to it
denver22299 says: May 12, 2008. 5:43 PM
dud found out never mind can u post plans
denver22299 says: May 11, 2008. 5:12 PM
dud nice but i dont get how the bb go down the barrel wouldnt the air leak out of the barrel
willstab says: Apr 18, 2008. 7:01 AM
can i try to mini size the the whloe pvc vortex tude and use 1" instead og 2" cuz im planning to make one and make it look like a Dragunuv sniper rifle
joeliolyijr says: Apr 4, 2008. 7:20 PM
would you be willing to sell the vortexes
Ianman (author) in reply to joeliolyijrApr 11, 2008. 7:06 PM
I accept paypal and would need specific dimensions on your application's requirements.
joeliolyijr in reply to IanmanApr 11, 2008. 8:26 PM
ok how much would u chart for one
Ianman (author) in reply to joeliolyijrApr 11, 2008. 9:56 PM
That depends on your specific dimensions on your application's requirements. In other words, do you need a taylor made block; or something to build a gun around? And if you meant charge, email my account.
willstab says: Apr 11, 2008. 5:47 PM
want materials can i make this out of, i have alot of wood lying around so i could make it out of that but im worried that the bb's will wear out the vortex (if i use airsoft pellets will it last longer???)
Ianman (author) in reply to willstabApr 11, 2008. 7:09 PM
Read the instructable. Or have someone read it to you. I would do it, but I would still be typing words. So sorry.
Enzo55 says: Aug 26, 2007. 3:59 PM
I´ll make one. But hey, how much psi can it go up to?? And a nother... Lets say that i where to sell a couple of these, what price do you think i could put on them, selling them to people that have never owned an airgun before. And how much does it cost to do this gun??
hackgeek in reply to Enzo55Nov 1, 2007. 5:09 PM
hey if you sell them your braking the law cuz this gun has already been made, and sold at
http://www.pipersprecisionproducts.com/videos.htm
but i doubt your gunnu get cought unless someone rats you out. but im not gunnu
grenades_and_ham in reply to hackgeekMar 28, 2008. 2:13 PM
so unless they have a copyright or patent on the design its not protected. plus you can make a cloud chamber less pieces and more reliable. because vortex blocks DO WEAR DOWN AND FAIL!!!
Ianman (author) in reply to hackgeekNov 11, 2007. 8:34 AM
Sorry to sound so bitchy, but THIS gun has not been "already" made, this is my design, the only thing not original to me is the vortex block which I learned from Burntlatke.com.
Ianman (author) in reply to Enzo55Aug 27, 2007. 7:52 AM
If you sell any of these your asking for trouble, as soon as someone gets hurt, you can be sued!!!!!!!!!
cowscankill in reply to IanmanSep 3, 2007. 11:57 AM
not if he makes them sign a paper saying he's not liable for damage done to people or property
clare4668 says: Jan 9, 2008. 3:12 AM
i will pay you to make me one, will you make me one and post it to me. I will pay $550 for one plz!
rownhunt in reply to clare4668Mar 14, 2008. 8:41 AM
make ur own it's easy plus u can get a real rifle for 550 bucks
thoraxe in reply to clare4668Feb 24, 2008. 1:00 PM
u could get a professional one for less dude.
Ianman (author) in reply to thoraxeFeb 24, 2008. 2:16 PM
Where? Thats what I thought.
Ianman (author) in reply to clare4668Jan 9, 2008. 3:28 PM
Cash up front. and it may take some time....
rownhunt says: Mar 14, 2008. 8:34 AM
good iam putting on my fav list cos want to make a barrel smaller so i can shoot bb and pellets thank you
jdavi303 says: Feb 2, 2008. 5:47 PM
hey can u send me the plans when u get them at edwijal@hotmail.com
Ianic says: Jan 10, 2008. 4:42 PM
What is the air supply cauze i noticed on your link it had one but urs doesn't. Where does the air come from?
