I was sure there would be some adapter available to turn the BLS-1 (E-420) battery into a BLM-1 (E-30) battery since they are both Li-ion batteries of the same voltage, but after searching online, I couldn't find one. The closest thing I could find is the PS-LBH1, which takes CR-123A batteries and turns them into a BLM-1. I decided to buy a PS-LBH1, since it already had the proper shape and contacts, and turn it into an adapter for the BLS-1.
For this mod, you'll need:
1 PS-LBH1
1 BLS-1
1 Eye glass Philips-head screw driver
1 Voltmeter
1 Dremel with cut off disk
1 Soldering Iron with solder
1 Drop of super glue.
(Note: I used a canon point and
Remove these ads by
Signing UpStep 1Strip the PS-LBH1
Next snap off all of the battery contacts off and remove the PCB. Save all of these.
You will be using the metal from the battery contacts to create new contacts for the BLS-1.
If you can give me some idea what is going on there, I would greatly appreciate it! Even just a picture of the PCB, or a hint as to what the components are would be a HUGE help.
