BLDC Motor Control with Arduino, salvaged HD motor, and Hall Sensors by dlginstructables
There is a lot of interest these days among hobbyists in controlling brushless DC (BLDC) motors, which have improved performance and better energy efficiency over
traditional DC motors, but are more difficult to use. Many off-the-shelf products exist for this purpose. For example, there are lots of small BLDCs controllers for RC
airplanes that work really well.
For those wanting to delve more deeply into BLDC control there are also many different micro controllers and other electronic hardware intended for industrial users and
these usually have very good documentation. So far, I have not found any comprehensive descriptions of how to do BLDC control with an Arduino microcontroller. Also, if
you are interested in doing regenerative braking, or using a BLDC for power generation, I have not found many products that are suitable for use with small motors or
much information on how to control a 3-phase generator.
This instructable started out as a demonstration project in a class on real-time computing, and which I continued after the class ended. The idea for the project was to
demonstrate a scale model of a hybrid electric vehicle with flywheel energy storage and regenerative braking. The motors used in the project are small BLDCs
scavenged from broken computer hard drives. This instructable describes how to implement BLDC control with one of these motors, an Arduino microcontroller and Hall-
Effect position sensors, in both motoring and regenerative braking modes. Note that having access to an oscilliscope is extremely helpful, if not essential, to doing this
project. If you don't have access to a scope, I have added some suggestions for how it might be done without one (step 5).
One thing that this project doesn't have that should be included in any practical motor controller is any safety features, such as overcurrent protection. As it is, the worst
thing that can happen is that you burn out the HD motor. However, it would not be too difficult to implement overcurrent protection with the current hardware, and perhaps
I will do it at some point. If you try controlling a larger motor, please do add overcurrent protection, to protect your motor, and for your own safety.
I would like to try using this controller with a larger motor that can do some "real" work, but I don't have a suitable motor yet. I noticed an 86W motor for sale on eBay for
around $40.00 that seems like a good candidate. There's also an RC website called "GoBrushless" that sells kits for putting together your own BLDC. These are not too
expensive and building one is a worthwhile experience. Note that the motors from this web site do not have Hall sensors.
Whew! It was a lot of work to write up this instructable. I hope you find it useful and please post your comments and suggestions.
Step 1: Video
Step 2: Tools and Materials
Tools
Digital Multimeter (DMM) - It's helpful if your DMM has a frequency meter
Oscilloscope (Preferably with at least 2 channels)
T8 Torx driver (you need one of these to open up any hard drive). A good hardware have them.
Machine Shop and Rapid Prototype Machine (These were extremely helpful, but with a little ingenuity I think the project can be done without them).
Materials
BLDC motor from a computer hard drive
A magnet ring (half of the motor) from another hard drive.
Several (3-6) of the silver disks from a hard drive
A second small motor (DC brushed OK)
rubber band or (preferably) belt to turn the BLDC with another motor
Electronic Breadboard
solid core wire 22 AWG for breadboard connections
One Arduino Duemilanove microcontroller
Three 120  k ohm resistors
six ~400 ohm resistors
Linear or Rotary Poteniometer 100 k ohm
ST Microelectronics  L6234 Three Phase Motor Driver IC
Two 100 uF capacitors
One 10 nF capacitor
One 220 nF capacitor
One 1 uF capacitor
One 100 uF capacitor
Three recifier diodes
one 2.5 amp fuse
one fuse holder
3 Honeywell SS411A Bipolar Hall-Effect Digital Position Sensors
Three 1 K  resistors
12 V hobby sized lead acid battery
Step 3: Understanding BLDC Control
If you are going to do this project, I recommend that you spend the time to thoroughly understand how a BLDC works and is controlled. There are tons of references available online (see below for some recommendations). I do however, include some diagrams and tables from my project that should assist you in your understanding.
Here is a list of the concepts that I think are the most important for understanding this project:
MOSFET transistor
3-phase half-bridge
6-step commutation of a 3-phase motor
Pulse Width Modulation (PWM)
General References
Brushless DC Motor Fundamentals by Microchip
AVR443: Sensor-based control of three phase Brushless DC motor
from ATMEL
Brushless DC Motor Control Made Easy from Microchip
3-Phase BLDC Motor Control with Hall Sensors from Freescale
 A nice video of a scavenged hard drive motor, but the author appears to be running the motor as a stepper motor, not as a BLDC
More Specific References
Web Page on the L6234 Motor Driver IC, including datasheet, application note, and purchase information.
free samples http://www.st.com/stonline/domains/buy/samples/index.htm
Design of a PM Brushless Motor Drive for Hybrid Electrical Vehicle Application. This is the only paper I have found that describes the commutation sequence for regenerative braking.
This paper, REGENERATIVE BRAKING IN AN ELECTRIC VEHICLE was useful and I borrowed a couple of figures from it, but I think it incorrectly describes how regeneration works.
Step 4: The Motor
I did this project with a salvaged disk drive motor because it was easy to come by and I liked the idea of learning the ropes of BLDC control with a small, low voltage motor that doesn't pose any safety issues. Also, the configuration of the magnets for the Hall sensors was made really easy by using a magnet ring (rotor) from a second one of these motors (See Step 4).
If you don't want to go to all the trouble of installing and calibrating the hall sensors (steps 5-7), I understand that at least some CD/DVD drive motors have built-in hall sensors.