Ianman (author) in reply to IanicJan 10, 2008. 6:30 PM
An air compressor.
Ianic in reply to IanmanJan 11, 2008. 12:43 PM
how big is urs? Could u use a c02 cartrige?
Ianic in reply to IanicJan 11, 2008. 12:44 PM
cartridges*
Ianman (author) in reply to IanicJan 11, 2008. 2:33 PM
I have a 15 gal a/c. I doubt you could use the small cartridges for bb guns cause of the lack of constant airflow. Possibly a co2 tank for a paintball gun, but that would get expensive really quick. You could get a air carry tank and refill it at the gas station if you don't have access to a real air compressor though.
Ianic in reply to IanmanJan 11, 2008. 6:22 PM
What would be the easiest though? I have tried multiple things and a bike pump just doesn't cut it for an automatic. Also did you spray paint the gun black?
Ianic in reply to IanicJan 11, 2008. 6:28 PM
or maybe even a portable airsource?
Molybdenum says: Jan 5, 2008. 4:57 PM
you say its a hard build, but you haven't bothered to explain the build process very much. the concept could easily be used for airsoft or any othe caliber (i dont know about paintball) so I dont see why its so important that its not airsoft.
brainspater says: Dec 30, 2007. 1:05 PM
Dude I got a grate idea that you may like, but you need a long steal tube.
James (pseudo-geek) says: Jul 19, 2007. 3:16 PM
ahahahaha I'm gonig to build one and put a silencer on it too but could you explain in further detail how to build the vortex chamber?
steven123654 in reply to James (pseudo-geek)Dec 5, 2007. 4:59 PM
well go to burntlatke .com and lanman does this gun work good because i saw like year ago and i was thinking of making it but i never knew if it was any good
gotja in reply to James (pseudo-geek)Sep 27, 2007. 5:48 PM
dude if you get caught by the cops with the silencer and it works on a real fire arm ull get sued and jailed(dont think thats a word though)
James (pseudo-geek) in reply to gotjaNov 24, 2007. 1:18 PM
I looked that law up. its perfectly legal to own a silencer for a firearm, just not to USE it. anyhow this isn't a firearm so its perfectly legal.
JordanZed in reply to gotjaOct 27, 2007. 12:13 PM
I doubt a silencer made for a PVC BB gun would work for a real firearm lol
Hawaii00000 in reply to JordanZedOct 28, 2007. 1:31 PM
Dangerous!! and probably illegal. Be carefull where use this as the police can shoot at you just for carrying it around. And again its probably illegal.
James (pseudo-geek) in reply to Hawaii00000Nov 24, 2007. 1:18 PM
gotja in reply to Hawaii00000Oct 29, 2007. 6:37 AM
its perficaly leagle and jordanzed even if it only silences one shot for a real gun (i dought it would work) its still considered a sound supresser or a silencer
Ianman (author) in reply to James (pseudo-geek)Jul 19, 2007. 5:07 PM
James (pseudo-geek) in reply to IanmanJul 19, 2007. 8:52 PM
I looked there, I need more exact details. how wide does the chamber need to be.
wblac1 says: Dec 2, 2007. 5:54 AM
looks like two air lines, can you send a break down of this? thanks,
Ianman (author) in reply to wblac1Dec 2, 2007. 7:54 AM
Just one airline, from blowgun thru handle and into bottom of vortex chamber. The black thing you see is the wire to the laser sight.
wblac1 in reply to IanmanDec 2, 2007. 3:14 PM
steven123654 says: Aug 18, 2007. 12:32 PM
yo u stoll this off burtlake.com but they have better intruction
Ianman (author) in reply to steven123654Aug 18, 2007. 1:30 PM
Steven123654 you are a real genius!!!! I have linked burntlatke.com (not lake) in my instructable as a source, as well as stated thats where I got the idea from and improved the look. And you may want to look for an instructable on spelling words, let me know if you need help with that. LATA
James (pseudo-geek) in reply to IanmanNov 24, 2007. 1:22 PM
don't you just love it when people don't read what you write throughly and then complain to you about it?
