This instructable has been removed by the author.
69
comments
Add Comment
| 1-50 of 69 | next » |
Mar 8, 2008. 4:49 PMZetheros
says:
heh, my barrel is 3 foot long, and I use 4 inch needles and 1 inch cones.
Aug 7, 2008. 8:30 PMwrodnie
says:
i use the thing that ajusts the shades/blinds so they filter out mor or less light
haha, I also had such blowgun, i wondered how small you could make it :)
Mar 9, 2008. 10:24 AMZetheros
says:
And a few tips; you can make the cones out of plastic chip bags, they last much longer and are lighter. Although maybe harder to get in a school than paper. -evil grin-
Jul 31, 2009. 11:42 AMCheepNEasyBuilder
says:
mine doesnt work well.it wont stick into anything any idease??
Jul 24, 2009. 5:20 PMa918bmxr
says:
its not that you cant blow hard enough it requires a technique kinda use your tongue as a quick release valve
Nov 3, 2007. 6:06 PMdezire
says:
I can never blow hard enough for the darts to go out of the barrel, either i made them too small or i am breathless. I couldn't manage to get the small blue part out of the pen to make it only the barrel. Any tips on that?
you could use a skewer or shish-kabob thingy to push the back blue part out
Jun 5, 2009. 11:45 AMsharlston
says:
i made it so the end of the pen is removeable and i shortened the ink tube so i can fit a dart in the back of the pen but still use the pen
Sep 4, 2008. 9:58 AMbrando the commando
says:
um that is incredibly easy but it sucks if you put lime juice on the end of the needle
Jun 5, 2009. 11:43 AMsharlston
says:
erm because lemon and lime juice stings when u get it on a cut
Apr 18, 2009. 4:44 PMshawntherobot
says:
does it hurt alot?Because i dont want to hurt anyone too much...........................or do i he he he he he MUHAHAHAHAH (caugh gag blag).
Take a hollow needle and inject lemon juice directly into your veins.
I'm liable for what you do
Apr 18, 2009. 5:42 PMshawntherobot
says:
sure ok i will thanks a ton ..........(five minutes later)OOOOHHHHHHMMMMMYYYYGGGGGGGOOOOODDDDDD
Dec 31, 2008. 9:38 AMEvilthingamabober
says:
How bout' capsaicin? That stuff is the main ingredient in pepper spray and pepper, it's pure spiciness.
May 13, 2009. 8:56 PMfedecale
says:
still piercing at 10 foots done n working wonders. Cheerz from argentina
Jun 16, 2008. 5:16 PMruiqim
says:
The problem with shooting them at people is that they can take it and throw it back at you.
Dec 31, 2008. 9:40 AMEvilthingamabober
says:
Actually, they would just run after you and beat you up.
Feb 8, 2009. 4:18 PMWeston607
says:
Unless you shot one in each of there eyes, and they couldn't see where they where running, and run into a tree! Though this would be very dangerous lol
Haha, yes, that is something we must concern about
Nov 27, 2008. 1:00 AMTrogdor_The_Burninator
says:
i made darts like those and i fit it into an airsoft gun... not its terrifying i shot it at a binder made of solid plastic about 5 mm's thick and it went through also piercing another 5-7mm's of paper in the binder
Aug 7, 2008. 8:22 PMwrodnie
says:
i use a sewing needle with the back end of a shoelace that has ben cut of and frayed at one end
Jun 15, 2008. 8:19 PMKLUTZYengineer
says:
There needs to be an Instructable for creating the paper cone itself...
Jun 4, 2008. 3:55 PMpindalanderz
says:
Great instructable!!! I have found though, that you can make the darts out of spiraled tape and they usually work pretty well. I did have a problem with getting the darts to fly strait but a bit of adjusting usually does the trick. The best part about it is you can shoot it at someone, they can take it and you lose little or no value.
May 13, 2008. 10:45 AMjeffconnelly
says:
I put the dart in the tube, pulled out the ink stick from the pen, and put the pen back together again, so it's a stealth blowdart-in-a-pen
