BMP280+5110 LCD Arduino
1,276
10
Posted
Introduction: BMP280+5110 LCD Arduino
Hello World!
I just had a long weekend and after finishing with my electronics soldering i got an idea. I have a few BMP280 sensors that i ordered by mistake , but i didn't use them for a while. This is a very simple sketch to measure the barometric pressure and temperature data.
Let's start!
Step 1: The Parts You Need!
The parts you need for this project:
1 X Arduino Uno ( Eg: Robotdyn Uno)
1 X Breadboard
1 X Nokia 5110 LCD
1 X BMP280 Sensor
And some jumper wires.
Step 2: The Pinout!
Nokia 5110 LCD:
RST: Digital 12
CE: Digital 11
DC: Digital 10
DIN: Digital 9
CLK: Digital 8
VCC: Arduino 3 Volts
LIGHT: Arduino ground (If you want backlight)
GND: Arduino ground
BMP280:
VIN: Arduino 3 or 5 Volts
GND: Arduino ground
SCL: Arduino Analog 5
SDA: Arduino Analog 4
Or the dedicated SCL SDA pinout on your arduino, if the board has them.
Step 3: The Code!
1. Place it in your Arduino sketces or libraries folder.
2. Download the correct libraries that are included in the sketch.
3. Place them in the libraries forlder.
4. Open the code in the Arduino IDE.
5. Compile it.
6. Upload it to your Arduino!
Step 4: Basic Informations!
To get the correct barometric pressure i modified the BMP280.h file, # float readAltitude(float seaLevelhPa = 1013.25)# to float readAltitude(float seaLevelhPa = 1019.60) # and the (bme.readPressure() / 98.7); in the sketch.
You still can get help from the local waether forcast station barometric data to get accurate results.
This is my case to get the correct pressure data 185 meters above sealevel in Central Europe.
To get yours it will be your job to do it. ( not that hard )
The temperature measuring is not very accurate with this sensor. If you don't want to measure temperature, then uncomment it in the code.
I hope that you will like it and take good use of it!
Pls feel free to use this code or advence it.
Step 5: A Compact Prototype!
If you want a smaller project, you still can use a PCB board with a standalone Atmega328P-Pu chip with some wires and a little time to solder it together.
I am planning to add a " low power" method to save power to run on a battery pack for a fair amount of time :)
I appreciate comments, suggestions or help to improve this project.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Paper Contest 2018
    Paper Contest 2018
  • Sew Warm Contest 2018
2 Comments
That looks good, I'd like to set something like this up in a case outside :)
Good to hear :)
You will probably make a good project :)
