Introduction: BOOKCASE DOOR THAT REPLACES YOUR DOOR.
90 PERCENT OF THESE BOOKS WERE WATER DAMAGED!!!!!!!
I DONT CONDONE DESTROYING BOOKS!!!!!!!!!!
IV WANTED TO BUILD THIS DOOR FOR YEARS BUT DIDNT WANT TO RUIN A BUNCH OF BOOKS. SO I FINALY FOUND SOME WATER DAMAGED BOOKS THAT NO ONE WOULD WANT TO READ. THATS THE HARDEST PART OF THIS PROJECT. I CUT ALL THE BOOKS THEN SUN BATHED THEM FOR A FOR DAYS TO DRY THEM AND TAKE ANY SMELL OUT. YOU COULD JUST GO TO A LIBRARY BOOK SALE AND GET BAGS OF BOOKS FOR ABOUT $2 A BAG, BUT PEOPLE FROWN UPON DESTROING BOOKS SO TRY TO FIND DAMAGED ONES IF YOU CAN.
YOU CAN REUSE YOUR DOOR OR BUILD A NEW ONE LIKE I DID. IF YOU REUSE YOUR DOOR ITS A MATER OF ADDING MORE WOOD AND BOOKS TO IT.
Step 1: Cutting Your Wood.
cut 1 1/2" x 3/4 pieces to make a frame around your door. [make sure you leave enough space on the latch side, that the door will shut and not hit on the jam.] measure the books you get to determin where you put the next piece of wood.
Step 2: Cutting the Books
cutting the books is not fun! but if you have a-
table saw
shopvac
dust mask
you can do this fairly easy. set your fence on the saw to 1 1/4" hook up your shop vac to the saw, put on you dust mask. and start cutting the books with the bind of the book to the fence, you will have to empty the shopvac about 5 times depending on the size of the vac. IF YOU TRY TO CUT THESE IN A CLOSED AREA WITHOUT A SHOPVAC AND MASK YOU WILL NOT BE ABLE TO BREATH!!! I KNOW CAUSE I DID IT.
table saw
shopvac
dust mask
Step 3: Stain Your Wood
stain or paint all your wood pieces and attach them with glue and nails. if your building a new door stain everything. MAKE SURE YOU MATCH THE STAIN OR PAINT OF YOUR DOOR JAM. then clear your wood with a varnish or polyurathane.
Step 4: Glue the Books on the Door.
glue the books on the door making sure to dry fit them first useing pl400 or some other very good glue.
i used a lever handle so i could hollow out the book i wanted to use as the handle. i then drilled the handle and attached with screws. if you dont have a lever handle you could get creative with 2 books or somthing.
Step 5: Hanging the Door
now you can rehang the door but keep in mind your door will be much heavier and you may need to add a heavier duty hinge.
now it should look somthing like mine or better! and the inside of your door will look just like a door.
Step 6: HANDLE IN THE WALL
My bedroom is very small, and after hanging the door i hit my arm on the book handle a few times. so i came up with this idea to make the handle go into the wall, and gain about 3" of walk space.
i just marked the wall were the handle hit the wall, and built a box that fit around the handle. cut out the wall and slid in the box with a little glue on it. then mounted a wall bumper on the wall down low.
this could be added to about any door that you needed more walk space.
THANKS FOR CHECKING OUT MY INSTRUCTABLE!
THANKS: THE GOOSE
Step 7: MORE PHOTOS
more photos.