mindkiller213 says: Nov 23, 2007. 12:08 AM
nice job bro can I get me more detailed steps to making one of this like how to make the vortex block and such?
sackables says: Aug 15, 2007. 10:38 PM
i went to burnt lake or whatever and i was wondering if they glued the vortex block to the 2" cap or screwed it? If i ask for a 1/4"x1x8"NPT brass fitting or a 1/4 brass compression fitting will they have them?
yomama1800 in reply to sackablesNov 22, 2007. 8:13 PM
i went to lowes and holy crap they have everything you need i spent 25 dollars and it works great make sure u use plumbers putty it works best and dries faster oh and don't use wood unless u have a 3d drill auger which is rare so yah
Ianman (author) in reply to yomama1800Nov 22, 2007. 8:19 PM
awesome, Send me some pics!!
_soapy_ in reply to sackablesSep 9, 2007. 2:40 AM
You could ask them. I'm not sure they hinge their lives on your every word here in the same way we do...
Sergeant Dotson says: Nov 22, 2007. 8:21 AM
Very nice, looks hard to make though...
nerfer192 says: Nov 4, 2007. 1:43 PM
you should make it c02 insted of lugging around an air compressor
thedude2111 says: Nov 3, 2007. 11:54 PM
just dont pressurize or load them and do 1 of those 18 or older only thinggs
thedude2111 says: Nov 3, 2007. 11:52 PM
yo i need 2 get 1 of these they look gangsta and i thought u should make a few and sell em on ebay. ps its legal cause burntlatke doesnt have a copyright
lewisbirch says: Oct 31, 2007. 12:57 AM
awesome
HALFSPOOL says: Oct 30, 2007. 7:58 AM
yeah, dude that's pretty sick
Ianman (author) in reply to HALFSPOOLOct 30, 2007. 5:57 PM
Thanks!!
gotja says: Sep 27, 2007. 5:42 PM
hmm you can probibly cange it into an airsoft gun realy easly
DerMaverick says: Aug 24, 2007. 5:37 PM
I built one, took me hours to make my vortex block even, smooth, and have all the holes lined up, yet, my bb's only go about 10 feet with a 90 psi output. My barrel is much bigger than the bb's but i tried with airsoft to the same effect. My design is different because in the 2" 'T' section I mounted it so the vblock was in theshaft andthe top of the block touching the top of the 'T' If any one has any ideas about what's wrong or needs pics send me an email ellipticme@hotmail.com
Ianman (author) in reply to DerMaverickAug 25, 2007. 4:05 AM
First your barrel needs to be just big enough for the bbs to come out, you are losing alot of back pressure there. Also having the v-block so high inside the T, not enough bbs are able to get into the inside of the v-block. Hope this helps.
Ianman (author) in reply to IanmanAug 25, 2007. 4:07 AM
PS, even though the airsoft may be closer to the size of the barrel, they are much lighter than metal bbs, so they will just blow around inside the chamber.
knightlord454 in reply to IanmanSep 9, 2007. 10:37 AM
if you want an upgrade on your design email me my address is spidrkilr5.0@hotmail.com
shooter1 says: Aug 25, 2007. 3:42 AM
Where do you load the bb's
Ianman (author) in reply to shooter1Aug 25, 2007. 4:02 AM
The drain cleanout in the back of the t unscrews
ghost2human says: Aug 19, 2007. 4:19 PM
is it possible to add something on the inside of the vortex block to have a better shooting rate?? since right now, the air blows up and the BB's follow the curve eventually going in to the barrel right? But if you add something like a V shaped piece guiding the bb"s into the barrel wouldn't that be better. And also how fast does it go . ( in FPS pls)
Ianman (author) in reply to ghost2humanAug 19, 2007. 5:32 PM
I put a shroud around the v-block to help keep the weight of the bbs from jamming inside the block, otherwise i have not had a prob with them not wanting to go out the barrel because the v-block creates a venturi effect taking any matter(bbs) with it. With the other question, i have no idea on the feet per sec. I hope this helps??
ghost2human in reply to IanmanAug 19, 2007. 5:41 PM
.......whats a shroud??
