3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
BHSB (Big Honkin' Sandin' Block)
Step 4The Tricky Part
The Tricky Part
Next step is to attach the other side of the belt to the other board. Youll want to do it such that there is a slight gap under the joint, this is where the tension will come from later. Ive found a 1 to 1 ½ gap (ie two pieces of 3/4 plywood) is just about perfect. If its too tight the belt will tear so dont overdo it. Shove a couple scraps under the bottom board's center cut and then pull the belt up and over and secure it with screws and a spacer blcok. Once the belt is attached then line the two bottom boards up and get it set up like this.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:SmileyStarfish
