BJ-2 Combat Knife : KNEX
Introduction: BJ-2 Combat Knife : KNEX
This knife is part of a series of weapons for BATTLEFIELD 2142, the Morretti SR-4 is part of that group. This weapon can easily be used to humiliate any foe.
In step 3 part 1 you can replace the 3 upper yellow half moons with white snowflakes, by doing this you can turn it into a bayonet!
Step 1: Parts
Gather the parts that are needed:
Green Rods : 20
White Rods : 21
Grey Rods : 2
Dark Grey Connectors : 3
Red Connectors : 5
Green Connectors : 2
Yellow Connectors : 11
White Connectors : 2
Y Connectors : 1
Tan Clip Connectors : 1
Step 2: Start to Assemble the Parts
1. First of all make this part.
2. Add a red connector.
3. Add a yellow connector and a green rod.
4. Add another red connector.
5. Add 2 white rods.
6. Add a third white rod.
Step 3: Continue to Assemble the Parts
1. Add 4 Yellow Connectors, 3 White Rods and 4 Green Rods.
2. Get your 'Y' Connector ready.
3. Attach the 'Y' Connector.
4. Attach the 2 Grey Rods.
5. Make up the knife tip using a Dark Grey Connector, A Green Connector and a Green Rod.
6. Attach the tip to the Grey Rods.
Step 4: Assemble the Handle
1. Add a Connector and a Green Rod on each side.
2. Attach a White Rod across the handle and then attach 2 Yellow Connectors and 2 Green Rods, Repeat on the other side.
3. To one side attach this to it.
4. Attach 2 White Rods.
5. Add a Tan Clip Connector
6. Repeat Step 3 and make sure that the White Rods from Step 4 are connected.
Step 5: The Final Checks
1. Check the handle and make sure it is all put together correctly.
2. Make sure the blade is correctly connected into the handle.
Step 6: Complete
The knife is now complete. This knife is good for combat training, to do this cover the bottom Grey Rod and the tip with your mum's or your sister's lipstick. And when you you get a critical hit like the neck you will know for sure.
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    • Pocket-Sized Contest
    Most combat knives are non-folding and have a full tang in order to be sturdy, as they have tou double as survival and utility knives. Folding knives are good for EDC (Every Day Carry) as they are lightweight and small, so they are very portable and practical, but can't withstand a lott of force since the hinge is the weakest part (even if it is reinforced, it's a Solids Mechanics principle). But in a situation that requires my life depinding on a knife, I'll take a full tang 1/4 inch thick knife anyday over a folding knife. Moving parts = less cross-section inn that point = effort concentrator in the material = point of rupture.
    Does it fold?
    combat knifes don't fold i like your knife a little better. this knife looks cool though.
    Some combat knives fold.
    Most combat knives don't fold as if you went to slit someone throat you would have to open it, giving your position away with the distinctive "ching" of the knife springing out, unlike a solid one with a leather sheath!
    1. Unless you are a terrorist you shouldn't do that. 2. Can't you open it quietly. 3. it is safer to have a folding one than stabbing your OWN leg when its in you pocket, and that's just pathetic. 3. What was the point of typing all of that I hate when i type that much.
    Lol, you imply that only terrorists use knives. Why do you think it's called a "combat" knife? Also, you used the number 3 twice.
    fail with the 3s there :L a combat knife could also be used as a bayonet or vice versa
    True. But still, it was designed to kill.
