3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
BBQ conversion to Gas
Step 2Make a hole
Make a hole
1) The fire ring/bar should be 4-8 from the grill. Closer will give you hot spots and farther will even out the heat. I chose 5 so I could have hot spots for the meat and veggies could cook slower on the sides.
2) Locate and mark the hole for the bulkhead fitting on the BBQ, then center punch. Make sure you are center punching with a hard object backing up the other side. if you don't your mark will be too light and you risk just making a big dent. Now using a hole saw on a drill, make a 1 1/8 hole. if you find the bit wandering off center go back and make a better center punch. Stainless steel is very hard and lots of pressure is need to get it started.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
115
Author:jonsarriugarte