To provide some rotational inertia on the motors and to give them a bit of a load to work against, I put 5 hard drive disks on the motor, lightly glued together and to the motor with a little superglue (this made the flywheel in my original project).
If you are going to remove the motor from a hard drive, you will need a T8 torx driver to unscrew the casing (often there are one or two screws in the center that are hidden behind a stick-on label) as well as the internal screws that hold the motor in place. You also need to remove the head reader (a voice coil actuator) so that you can remove the memory disks to get to the motor.
Also, you'll need a second, identical hard drive motor from which you'll remove the rotor (which has a ring of magnets inside it). To pull the motor apart, I gripped the rotor (top) of the motor in a vise and then pried on the stator (bottom) with two screwdrivers 180 degrees apart. It's not so easy to grip a motor in a vice tight enough without deforming it. You may want to build a set of wood v-blocks for this purpose.
I drilled and bored a hole in the magnet ring on a lathe so it would fit snugly on top of the motor. If you don't have access to a lathe, you can fix the inverted rotor to your motor with superglue.
Photos 2 and 3 below show the interior of one of these motors that I pulled apart. Inside the top half there (the rotor) are 8 poles (magnets that are encased in plastic). On the bottom half (the stator) there are 12 slots (windings).  Each of the three motor phases has 4 slots that are connected in series.
Some HD motors have three contacts on the bottom, one for each phase, and have an extra one that is the center tap of the motor (where the three phases meet). In this project, there is no need for the center tap, but in sensorless control it can come in handy (I hope to post an instructable about sensorless control one of these days). If your motor has four contacts, you can identify the phases with an ohmeter. The resistance betwee the center tap and a phase is half  of the resistance between any two phases.
Most literature on BLDC motors concerns those with trapezoidal back EMF waveforms, but hard drive motors seem to have a back EMF that looks sinusoidal (see photo below). As far as I can tell, it works fine to drive a sinusoidal motor with a square wave PWM, although there may be some decrease in the efficiency.
As with all BLDC motors, this one is driven by a three-phase half-bridge of transistors (See 2nd photo below). I used an IC made by ST Microelectronics (L6234) for the bridge, also known as the motor driver. The electrical connections for the L6234 are shown in Step 8. The third photo below shows a schematic of the motor driver and the three motor phases.
In order to make the motor run clockwise, the following order of switching would be done (first letter is the upper transistor, second is the lower):
Step                                 1      2     3     4     5     6
Clockwise:                    CB, AB, AC, BC, BA, CA
Counter Clockwise:     BC, BA, CA, CB, AB, AC
This 6-step sequence takes 360 "electrical degrees" but, for these motors, only 90 physical degrees. So, the sequence happens four times per motor revolution. It would seem that both of these sequences are identical, but they are not, because, for each step in the 6-step sequence, the current through the phases is in one direction for CW and in the opposite direction for CCW.
You can see this for yourself by applying a voltage from a battery or power supply to any two motor phases. If you apply voltage, the motor will turn a little bit in one direction and then stop. If you could quickly change the voltage on the phases in one of the sequences above, you would be able to rotate the motor manually. The transistors and the microcontroller do all of this switching very rapidly, many hundreds of times per second when the motor is running at high speed.
Also, notice that if you apply voltage to two phases, the motor move a little bit and then stops. This is because the torque goes to zero. You can see this in the fourth photo below, which shows the back emf from a pair of motor phases. It's a sine wave. When the wave crosses the x-axis, the torque provided by that phase is zero. In the six-step BLDC commutation sequence that never happens. The power is switched to another phase combination before the torque on a particular phase goes low.
Step 5: The Hall Sensor Mechanical Setup
Larger BLDC motors are often manufactured with the hall sensors inside the motor. If you have such a motor then you can skip this step. Also,  I understand that at least some CD/DVD drive motors have built-in hall sensors.
Three hall sensors are used for position detection as the motor rotates, so commutation takes place at just the right instant. I have run my HD motor as fast as 9000 RPM (150 Hz). Since there are24 commutations per rotation, at 9000 RPM the commutations occur every 280 microseconds.  The Arduino microcontroller operates at 16 MHz, so each clock cycle is 0.06 microseconds. I don't know exactly how many clock cycles it takes to perform the commutation, but even if it takes 100, that's five microseconds per commutation.
The HD motors do not have hall sensors,  so it's necessary to mount them to the exterior of the motor. The sensors need to be fixed relative to the motor rotation and exposed to a series of magnetic poles that change in concert with the rotation of the motor. My solution was to take the magnet ring from an identical motor and mount it, inverted, on top of the motor to be controlled. I then mounted the three Hall sensors just above this magnet ring, exactly 30 degrees apart from each other on the motor axis (120 electrical degrees in the motor rotation).
My hall sensor mount consists of a simple stand made of three aluminum parts that I machined and three plastic parts made on a rapid prototype machine. If you don't have access to these tools, it shouldn't be too difficult to find another way to make the stand. Creating a mount for the hall sensors will be more challenging. This is one way that might work:
1. Find an appropriately sized plastic disk to which you can carefully epoxy the Hall sensors.
2. Print out a template on paper that has a circle with the same radius as the magnet ring and three marks 15 degrees apart
3. Glue the template to the disk and then carefully epoxy the Hall sensors in place using the template as a guide.
Step 6: Hall Sensor Circuits
Now that you have the Hall sensors properly mounted on the motor, connect each of them with the circuit shown below and test them out with a DMM or oscilloscope to ensure that the output goes high and low as the motor is rotated. I run these sensors at 5V, using the 5V output of the Arduino.
