3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
BB Machine Gun(NOT AIRSOFT!!!!!)
Step 3The gun
The gun
With this gun you can make your own design or copy mine.
Cut all of your pvc out and dry fit before gluing together with pvc cement.
The butt of the gun is attached with a long bolt with rubber washers inside of the drain to prevent air leaks. And a bondo spacer to match the parts shapes together.
I attached the blow gun using plumbers tape.
I will be adding to the actual construction process soon!
7 comments
Jun 9, 2010. 9:11 AMBilly mahony says:
Does anyone have any ideas on running this off a CO2 tank, Making it more portable.I have no idea on how to regulate the flow? pressure, any help would be great.
Jul 4, 2010. 1:28 PMguitarmonk15 says:
Do you mean running it on something like a co2 bike tire inflator? Because I had that EXACT same idea. I'm guessing it would work pretty well, but I have never tried it.
Jul 24, 2010. 11:43 AMBilly mahony says:
I was thinking something slightly larger (Paintball tank) but yeah, annything light and portable, how fast do you think the flow is on a tire inflator, my guess is pretty low, but it should work.
Oct 16, 2010. 12:26 PMdla888 says:
Get a CO2 regulator. Look on amazon, or ebay.
Dec 4, 2008. 9:02 PMlogann2292 says:
This interesting. I am currently doing a project, and this is alot of help. I'm trying to use this same idea, but have a revolving quad barrell system. I think I am going to try to use one air compressor, and 4 vortex blocks, as I have a big air compressor, but I'm not sure if its possible with the vortex block being upside down at some point, and the big pvc drain tap. Any ideas anyone? Thanks.
Dec 5, 2008. 12:32 PMlogann2292 says:
Actually, what I think I'm going to try to do is drop the revolving barel idea. I'm going to made the vortex a little bigger, and drill 4 holes for 4 barrels into the vortex. I have a powerful air compressor, so it should be fine. You think this will work?
Nov 19, 2007. 2:09 PMbruce911 says:
Whn will you be done with the construction process?
Nov 21, 2007. 3:03 PMbruce911 says:
Where do you get the Blowgun trigger handle thingies.
Jul 8, 2008. 3:42 PMMisterHankie says:
You can buy the blowgun from a hardware store.
Sep 7, 2008. 11:30 AMNitornos says:
Jeez, seems like you have to get everything on an instructable from a hardware store.
Nov 23, 2007. 12:08 AMmindkiller213 says:
nice job bro can I get me more detailed steps to making one of this like how to make the vortex block and such?
Oct 30, 2007. 7:58 AMHALFSPOOL says:
yeah, dude that's pretty sick
May 1, 2007. 5:38 AMJonno says:
Nice work man..
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:Ianman
