BLUE LED RING
5,631
88
6
Published
Introduction: BLUE LED RING
About: If you can't make it simple,you don't have right to make it...
THIS IS A RING VERY EASY TO MAKE AND CAN BE MADE IN LESS THAN 30 MINUTES
Step 1: MATERIALS REQUIRED
SOLDERING IRON
BATTERY
WIRE
LED STRIP
FLUX AND SOLDERING WIRE
Step 2: CIRCUIT DIAGRAM
EASIEST CIRCUIT DIAGRAM EVER
Step 3: DESOLDER THE LEDS FROM THE STRIP
DESOLDER 13 LEDS FROM THE STRIP
Step 4: THE SMD LED
IT IS A VERY SMALL SURFACE MOUNTED DEVICE LED WHICH HAVE VERY HIGH POWER NO HEATING AND A LOT OF BRIGHTNESS TOO
Step 5: START ATTACHING THE LEDS TO THE WIRE
AND MAKE THE RING PATTERN OF YOUR SIZE AND CHOICE
Step 6: THE FINAL LED PRODUCT YOU WILL GET
TAKE CARE OF THE POLARITY - POSITIVE, NEGATIVE OF THE LEDS
Step 7: THIS IS THE FINISHED LED.RING YOU NEED TO CONNECT WITH a POWER SOURCE
CHOOSE A POWER SOURCE LIKE I HAVE USED A 3.7 VOLT LI ION RECHARGEABLE MOBILE PHONE BATTERY
Step 8: SOLDER THE WIRES WITH THE LED
ALSO ATTACH THE BATTERY
MAKE SURE THAT THE THINNER WIRES YOU ATTACH THE BETTER IT WOULD BE
Step 9: ATTACH IT TO YOUR HAND
PUT IT ON YOUR FINGER AND USE SOME RUBBER BANDS TO HIDE THE WIRE OR PUT DOWN YOUR SLEEVES
Step 10: LIGHT TESTING
Step 11: TIME TO LIGHT IT UP
ENJOY EVERYWHERE FROM PARTIES TO MARRIGE RING CEREMONY OR TO SHOW OFF YOUR FRIENDS
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    6 Comments
    Is it possible to power low consumption LEDs
    I am not able to understand what u want to ask
    why not rather just buy leds in reel instead solderd onto strip. Also you need protecting resistor
    THESE ARE SMD LEDS WHICH HAVE MORE POWER AND ALSO I HAVE MADE IT FROM WASTE WITH ME THAT WAS THE WASTE BROKEN INTO PIECES LED STRIP YOU MAY DEVELOP THIS PROJECT AND COMMENT HERE HAPPILY ACCPTED ALL SUGGESTIONS AND ADVICES
    It would have been better if you have used (x2) 3v coin cells...
    And Thanks For sharing
    THIS IS RECHARGEABLE SOURCE OF ENERGY AND IN CASE OF ANY MARRIAGE WEDDING RING IT GLOWS FOR MORE THAN 5 HOURS WHICH COULD NOT BE POSSIBLE WITH CELLS