Step 7: Calibrating the Hall Sensors
The Hall sensors are digital devices that output either high or low (1 or 0) depending on whether they sense a south or north magnetic pole. Because of their arrangement 15 degrees apart and the magnets that rotate beneath them, changing polarity every 45 degrees, the three sensors are never all high or low at the same time. As the motor spins, the sensor output varies in a six-step pattern that is shown in the table below. The sensors must be aligned to the motion of the motor such that one of the three sensors changes exactly at the positions of motor commutation. In this case, the rising edge of the first Hall Sensor (H1) should coincide with the turning on of the combination of phases C(high) and B (low). This corresponds to having transistors 3 and 5 turned on in the bridge circuit.
I used an oscilloscope to align the sensors with the magnets. I had to use three channels of the scope to do this. I spun the motor via a belt connected to a second motor and measured the Back EMF between two phase combinations (A and B, A and C), which are the two sine-like waves in the photo below. The signal from one of hall sensor 2 was then viewed on channel 3 of the scope. The Hall sensor mount was turned until the rising edge of the hall sensor was aligned exactly with the point where commutation should take place (See photo below). I now realize that this same calibration can be made with just two channels. If the BEMF of Phase combination B-C were used, then the rising edge of H2 would coincide with the zero crossing of the B-C curve.
The reason that commutation should occur here is to keep the motor torque as high as possible at all times. The Back EMF is proportional to the torque and you will notice that each commutation takes place when the BEMF crosses below the curve of the next phase. So, the actual torque consists of the highest parts of each phase combination.
If you don't have access to a scope, here is an idea I have for doing the alignment. This is actually an interesting exercise for anyone wanting to get a feel for how the BLDC motor works. If you connect  motor phases A (positive) and B (negative) to a power supply and turn on the power, the motor will rotate a tiny bit and then stop. If you then move the negative power lead to phase C and turn the power on, the motor will turn a little further and then stop. The next part of the sequence would be to move the positive lead to phase B and so on. When you do this the motor always stops at a point where the torque is zero, which corresponds  on the graph to one of the places where the graphs crosses the x axis. Notice that the zero of the third phase combination corresponds to the commutation location of the first two combinations. Therefore, the zero torque position of the B-C combination is where you want to locate the rising edge of H2. Mark this position with a fine marker or a sharp blade, and then, using a DMM, adjust the Hall sensor mount until the output of H2 goes high exactly on this mark. Even if you are slightly off in this calibration, the motor should work pretty well.
Step 8: The Power Electronics
The three motor phases will receive power from the L6234 three phase motor driver.  I have found it to be a good product that has stood the test of time. Working with power electronics, there are many ways to accidentally fry your components, and me not being an electrical engineer I don't always understand exactly what's going on. In my school project, we also made our own 3-phase half bridge out of 6 MOSFET transistors and six diodes. We used this with another driver, the HIP4086 by Intersil, but we had tons of problems with this set up - we burned out a bunch of transistors and chips.
I run the L6234 (and thus the motor) at 12V.
The L6234 has an unusual set of inputs to control the 6 transistor half bridge. Instead of having one input for each transistor, there is an enable (EN) input for each of the three phases, and then another input (IN) that chooses which transistor in the phase is turned on (upper or lower). For example, to turn on transistors 1 (upper) and 6 (lower), EN1 and EN3 are both high (EN2 low to keep that phase off) and IN1 is high and IN3 is low. This makes the phase combination A-C.
Although the L6234 application notes suggest that the PWM for controlling motor speed be applied to the IN pins, I decided to do it on the EN pins because, at the time, I thought it would be "weird" to have the upper and lower transistors of a phase being turned on alternately. In fact, there appears to be nothing wrong with having the low transistors from two phases turned on at once, because they are at the same potential, so no current will be passed through either of them. With my method, the high phase is alternately enabled and disabled at the PWM frequency, while the low phase is kept on throughout the commutation period.
Below is a diagram of the motor driver, to which I have added the pin connections to the Arduino board. I also add a 2.5 Amp fuse between the positive battery lead and the circuit and a 100 uF Capacitor between power and gnd to reduce the ripple in the regenerative current. The diagram is kind of small to see, so consult the documentation for the L6234 for a larger version.
Step 9: Regenerative Braking
SInce I haven't found a lot of information out there about regenerative braking with a 3-phase motor, I will describe my understanding of how it works. Note that I am not an electrical engineer, so any corrections to my explanation would be appreciated.
When motoring, the control system sends electric current into the three motor phases in such a way as to maximize torque. In regenerative braking, the control system also maximizes torque, but this time it is negative torque, which causes the motor to slow down, while at the same time sending  current back into the battery.
The method of regenerative braking I use comes from a paper by Oakridge National Laboratory, a U.S. govt. lab that does a lot of research on electric motors for cars. The diagrams below are from another paper and help illustrate how it works (However, I believe that the explanation given in this second paper is partially incorrect). Remember that the BEMF voltage in the motor phases goes up and down as the motor rotates. In the diagram, a moment in time is shown where the BEMF is high in Phase B and low in Phase A. In this case, the current has the possibility of flowing from B to A.
