Step 3Add the plumbing
Alternates methods of plumbing the gas though the container for thicker materials:
Bolt on flange - great for thick material. Make sure to use a high temp silicon sealer to make sure there are no leaks. see attached photo
Weldable couple r- The best solution, but you must be able to weld.
Now attach the hose/regulator using the 45 deg flare fitting on the end of your hose.
Add Comment
