If you check out the net you'll find lots of active crossovers for sale. Many use esoteric technology but all are overpriced and unsuitable for experimenters. So here I will introduce a new concept for audio experimenters, the core kit. I believe it's counterproductive to try sending heavy items overseas. Especially as most can get the heavy and expensive parts locally and at a lower price. It makes sense then to design high quality kits which can be operated by a wide range of locally available power supplies. By locally I mean everywhere with a mains supply . The circuits are designed to operate from battery eliminator type plug in power supplies. Current requirement is 20mA. If plug in supplies, or the mains aren't available the circuit can be operated from batteries, a car battery is ideal.
Similarly a basic housing is provided. If the builder wants more he can make his own arrangements locally. The payoff is less expense and higher performance for the customer and, hopefully, higher sales for us. Why go active? Audiophiles know that so called passive speakers, those driven from a single power amp passive filters will never sound as good as an active speaker. Putting a passive filter in series with the speaker drivers will rob the drivers of the full damping factor of the amplifier driving it. The result, muzzy sound. Furthermore most of the energy in music occurs below 1kHz so a single amplifier can be driven into overload passing the unwanted high frequencies distortion components into the tweeter via the passive crossover. In the active system the tweeter will be driven from a separate amp so that even if the woofer amp is overloading no damage can be caused to the tweeter and the whole system will still sound sweet.
Another advantage of the active system is that the required response curves are easily generated by standard filter stages and are independent of speaker parameters. Anyone who has tried to design passive crossovers will be well aware of the difficulties, and compromises, involved.
Remove these ads by
Signing UpStep 1GETTING THE PARTS
Is there an equivalent opamp to the TL074 my local store has discontinued them and im having a bit of trouble locating them
Thanks =)
Thanks