What's essential to the regenerative braking is that the low side transistor is switching rapidly on and off (PWM switching thousands of times per second). While the high side transistor switch is OFF; when the low transistor is ON, the current flows as in the first diagram.  In the terminology of power electronics, the circuit acts like a device called a boost converter and energy is stored in the motor phases (Wikipedia has a nice article explaining how a boost converter works). When the low side transistor turns off, this energy is released, but at a higher voltage, and the current momentarily  flows through the "flyback " diodes next to the each transistor and back into the battery.  The diodes prevents current from going from the battery to the motor.  Meanwhile, the current in this direction (opposite from motoring) interacts with the ring of magnets to create negative torque that slows the motor down. The low side transistor is switched with PWM and the duty of the PWM controls the amount of braking.
When motoring, the commutation of the motor switches from one phase combination to the next at just the right moment to keep the torque as high as possible. The commutation for regenerative braking is very similar in that a certain pattern of switching keeps the motor generating the highest possible amount of negative torque.
If you watch the video in Step 1 you can see that the regenerative braking works, but it doesn't work all that well. I think the main reason is that the hard drive motor I'm using is a very low torque motor, so it doesn't generate much BEMF except at the highest speeds. At lower speeds, there is very little, if any, regenerative braking. Also, my system operates at a relatively low voltage (12 V) and, since every path through a flyback diode drops the voltage by a couple of volts, that also reduces the efficiency a lot. I use ordinary rectifier diodes and if I used some special diodes with a lower voltage drop I might get better performance.
Step 10: Connections to the Arduino
Below is a list of the inputs and outputs on the arduino. A diagram and a photograph of my boards are also included.
2- Hall 1 digital input  - Also 120 K resistor to gnd
3 -Hall 2 digital input  - Also 120 K resistor to gnd
4 -Hall 3 digital input - Also 120 K resistor to gnd
5 - IN 1 digital output in series with 400 ohm resistor
6 - IN 2 digital output in series with 400 ohm resistor
7 - IN 3 digital output in series with 400 ohm resistor
9 - EN 1 digital output in series with 400 ohm resistor
10 - EN 2 digital output in series with 400 ohm resistor
11 - EN 3 digital output in series with 400 ohm resistor
100 k ohm potentiometer connected to +5V and gnd on the ends and analog pin 0 in the middle. This potentiometer is used to control motor speed and the amount of braking.
+5V power is also used to run the Hall sensors (see step 5).
Step 11: Control Software for the Arduino
Below is the entire program that I wrote for the Ardjuino, with comments included:
 * BLDC_congroller 3.1.1
 * by David Glaser
 * The 3.x series of programs is for the ST L6234 3-Phase Motor Driver IC
 * Runs a disk drive motor clockwise
 * With regenerative braking
 * Motor speed and braking is controlled by a single potentiometer
 * Motor position is determined with three Hall-Effect sensors
 * The Arduino receives outputs from 3 hall sensors (pins 2,3,4)
 * and converts their combination to 6 different commutation steps
 * PWM outputs on pins 9,10,11, at 32 kHz (corresponding to EN 1,2,3 respectively
 * 3 DO on pins 5,6,7 (IN 1,2,3)
 * Analog in 0 is connected to a potentiometer to change the PWM duty and change
 * between motoring and regenerative braking.
  * 0-499: braking
  * 500-523: coasting
  * 524-1023: motoring
  * There are many lines commented out that were used for debugging by
  * printing various values to the serial connection.
int HallState1; //Variables for the three hall sensors (3,2,1)
int HallState2;
int HallState3;
int HallVal = 1; //binary value of all 3 hall sensors
int mSpeed = 0; //speed level of the motor
int bSpeed = 0; //braking level
int throttle = 0; //this variable is used with analog in to measure the position of the throttle potentiometer
void setup() {
  pinMode(2,INPUT);    // Hall 1
  pinMode(3,INPUT);    // Hall 2
  pinMode(4,INPUT);    // Hall 3
// Outputs for the L6234 Motor Driver
  pinMode(5,OUTPUT);   // IN 1
  pinMode(6,OUTPUT);   // IN 2
  pinMode(7,OUTPUT);   // IN 3
  pinMode(9,OUTPUT);   // EN 1
  pinMode(10,OUTPUT);  // EN 2
  pinMode(11,OUTPUT);  //  EN 3
  //Serial.begin(9600); //uncomment this line if you will use the serial connection
  // also uncomment Serial.flush command at end of program.
