3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
BBQ Ribs low and slow on a smoker
I will show how to do Spareribs on a smoker, from removing the membrane, adding a rub, and how long to cook them.
What you will need:
A BBQ Water Smoker (or charcoal grill set up for indirect grilling)
A Rack of spareribs
Yellow Mustard
1 cup paprika
1 cup chili powder
1/2 cup kosher salt
1/4 cup onion powder
1/4 cup garlic powder
3 TBL granulated sugar
1 tsp Black pepper
1 tsp Cayenne pepper
1 TBL molasses
Charcoal
Lighter Fluid
3 cinder blocks
water
Step 1Removing the membrane from spareribs
Please don't skip this step. Covering the bone side of the spareribs is a thin translucent membrane. Low and slow cooking can do a lot of things, tenderize tough meat, change cartilage into a lip smackin goodness, but there is nothing that can be done with the membrane covering the ribs except remove it. It also prevents flavors from being absorbed into the meat.
Start in the valley between the last 2 ribs. Take a small pointed tool such as an ice pick, or the tip of an instant read thermometer and insert it between the meat and the membrane. Work the two apart until you can get a finger in there. You should have a good piece loose at this point. Grab this with a dishtowel or paper towel which gives you abetter grip and pull. The membrane will come off. Most times only half comes off, and you'll have to go back and take the balance off. This takes a few minutes but is well worth the trouble.
20 comments
Jan 27, 2012. 7:58 AMcookin fool says:
the rub is an awesome combination of ingredients. I will be trying it soon. I can already taste it.I agree with removing the membrane although some chefs are now leaving it on claiming it holds in moisture. To each their own right.
Aug 6, 2009. 7:16 AMrein365 says:
One good way for BBQ ribs is to wrap them in aluminum foil. Then let them cook about 45 - 60 minutes. For nicer look just 30 sec on high heat BBQ without foil. If you get to choose ribs, pick the ones with thinner bones. That means the animal was younger and meat is better.
Oct 20, 2010. 6:03 PMrprough says:
If your gonna use the foil method, also known as the "crutch", add a cup of apple juice in the foil. This will mix with the fat and dry rub drippings making an awesome juice. Add some maple syrup and a little water to this juice and simmer and reduce to one third and use this to brush onto the ribs for the last 15 minutes or so of cooking. All I can say is awesome!
Jul 3, 2010. 11:33 AMfroggi says:
The yellow mustard you use in this step, is it English mustard or the stuff we call American burger mustard (much milder and sweeter it has to be said)
Sep 2, 2009. 7:09 AMDebbieP817 says:
These RIBS taste great....I know for a fact he has cooked them for me before... Love Ya Michael
Aug 24, 2009. 7:54 AMtonyc says:
Great looking BBQ Ribs........................this is the winner.
Aug 20, 2009. 6:29 AMcigarsandscotch says:
Wow, awesome
Aug 14, 2009. 9:57 PMbaxterdog says:
To reinforce what the writer is saying; Put the meat bone side down. This applies to ribs or chicken. This allows the skin/fatty side to drip down.
Aug 14, 2009. 9:47 PMbaxterdog says:
Most people forget this step! Do this and your guests will, unknowingly, be very appreciative you did!
Aug 11, 2009. 9:25 AMremovesstains says:
Sweet, I made ribs last Friday on my modified ECB Smoker. I used way to much cumin in the rub recipe i used. this was my 1st time smoking ribs and i learned that cumin is gross and over powering. Never again. I'll try your rub recipe next time but leave out the chili powder and use crushed red pepper instead. I should do a how to on modifying the brinkmann smoker. Adding a vent on the lid is extremely easy. i did all my mods for around 20 bucks.
Aug 7, 2009. 9:37 AMRicardo Furioso says:
Where does the smoke come from?
Aug 5, 2009. 8:53 PMbranonls says:
Looks pretty good.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:Mhbaben
