This berry patch belongs to a neighbor. I plan to grow some at my house on rebar trellises, for easier maintenance and harvesting. See my trellis instructable when you are done with this one: http://www.instructables.com/id/A-REBAR-TRELLIS-for-Home-and-Garden/
Also, for further PVC working inspiration, see my instructable: http://www.instructables.com/id/PVC-Its-Great-for-Inventions/
Step 1: Safety
Vinyl Chloride, one of the components of PVC, is carcinogenic. When it is locked up in the polymer, however, it is much safer to be around. In my years of experience working with PVC, I have not noticed any adverse effects on my health from being around it.
Always work in areas with good ventilation. If you do get caught in a cloud of smoke, hold your breath and move to clean air.
When heating PVC with a gas stove or propane torch, try not to let it burn. Smoke from burning PVC is bad. With experience one burns it less and less. Don't panic the first time you do burn some. It scorches, but doesn't immediately burst into flame. Move the material away from the flame and try again. Don't breathe the smoke. Smoke avoidance comes naturally for most people.
While heating PVC over a gas flame, keep the plastic an appropriate distance from the flame. Avoid scorching the surface before the inside can warm up. It takes time for heat to travel to the center of the material being heated.
Keep the plastic moving, and keep an eye on the state of the plastic. When heated, the PVC material is flexible, like leather. Beyond this stage, you risk scorching it.
A word from James, the plastic engineer -- "Just a word of warning, PVC can handle some high heats but if it catches fire, you wont be able to put it out, it does not need oxygen to burn so don't do this inside".
I do work inside, but my house is made of cement and has good ventilation. MAKE SURE THAT YOU HAVE GOOD VENTILATION. IF YOU PLAY WITH FIRE, DO SO CAREFULLY.
Step 2: The First Cut
The first cut is made at quite a sharp angle. This gives you plenty of material to cut the two "fingers" out of.
Use a pencil to sketch out the cuts you are going to make.
Step 3: Cut out the Pattern
Step 4: Smoothing the Edges
Notice the PVC handle on the scraper. It was heated and then just squeezed over the knife fragment to hold it firmly.
Step 5: Heat and Form the "Fingers"
Bend the fingers into the hook shape by pressing them against something, such as a wall. You can always do touch-up heating with a propane torch to modify the shape.
Make sure the slot between the two fingers is open enough to accommodate the berry stem. If it is not, you may have to open it up more with a saw, or file.
Step 6: The Bottom End
You could use something conical, or rounded to make the flared end, but I thought it would be appropriate for the project to be flared over a glass hand juicer. It gave the end an interesting hexagonal shape.
I tied the plastic bag on with a piece of string.
The final step is to go pick some berries!
Visit Our Store »
Go Pro Today »
At least the picker is ready for next year.
Do you have a web site for your farm or products? Is there a way to PM on this site so I don't have to post my email on this comments page?
Please tell me how you superimposed that image of the picker onto your other photo.
Keep inspiring and thinking creatively!!
Michael
My web site is www.angelfire.com/in2/manythings . Hope you enjoy it.
I think if you click on my icon it will take you to my profile, and from there you can send a private message.
I use a photo editing program called PhotoImpression that lets one work with layers and make collage images. It's a lot more user friendly than Photoshop is.
I like to use hot water to soften plastics though.
However, how many people have even this? I have yet to see it in my generation, for all they care about is what they look like.
(Huckleberries are selling for $40 per gallon bag at the farmers markets.)
Thanks!
use a 1 gallon plastic milk jug with short fingers cut out of the side opposite of the handle