/* Set PWM frequency on pins 9,10, and 11
// this bit of code comes from
http://usethearduino.blogspot.com/2008/11/changing-pwm-frequency-on-arduino.html
  // Set PWM for pins 9,10 to 32 kHz
  //First clear all three prescaler bits:
  int prescalerVal = 0x07; //create a variable called prescalerVal and set it equal to the binary number "00000111"                                                       number "00000111"                                                      number "00000111"
  TCCR1B &= ~prescalerVal; //AND the value in TCCR0B with binary number "11111000"
  //Now set the appropriate prescaler bits:
  int prescalerVal2 = 1; //set prescalerVal equal to binary number "00000001"
  TCCR1B |= prescalerVal2; //OR the value in TCCR0B with binary number "00000001"
  // Set PWM for pins 3,11 to 32 kHz (Only pin 11 is used in this program)
  TCCR2B &= ~prescalerVal; //AND the value in TCCR0B with binary number "11111000"
  TCCR2B |= prescalerVal2; //OR the value in TCCR0B with binary number "00000001"//First clear all three prescaler bits:
//MAIN LOOP OF THE PRGROM
void loop(){
   //time = millis();
  //prints time since program started
  //Serial.println(time);
  //Serial.print("\n");
  throttle = analogRead(0); //value of the throttle potentiometer
  mSpeed = map(throttle, 512, 1023, 0, 255); //motoring is mapped to the top half of potentiometer
  bSpeed = map(throttle, 0, 511, 255, 0);    // regenerative braking on bottom half of pot
  //mSpeed = 100; //used for debugging
  HallState1 = digitalRead(2);  // read input value from Hall 1
  HallState2  = digitalRead(3);  // read input value from Hall 2
  HallState3  = digitalRead(4);  // read input value from Hall 3
  //digitalWrite(8, HallState1);  // LEDs turned on when corresponding sensor is high - originally used for debugging
  //digitalWrite(9, HallState2);
  //digitalWrite(10, HallState3);
  HallVal = (HallState1) + (2*HallState2) + (4*HallState3); //Computes the binary value of the 3 Hall sensors
  /*Serial.print("H 1: "); // used for debugging
  Serial.println(HallState1);
  Serial.print("H 2: ");
  Serial.println(HallState2);
  Serial.print("H 3: ");
  Serial.println(HallState3);
  Serial.println(" ");
  //Serial.println(mSpeed);
  //Serial.println(HallVal);
  // Monitor transistor outputs
  //delay(1000);
  /*T1 = digitalRead(2);
  //T1 = ~T1;
  T2 = digitalRead(4);
  //T2 = ~T2;
  T3 = digitalRead(5);
  //T3 = ~T3;
  Serial.print(T1);
  Serial.print("\t");
  Serial.print(T2);
  Serial.print("\t");
  Serial.print(T3);
  Serial.print("\n");
  Serial.print("\n");
  Serial.print(digitalRead(3));
  Serial.print("\t");
  Serial.print(digitalRead(9));
  Serial.print("\t");
  Serial.println(digitalRead(10));
  Serial.print("\n");
  Serial.print("\n");
  //delay(500);
// Commutation for Motoring
// Each binary number has a case that corresponds to different transistors being turned on
// Bit Math is used to change the values of the output
// For tutorial on bitmath with the Arduino: http://www.arduino.cc/playground/Code/BitMath
// PORTD contains the outputs for the IN pins on the L6234 driver
// that determine whether the upper or lower transistor of each phase is used
// The outputs for the EN pins are controlled by the Arduino command analogWrite, which
// sets the duty of the PWM (0 = OFF, 255 = ON or throttle value that is controlled by the potentiometer).
  if (throttle > 511){
      switch (HallVal)
        case 3:
          //PORTD = B011xxx00;  // Desired Output for pins 0-7 xxx refers to the Hall inputs, which should not be changed
          PORTD  &= B00011111;
          PORTD  |= B01100000;  //
          analogWrite(9,mSpeed); // PWM on Phase A (High side transistor)
          analogWrite(10,0);  // Phase B off (duty = 0)
          analogWrite(11,255); // Phase C on - duty = 100% (Low side transistor)
          break;
        case 1:
          //PORTD = B001xxx00;  // Desired Output for pins 0-7
          PORTD  &= B00011111;  //
          PORTD  |= B00100000;  //
          analogWrite(10,255); //Phase B on (Low side transistor)
          analogWrite(11,0); //Phase B off (duty = 0)
          break;
        case 5:
          //PORTD = B101xxx00;  // Desired Output for pins 0-7
          PORTD  |= B10100000;
          analogWrite(9,0);
          analogWrite(11,mSpeed);
          break;
        case 4:
          //PORTD = B100xxx00;  // Desired Output for pins 0-7
          PORTD  &= B00011111;
          PORTD  |= B10000000;  //
          analogWrite(9,255);
          analogWrite(10,0);
          break;
        case 6:
        //PORTD = B110xxx00;  // Desired Output for pins 0-7
          PORTD  &= B00011111;
          PORTD = B11000000;  //
          analogWrite(9,255);
          analogWrite(10,mSpeed);
          analogWrite(11,0);
          break;
        case 2:
          //PORTD = B010xxx00;  // Desired Output for pins 0-7
          PORTD  &= B00011111;
          PORTD  |= B01000000;  //
          analogWrite(9,0);
          break;
   // Commutation for Regenerative Braking
   // PORTD (Outputs for IN pins on L6234) pins are always low so only the
   // lower transistors on each phase are used
   // upper transistors are always off during regen. braking.
   else{
          //PORTD = B000xxx00;  // Desired Output for pins 0-7
            PORTD  &= B00011111;
            PORTD  |= B00000000;  //
          switch (HallVal)
          case 3:
            analogWrite(9,bSpeed);
            //analogWrite(9,0);
            analogWrite(10,0);
            analogWrite(11,0);
            break;
          case 1:
            analogWrite(10,0);
            analogWrite(11,0);
            break;
          case 5:
            analogWrite(9,0);
            analogWrite(10,0);
            analogWrite(11,bSpeed);
            break;
          case 4:
            analogWrite(9,0);
            analogWrite(10,0);
            break;
          case 6:
            analogWrite(9,0);
            analogWrite(10,bSpeed);
            analogWrite(11,0);
          break;
        case 2:
          analogWrite(9,0);
          analogWrite(11,0);
          break;
   //time = millis();
  //Serial.flush(); //uncomment this if you will use serial port for debugging
Step 12: An Alternate Hardware-Based Approach to Commutation Logic
It has occurred to me that the operations performed by the Arduino in this project are so simple that it almost seems like a waste to use a microprocessor for this task. In fact, the L6234 application notes recommend a simple programmable logic gate array (GAL16V8 made by Lattice Semiconductor) to do this job. I don't have any familiarity with programming this type of device, but the IC costs only $2.39 at newark.com, and other similar ICs are also very inexpensive.
