BOINC SETI@HOME for Raspberry Pi
1,107
10
Posted
Introduction: BOINC SETI@HOME for Raspberry Pi
Quick Start Guide to Setting up BOINC & SETI@HOME on Raspberry Pi3
If you have an extra Raspberry Pi 3 laying around, you can put it to use on SETI@HOME.
This guide uses the Raspberry as a Headless Server, i.e. no Display or Keyboard/mouse needed. But you can use these, as desired. The GUI does make it easier to customize preferences if you don't want the Pi3 to run SETI 24/7.
NOTE that only the Pi3 is powerful enough to really run SETI. Others just take too long to calculate enough to make a difference.
Requirements:
  • Your login (email) id and password of your SETI@HOME account
  • A Raspberry Pi3 running Raspbian Jessie (Lite version is fine)
  • WiFi connection
Set up Raspberry Pi3
  1. Install Raspbian on a 8GB or better SD card.
  2. If you use a PC to set up your SD card, see the Appendix (below) for a quick hint on setting up WiFi before booting.
  3. Boot and SSH to your Raspi (or use display/keyboard/mouse)
sudo apt update<br>sudo apt upgrade<br>sudo raspi-config    <br>Update any preferences you like, (Locale, hostname, etc.) but none are required for SETI)<br>sudo reboot
Install BOINC and SETI@HOME
sudo apt get install boinc<br>boinccmd --lookup_account <a href="http://setiathome.berkeley.edu" rel="nofollow"> http://setiathome.berkeley.edu </a><seti_login_id> <seti_password><br>boinccmd --project_attach <a href="http://setiathome.berkeley.edu" rel="nofollow"> http://setiathome.berkeley.edu </a> <account key>
Configure
boinccmd --set_run_mode always <br>boinccmd --set_network_mode always<br>boinccmd --set_gpu_mode always
This sets up Boinc to run SETI all the time. You can still use the Pi for other things, but it will be slower. The GPU doesn't appear to be used by this version of Boinc.
It will now automatically connect to SETI using the credentials you provided, download a work unit and start computing it. Boinc will restart automatically if you reboot the Pi.
Configuration Status
<p><em>boinccmd --get_cc_status</em></p><p><br>CPU status
    not suspended
    current mode: always
    perm mode: always
    perm becomes current in 0 sec
GPU status
    not suspended
    perm mode: always
Network status
    not suspended
    perm mode: always
    perm becomes current in 0 sec</p>
Step 1: SETI STATUS
You can check the status of your Pi in three different ways:
  • Via command line
  • Via GUI
  • Via SETI Website
For command-line, try these:
boinccmd --get_tasks
boinccmd --get_simple_gui_info boinccmd --get_project_status boinccmd --get_cc_status
ps -ef|grep boinc
If you've run SETI@Home on a PC or Mac, then the GUI version for Raspi will look very familiar. And since this guide is for a Headless Pi, I'm not including the GUI part here.
You can also go onto the SETI@Home website, log in to your account and then go the View Your Computers https://setiathome.berkeley.edu/hosts_user.php
Computer ID Name Model Location Avg. credit Total credit BOINC
version CPU GPU Operating System Last contact ID: 8232247 Details | Tasks Cross-project stats: BOINCstats.com Free-DC raspi64g home 0.00 0 7.4.23 ARM
(4 processors) --- Linux 4.4.50-v7+ 24 Mar 2017, 21:01:24 UTC
Step 2: Appendix - Quick Way to Set Up WiFi
Did you know?
If you install Raspbian Jessie on an SD card using a Windows PC, you can create two files on the card to configure WiFi and SSH access before you boot it on a Raspberry.
For this, assume your SD card is currently mounted as K: on your PC:
1) Download and Install the latest Raspbian Jessie image to your SD card. For this project the Jessie Lite should work. https://www.raspberrypi.org/downloads/raspbian/
2) With notepad, create a file called just “ssh” and use Save As “All files” to K:/ssh The file can contain anything. It’s the filename that is important. Must NOT be “ssh.txt”!!!
3) With notepad, create a file called “wpa_supplicant.conf” with following:
ctrl_interface=DIR=/var/run/wpa_supplicant
GROUP=netdev
update_config=1
network={
ssid="mySSID"
psk="mypassword"
key_mgmt=WPA-PSK
Use Save As “All files” to K:/wpa_supplicant.conf
Again, do not let Notepad change it to “wpa_supplicant.conf.txt”!!
When you boot the Raspberry the first time, Jessie will look for these and connect to your Wifi.
You will have to look on your Router for the IP address, though, since its auto assigned.
Then you should be able to use Putty SSH to connect to pi@192.168.X.X
  • Epilog Challenge 9
    Epilog Challenge 9
  • Gluten Free Challenge
