Propane/NG Disclaimer
Site Disclaimer
This instructable is for informational purposes only. It is not intended to be an instructional medium of any type. Nor is it intended to be an authority regarding safety or regulatory issues. It is not intended to be a guide for safety or security. This instructable is designed to introduce current and prospective users of propane to common issues in the use of propane and as an explanation of how propane tanks, LP/NG Gas parts, related appurtenances operate and what their purpose is. Using this site as a guide for diagnosing problems or attempting to fix propane related problems is, under no circumstance whatsoever advised or recommended. Only licensed propane companies and/or LP Gas plumbers are to diagnose and make repairs. This site assumes no liability as it is intended for educational and informational purposes only.
I do not endorse any particular safety procedure or policy but rather endorses the practice of overall safety and common sense regarding all aspects of propane/NG and its properties. This site is not intended for "do it yourself" consumers or as a guide for unlicensed propane plumbing activity. It is published solely as a resource for people seeking information about propane and to better understand the activities that licensed propane companies, installers and plumbers are engaged in.
Photography and Content Disclaimer
Be aware that safety rules and regulations vary among states and jurisdictions. Although the nationally recognized standards of NFPA 58 and NFPA 54 govern the propane industry on a national level, independent states, counties, cities and locales often have their own rules and regulations concerning LP/NG Gas and propane. The content within this site, along with the pictures depict an overall view of safety as an exhibit. The content and pictures within this instructable are not intended as a guide, but rather as an exhibit. Rules and regulations reside with individual states and local jurisdictions, not with the contextual or photographic depictions within this site.
Remove these ads by
Signing UpStep 1Parts Needed
1) 3/8 NG hose and a needle valve to adjust the flame size. I use brass 45deg flair fitting for the hose ends and the attachments at the BBQ and house.
2) Fire ring/bar. This is the distribution system that is below the grill for your gas. If you have the ability to weld and make rings you can make your own using a 1/2 weldable (not cast iron) coupler in the center, 5/8 thin wall tubing for the ring and drilling 3/32 holes every 1 1/2". The ring should 1/2 - 1/3 the size of your BBQ container diameter.
Stainless steel will prolong the life of the ring especially during the winter when you forget to cover your BBQ in the first rain. I've heard of people using copper too.
3) BBQ Fittings: A 1/2 NPT brass bulkhead coupler and 1 1/8 lock nut, or a 1/2 weldable steel coupler, Brass1/2 to 1/4 reducer, 1/4 street 90, neddle valve, 45 deg flare (for attaching the hose to)(not used in this build), brass 1/2 NPT nipple (to attach the the ring to the coupler welded to the container)(not used in this build).
4) House Fittings: all brass; 3/4 to 3/8 reducer, 3/8 street 90, 3/8 nipple, 3/8 ball valve, 3/8 to 45 deg flare for attaching hose to BBQ.
For Propane:
1) Regulator/hose 1-30 PSI (not a BBQ regulator, too small) and a needle valve to adjust the flame size. I use brass 45deg flair fitting for the hose ends and the attachment at the BBQ. BBQ propane tank. You will need a venturi if the propane flame is too smoky.
Alt.: Home Depot sells replacement BBQ parts. Buy the reg, hose, burner and install in your charcoal grill.
I've put together an affordable kit of the basic plumbing supplies you'll need to build a fire pit. This kit could be used to build a BBQ as well.
I offer several sizes of rings, stainless upgrades and fully auto systems for high end remote controlled fire pits.
Fire Pit Kit link
for more info.
I use pink, yellow and white. White is thinner.
I like to use a small bit of pipe dope along with the tape.