Another option is to piece together discreet logic gates. I figured out some relatively simple logic sequences that should work to drive the L6234 IC from the output of the three hall sensors. The
diagram for phase A is shown below and also the truth tables for all three phases (In order to make the logic circuit for phases B and C the "not" gate must be switched to the other side of the "or" . The problem with this approach is there are nearly 20 connections per phase, so it would be quite a bit of work to put it together. Better would be to program this into a programmable logic gate.
1-40 of 49Next »
elabz says: Mar 24, 2013. 9:44 PM
I love to spin these up to 10,000 RPM + myself but just a bit of a warning is in order here I think. Just yesterday I've opened a 2.5" (laptop) HDD in which the platter has shattered to thousand very dangerous looking glass shards. I assume not all HDDs have ceramic platters, especially not very old ones, but if they do, you spin it up high and it breaks from vibration or you've overtightened the bolt(s) or something like this, the result would be very much like an explosion of a grenade and someone will end up in a hospital or dead. For any serious RPMs you need to have some sort of a cover - the HDDs own body is nice or perhaps a cover from a 100-CD blanks box or some such.
Other than that, happy spinning!
dlginstructables (author) says: Apr 5, 2013. 4:41 PM
Thanks for the comment. I thought that the hd platters were made of metal, but I looked it up and some of them are in fact glass/ceramic. In my project, I had several of them glued together and they were never screwed down tightly, but, when I get a chance, I will add a suggestion that a clear cover be put over the platters.
CraigHyatt says: Apr 3, 2013. 3:05 PM
This is one of the best instructables I've seen. I like that you broke down how the Hall sensors and bridge operate in such a detailed day. Bonus that you included regenerative braking. I've read a ton of documents on this topic, and this is the first time I have actually understood what is going on. Thanks!
dlginstructables (author) says: Apr 5, 2013. 4:37 PM
Thank you very much for the compliment! I put a lot of work into describing everything and I like to know that people are benefiting from it. Yeah, regen braking is hard to grasp, and I by no means have it down. I don't know why there isn't more info out there about it. By the way, I recently drove a Nissan Leaf, and when it does regenerative braking it sounds pretty much the same as my little disk drive motors do!
elabz says: Mar 24, 2013. 9:35 PM
Not sure what you mean by "running the motor as a stepper motor, not as a BLDC" - 9 cog 12 pole BLDC motor is very much like a 36 SPR stepper. Did you mean that his commutation sequence did not include a high-Z state for one of the windings in each step?
E_motor says: Feb 28, 2013. 7:45 AM
awesome guide this! Just fyi, step 5's first picture tag shows 15 degrees, so does the second last line on that page, and the second line in step 7 also says 15, where they should be 30 degrees apart. Was a bit lost until I saw your exchange with Carl.
guillempq says: Jan 1, 2013. 8:42 AM
Is it better control 4 brushless motors through receiver or this special chip?
guillempq says: Dec 31, 2012. 8:18 AM
Can you write an example about the Arduino working with a commercial Brushless Motor, please?
int motor = 0;
void setup() {
pinMode(motor, OUTPUT); //analog Pin
void loop() {
analogWrite(motor, 255);
delay(1000);
analogWrite(motor, 40);
delay(500);
But it doesn't work?
Regards and thanks
dlginstructables (author) says: Dec 31, 2012. 1:59 PM
The arduino digital pins can only output a very small amount of current, so if you have your motor directly connected to the Arduino, I wouldn't expect it to work. What you need to do is use the analogWrite output to control a separate power source.
Here is one instruct able that uses a special chip for controlling motors that will allow you to operate the motor in both directions: http://www.instructables.com/id/Control-your-motors-with-L293D-and-Arduino/?ALLSTEPS
If you only need to run the motor in one direction, then you can use a MOSFETtransistor like this one, which has a link to an arduino tutorial:
https://www.sparkfun.com/products/10213
Good Luck!
mhyanni says: Nov 1, 2012. 8:18 AM
Man,You're Great !!
I'm gonna start on the Project thanks for your help my friend !
dlginstructables (author) says: Nov 1, 2012. 10:45 AM
Thank you. I put a lot of work into this instructable, and I hope it helps you do the project successfully.
tomshirvo says: Sep 19, 2012. 4:36 PM
Hi,
Yes they all support 2A but after some troubleshooting I found that the motor only draws .05A from a working 3 phase controller I have. I did find that one of the hall sensors is not working correctly.
I have tested everything;
I tested that the out puts work High, Low and NC they are fine. I am using 24V and not 12V like you did, does that mean that I should have made some changes with resistors. The one thing I did do was connect both the Sense one and two together and then connected the resistor to GND.
The motor just doesn't seem to spin at all.
dlginstructables (author) says: Sep 21, 2012. 1:40 PM
There are three Hall Sensors and each one must have its own resistor and its own input to the Arduino.