Ianman (author) in reply to ghost2humanAug 20, 2007. 7:23 AM
This is a shroud.
C:\Documents and Settings\Compaq_Administrator\My Documents\My Pictures\shroud.jpg
sackables says: Aug 15, 2007. 1:31 AM
how would you hook your air supply to the blowgun if i were to use a 20oz tank of co2 as the source
Ianman (author) in reply to sackablesAug 15, 2007. 9:38 AM
I would take the tank to a hardware store and find the fittings to match them up, if you need help, ask someone who works there.
sackables in reply to IanmanAug 15, 2007. 11:03 PM
hhmmk
shooter1 says: Aug 13, 2007. 8:07 AM
Good idea i love this gun.
Mr Tenacious says: Jul 15, 2007. 10:02 AM
do u know if there is any way u could have the vortex block put in a nerf gun or airsoft gun?
Ianman (author) in reply to Mr TenaciousJul 15, 2007. 1:25 PM
If your crafty enough! Just make the block the size ya need, if you want send me a pic of the gun in question and ill try to help!!Lata
Wingmaster700 says: Jun 9, 2007. 1:25 PM
Does anybody think a CO2 paintball tank will work. I dont know too much about paintball but do you think you can hook up a hse from the ASA fitting on the tank to the end of the air gun
Ianman (author) in reply to Wingmaster700Jun 9, 2007. 3:48 PM
I think it would work, but if your using air in the tank, it prob wouldnt last but a few sec, co2 would have more psi and last a bit longer.
ceobeeswax says: May 10, 2007. 3:49 AM
what were the measurements on the vortex chamber??
Ianman (author) in reply to ceobeeswaxMay 15, 2007. 1:21 PM
see link on page, here it is again..........http://www.burntlatke.com/bb.html
BOMBOMBOMB says: May 6, 2007. 6:59 PM
and i also forgot.. i was reading ur replies and soemone mentioned abut how much u said cost bla blah blah cause of brass fittings... I didnt here anythign botu brass fittings in ur instructable and thats sayign something. sorry if thsi sounds really mean but its more constructive critisim but nice job aye got me intruged cheers nato
Ianman (author) in reply to BOMBOMBOMBMay 15, 2007. 1:19 PM
Section one of the instructable is were I mentioned the brass fittings, I didnt specify exactly what I used because you may not be able to find all of them and will have to substitute and come up with something on your own that gets the job done.
ceobeeswax in reply to BOMBOMBOMBMay 10, 2007. 3:48 AM
true!! hey what
BOMBOMBOMB says: May 6, 2007. 6:55 PM
Hey nice instructables but if u wanted oe of the bad asses instructables on instructables id redo it with step by step construction much easier to understand and include ur paintjob its sick... im just nto too clear on the T bit like hwo the caps on each end are setup..... anyways u really should redo this with step by step instructions!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! cheers nato
Wingmaster700 says: May 5, 2007. 2:18 PM
hop up helps put spin on the bb so it doesn't sink in the air
ac1D says: May 2, 2007. 9:34 PM
I dont think they are accepted in a airsoft field, a metal bb would do too much damage! (shoot one in your hand)
I made one that look almost the same, exept it shoot plastic one. i used these small CO2 bottle they are selling at STAPLES
(here)
It work pretty good, shoot really quickly ( around 30/secondes ) and is accurate.
