BLE Heart Rate Sensor
4,343
53
5
Published
Introduction: BLE Heart Rate Sensor
About: Make it yourself if you cannot buy one!
This instructables show how to build a BLE heart rate sensor with Arduino, nRF8001 Bluetooth LE breakout board and PulseSensor module.
Step 1: Introduction
This instructables coding come from 2 modules sample code:
Cheong2K's sample code demonstrate how to advertise heart rate value with BLE module, but only use dummy value in the sample. On the other side, pulse sensor can capture real heart rate value with the Arduino.
My code just merge both sample code to make a workable example.
Module reference:
Step 2: Preparation
Arduino Board
This time I use Arduino Pro Micro
BLE Module
Heart Rate Sensor
Sensor from pulse sensor.com
Others
A small size bread board and some bread board wire
Step 3: Software Preparation
  1. Download and install Arduino (if not yet): https://www.arduino.cc/en/Main/Software
  2. Install BLE SDK for Arduino library
    • Select menu item in Arduino: Sketch -> Include Library -> Manage Libraries
    • Search "BLE SDK for Arduino"
    • Install
Step 4: Connection
Here is the connection summary:
BLE SCK  -> Pro Micro pin 15
BLE MISO -> Pro Micro pin 14
BLE MOSI -> Pro Micro pin 16
BLE REQ  -> Pro Micro pin 10
BLE RDY  -> Pro Micro pin 9
BLE RST  -> Pro Micro pin 8
BLE GND  -> Pro Micro GND
BLE VIN  -> Pro Micro RAW
Pulse Sensor Signal -> Pro Micro A1
Pulse Sensor +ve    -> Pro Micro RAW
Pulse Sensor -ve    -> Pro Micro GND
Step 5: Program Arduino
Download the code from Github:
https://github.com/moononournation/BLE-Heart-Rate-...
If you are not familiar with Github, simply press "Clone or Download" button and select Download ZIP.
Open BLE-Heart-Rate-Sensor.ino in Arduino.
It is some tricky while select board, you need to select "Arduino Leonardo" in Tools Menu -> Board.
Connect the Arduino Pro Micro and press upload button to program it.
Step 6: Start Serial Monitor
After upload the program to Arduino Pro Micro, open Serial at Tools Menu -> Serial Monitor.
You can see "Advertising Start" message.
Step 7: Connect BLE HR Sensor
While advertising start, use an iOS device search the bluetooth device.
Connect to the BLE HR Sensor.
I have no Android in hand, you may find some app that can connect with bluetooth heart rate sensor.
Step 8: Check the Heart Rate
After mobile connected, you will see "Evt Connected" at Serial Monitor.
Open Health app in iOS or BLE heart rate related app in Android.
Put a finger on the pulse sensor, it will start advertising heart rate readings to the mobile.
Step 9: Happy BLE Sensing!
This instructables is just a very simple example of BLE advertising sensor value, you may find more BLE example at Arduino File menu -> Examples -> BLE SDK for Arduino.
    • Water Contest
      Water Contest
    • Oil Contest
      Oil Contest
    • Creative Misuse Contest
    5 Discussions
    Arduino: 1.8.5 (Windows 10), Board: "Arduino Leonardo"
    C:\Users\SiddBSharma\Downloads\software\BLE-Heart-Rate-Sensor-master\BLE-Heart-Rate-Sensor\BLE-Heart-Rate-Sensor.ino: In function 'void setup()':
    BLE-Heart-Rate-Sensor:154: error: 'interruptSetup' was not declared in this scope
    interruptSetup(); // sets up to read Pulse Sensor signal every 2mS
    exit status 1
    This report would have more information with
    "Show verbose output during compilation"
    option enabled in File -> Preferences.
    how do you correct this ? please help.
    Can i use a bluetoth module HC-05...instead of your bluetooth module
    no, you need a BLE module to do that