Have you tried getting the motor to turn by manually powering the phases (see step 4)
Step 1 2 3 4 5 6
Counter Clockwise: BC, BA, CA, CB, AB, AC]
have you tested the Hall sensors? You should be able to make them go high by putting a magnet near them.
Do you have an oscilloscope? It helps to have that to see if the hall sensors are in synch with the motor (you can spin the motor by hand and watch the sensor output
tomshirvo says: Sep 22, 2012. 12:28 AM
Ok really strand thing, even though my multimeter give me a reading of 24v out of the outputs 1,2,3 when I make output 1 positive and output 2 negative I get a reading out on the multimeter 24v. BUT this is a big but, when I connect just a plane old dc motor to it nothing happens. If I put the motor on the 24v directly it works fine.
I keep thinking that it has something to do with the sense 1 and 2. you did say that you needed a 400ohm from sense to GND but mine is 470ohm.
dlginstructables (author) says: Sep 24, 2012. 8:06 AM
Try measuring the voltage of the output while the DC motor is connected. If the voltage goes way down, then maybe not enough current is being supplied.
I don't know if it makes a difference to have 470 or 400 ohms on the sense pins.
I need to go back and read the instructable because I have forgotten so much. I will do that when I have time.
tomshirvo says: Sep 25, 2012. 11:56 PM
I have done the same and I don't know where I got the 400ohm resister from. I took that out of the system and it WORKS, sort of. It seems to spin some of the time. Some times it will spin for a while and then start to slow down and stop. Some times it will turn once and stop. and so on.
Thanks for your help so far i'm very grateful, but if you have any ideas with the new problem I'm happy to hear it.
Thanks again
dlginstructables (author) says: Nov 1, 2012. 10:44 AM
Also, take a look at the Hall sensor calibration, to make sure that it matches the back EMF
dlginstructables (author) says: Nov 1, 2012. 10:43 AM
Sorry I haven't replied in a long time. Have you had any progress? Based on your last message, I would take a look at the sequence of the motor's back EMF and make sure that your software is firing the digital outputs in the correct order. Do you have an oscilloscope to look at this?
tomshirvo says: Sep 22, 2012. 12:09 AM
One hall sensor is dead I'm not sure why but the others all work and my circuit works for that.
If you put the motor on a motor controller I have it works fine.
If you just take two of the phases and put them across the positive and negative terminals the motor moves a fraction.
I have a multimeter and when I put it on the terminals I can get a positive and negative and NC reading from each of the 3 phases of the out pins.
I have gotten this motor to turn just using relays it was slow and very noisy but it worked my point is the motor works.
I will list a few of the voltages coming off the L6234 below;
Vs: 24v
VBOOT: 31.7v
VCP: 4.61v
VREF: 9.24v
Sense 1 & 2: 0
I hope this helps. I'm so stuck right now. I don't understand how I can get voltage out of each output but nothing works
tomshirvo says: Sep 18, 2012. 11:53 PM
Hi,
I have been trying to follow this instructable and I just cant get it to work.
I have built the electronics but the nothing works. the only difference is that I am using a 24v 2A BLDC and a Arduino UNO R3
Do you know if the code doesn't work with the UNO R3
dlginstructables (author) says: Sep 19, 2012. 1:25 AM
Hi, you are the first person to write that you are trying to do this project :)
I wrote the code for a Duemilanove, but I think it should work fine with an UNO. I did this project three years ago, but I can try and help you troubleshoot.
My first question is: Do all of your electronic components support 2A?
Second, you say that nothing works. Why don't you start with an individual step iin the instructable and describe what is happening.
chuvso says: Mar 30, 2012. 6:43 AM
How can I check operation of Hall sensor?
Can I check it by Sanwa Analog Multitester ?
dlginstructables (author) says: Apr 7, 2012. 8:33 PM
The best way to test the Hall sensor is with an oscilloscope, but you can use a multitester (we call it a multimeter in the U.S.).
First, connect the sensor as shown in my instructions, and then move a magnet slowly across the sensor. When the sensor works, you will see the voltage go high when it senses the magnetic field. A refrigerator magnet is useful for this, because it has stripes of magnets and as you move it across the sensor, the voltage will go high-low-high-low...
Pash1987 says: Nov 4, 2011. 10:54 AM
I'm relatively new to Arduino and am currently still finding my feet on it.
I am designing a parking sensor and need to use the analogWrite() function to control my sensor as the tone() function is tied up somewhere else.
I was wondering if you could run me through how you altered the frequency of the analogWrite() PWM.
Any help would be greatly appreciated.
BradyZ says: Jan 14, 2012. 10:57 AM
You modify the TCCRnB ('n' is the number of the timer) register for one of the TIMER's. The ATmega328P has 3 timers (TIMER0, TIMER1, and TIMER2). If you want to change the PWM frequency, you just modify the prescaler value for whatever timer you want to change. TIMER0 is used for delay() and millis(), so it's better to use any timer other than TIMER0; but usually nothing bad happens if you modify TIMER0. Your program just wont have/use the correct values in delay() and millis(). To change the PWM frequency on pins 3 and 11 (they use TIMER2) to be ~4kHz (3906.25) you simply place the following line of code in your "void setup()" space:
TCCR2B = TCCR2B & 0b11111000 | 0x02;
- The default for TIMER2 is "0x04"
- If the code is confusing, check out these links for some help:
      -http://arduino.cc/en/Reference/Boolean
      -http://arduino.cc/en/Reference/BitwiseAnd
      -http://arduino.cc/en/Reference/BitwiseXorNot
      -http://arduino.cc/en/Reference/Bitshift
This will work on any 'ATmega' or 'ATtiny' that is supported by Arduino (install ATtiny 'cores' to program them with Arduino 0022 or Arduino 1.0)
I did not figure this stuff out myself. I'm just passing the information onward. Check out this page in the Arduino Playground. It's extremely helpful!