Jonno says: May 1, 2007. 5:38 AM
Nice work man..
knex hater hater says: Apr 30, 2007. 8:59 PM
holy crap dude. how much money did u spend. i personaly wouldnt make this and just buy an electric one for just 30 thats full auto. I mean it would look like crap next to this badass gun but idk if people are gonna build this. well you just never know. nice job.
kinghack says: Apr 21, 2007. 9:30 PM
hay man i live in australia do u know were i can buy a bb gunthingy i have wanted for ever of a website 2 buy dem thanx nice dedign can u please explain the vortex block 2 me a bit clearer in detail
Mad Cat in reply to kinghackApr 27, 2007. 4:46 PM
You can't buy them here. They're kind of illegal. I got mine from Europe.
Wingmaster700 says: Apr 27, 2007. 12:00 PM
Hey, what did you use as an air source
Wingmaster700 says: Apr 19, 2007. 6:59 PM
About How much did this cost
Ianman (author) in reply to Wingmaster700Apr 19, 2007. 9:35 PM
To sum up both of your questions, I spent about US $50 on the parts, the majority of it on the brass fittings and PVC cement/primer.Not to mention the old BB rifle I already had; and the vortex block was made from bondo, I linked the site i learned that from in the instructible, but here it is again.........http://www.burntlatke.com/bb.html
Thanks for your comment, let me know if I can help any more!!!!!!!!!!!!!
Wingmaster700 says: Apr 19, 2007. 7:17 PM
waht did you make the vortex boout of.
DIRTYSHOTZZ says: Apr 18, 2007. 8:52 AM
YOU ARE A TOTAL LEGEND Since i live in australia wee have very high restrictions on weapons of any sort but i make my own guns n stuf ill make it then tell you the rest
Ianman (author) says: Apr 14, 2007. 8:09 PM
Sorry for the confusion, this is not an air soft gun. It shoots REAL metal BB's.
yofooshitter says: Apr 11, 2007. 7:11 PM
hey thats awesome ive already made a gun like this out of a potato gun n using straws as the barrel but they always rip even though i could shoot airsoft through plywood. where did u get your barrel?
yofooshitter in reply to yofooshitterApr 11, 2007. 8:37 PM
do u kno where i can get a barrel for cheap cuz i checked airsoft websites and they cost like $50
Ianman (author) in reply to yofooshitterApr 11, 2007. 8:53 PM
My barrel came off an old bb gun, but you could try a hardware store and try to find some aluminum tubing, or try a salvation army or yard sale for an old POS bb rifle.
Whaleman says: Apr 9, 2007. 5:19 PM
wht size bb does it shoot? 6mm, 4mm....
Ianman (author) in reply to WhalemanApr 9, 2007. 5:36 PM
Sorry I didnt specify, It shoots METAL 0.177 inches (4.5 mm)BB's., I have never owned an airsoft, but I think those would be too big.
Whaleman in reply to IanmanApr 9, 2007. 9:03 PM
thx
knexpro7 says: Apr 6, 2007. 7:44 PM
gunmanx says: Apr 4, 2007. 6:09 PM
lol i can hear in the back round ur listing to baracuda - heart lol i lovve tht song
knexer1 says: Mar 31, 2007. 4:44 PM
This is amazing!!!!! I have already built something similar to this for airsoft, but this is just incredible!!!!!! Nice work
Ianman (author) in reply to knexer1Apr 2, 2007. 4:03 PM
Thanks, If you need any help along the way, feel free to ask!
knexer1 in reply to IanmanApr 3, 2007. 8:49 PM
actually I just finished buying the parts on sunday and built it on monday, but i still need a few parts for my air compressor (an air filter and a universal coupler) and it will take me a while to save up enough money, but i'm pretty sure it will work, but thanks for the offer.
wingman246 says: Mar 31, 2007. 5:09 PM
about time this instructable came along, I HAVE to make one of these
Ianman (author) in reply to wingman246Apr 2, 2007. 9:14 PM
Let me know if I can help!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