      -http://arduino.cc/playground/Main/TimerPWMCheatsheet
Nakiros says: Nov 4, 2011. 2:05 AM
For higher power you should better turn to mosfet bridges(like the irf3704s-77A@10V) and gate drivers (ir2101 or ir2110). Just google 'Open BLDC' and you will find more info.
Spydamonky says: May 25, 2010. 12:02 PM
 so is the speed of the motor variable? cause im making a autonomus hexacopter and need a speed controller based on a arduino. also dus it use the hall effect sersors for the speed control or only for braking. is there any feedback about the rmp?? ie can you read off the current rpm of the motor any time ??
lampuiho says: Oct 28, 2011. 5:01 PM
the speed of the BLDC motor is determined by the frequency of the pulses of voltage sent to the stator windings. So what you need to do to increase the speed is to reduce the period of the signal and vice versa.
dlginstructables (author) says: May 28, 2010. 9:29 PM
I'm also interested in building a quadracopter, but I wouldn't recommend this for your project. Yes, the Hall sensors can be used to vary the speed, but it pretty much takes all of the arduino's capacity to do the motor commutation. There wouldn't be much computing power left for other functions, and you would need one arduino for each of the 6 motors, plus another to do the control. I know that commercial electronic speed controllers are not cheap. There is one, the Markus 10 that only runs about $25. It's very small but powerful enough for your needs.
Thanks for your interest.
lampuiho says: Oct 28, 2011. 4:54 PM
Are you controlling the field current directly? If not, that's probably the reason why it didn't work well.
Gnutella says: Sep 30, 2011. 4:33 AM
My HD motor has 4 contacts . can you please explain how i could make them turn clockwise and counter clockwise? explain it to me like youre explaining it to a Four year Old.
dlginstructables (author) says: Sep 30, 2011. 8:25 AM
Three of the contacts are the three phases and the fourth one is the center tap, where all the phases meet (search on the Internet for "BLDC Wye Configuration") This contact can be used as a sort of reference "ground" voltage, but you don't need to use it for the control scheme described in this instructable.
Use an ohmeter to figure out which are the three phases and which is the center tap. The resistance between any two phases should be double the resistance between a phase and the center tap.
As far as getting your motor to spin CW or CCW, please read the instructable carefully, as I believe I put detailed instructions on how to do that. If you still have problems, send another comment.
rany says: Aug 31, 2011. 10:17 PM
Thanks a lot for the the nice upload ... superr..
carl says: Jun 17, 2011. 12:02 PM
It looks to me like the hall sensors need to be 30 mechanical degrees apart, which I think would be 120 electrical degrees. Am I making a conceptual error? My motor has 12 slots and 8 poles, which appears to me to be similar to your motor.
dlginstructables (author) says: Jun 17, 2011. 12:22 PM
It's been a long time since I designed the system, so I'd have to go back and confirm why I chose 15 degrees, but I know that it works this way. I believe there are often multiple ways to configure hall sensors on a motor, so 30 degrees may work as well.
carl says: Jun 17, 2011. 1:46 PM
Thanks for the reply. I too am trying to learn about bldc motor control by starting small. I wouldn't have questioned the 15 degree spacing except that I couldn't fit my hall sensors 15 degrees apart without overlap on a sketch of the rotor diameter. From your photos it looked to me like your hall sensor holder was built at 30 degree spacing (it looks like an equilateral triangle will fit between the center and the outer two Hall sensors). I thought I'd ask before I started hacking into my holder material. I guess this is the opportunity for learning that I was looking for!
dlginstructables (author) says: Jun 17, 2011. 2:12 PM
I'm happy that someone is actually using this Instructable! I wrote 15 degrees in my text, but I'll try and take a look at it this weekend. Do you know how to actually figure out hall sensor spacing on a motor?
I'm curious, do you have access to an oscilloscope?
carl says: Jun 17, 2011. 10:00 PM
I drew a sketch of the poles and sensors, then rotated the poles to try to understand how the signals change during rotation. A 30 degree spacing works. A 15 degree spacing does not work (a 111 and 000 shows up at that spacing since the sensors span 30 degrees and a pole spans almost 45 degrees). It looks like the image in step three shows sensor B output inverted, making it look like the sensors should be spaced 60 electrical degrees apart when they should be 120 electrical degrees apart. That's my story at the moment. I will need to throw something together and put it on the oscilloscope and see what happens.
dlginstructables (author) says: Jun 18, 2011. 3:03 AM
You are right! My sensors are placed 30 degrees apart, which is 120 electrical degrees. I corrected the text. Thanks for catching that!
carmatic says: May 7, 2011. 4:56 PM
This looks like 'dynamic' braking rather than 'regenrative' braking, as in the motor is basically shorted out, and the energy would be dissipated as heat in the wires... I do not see how the energy is stored from braking?
1-40 of 49Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
