Introduction: BTTF Time Clock
Picture of BTTF Time Clock
Back To The Future Time Machine Clock
jiminashland (author)2016-10-16
Nice. Another great project.
To add to the effect, make a slot in the box to reveal the effects from the top of a bubble lamp.
http://www.noveltylights.com/Glitter-christmas-Bub...
Flint glass tubing may be another element in that it is easily bent and cut
https://www.amazon.com/gp/product/B005QDT94Y/ref=o...
Looking forward to more projects. Keep em coming.
My project in progress:
http://wwwphoto.org/2015/02-Feb/20150220-ClockBuil...
Jim (JimInAshland)
Thank you. I love your project.
stringstretcher (author)2016-03-08
This is way cooler than the clocks I have made, but maybe I can add a little different approach. I made a simple silicon mould of a tube and cast it in clear resin, with the diode inside. That gave me the little glass-looking tip on top, which makes it look just like a tube. I also drilled a small hole in some tubes, just large enough for the diode to fit in, and kept all the good stuff in the tube that way. I have to make another one and use some of these ideas. Fine clock!
CrashnDash (author)2015-11-01
I want to make this! I need more information though. I'm not an electronics geek unfortunately and don't know enough to fill in the blanks for myself. I'm betting that if you took the time to draw a schematic and put together a material list and maybe a short kit, you could sell them through some of the BTTF fan sites. This is an excellent looking device you've made.
Nesmaniac (author)2015-10-23
This is Heavy!!!
TheCutlassKid (author)Nesmaniac2015-10-24
Nice. Thank you.
TheCutlassKid (author)2015-10-17
AVI
MissArtieCraftie (author)2015-10-16
looks so cool!
Thank you.
blkadder (author)2015-10-15
Overall, you did a good job explaining how everything went together. Could you tell us where you got the switch with the nuclear symbol on it?
TheCutlassKid (author)blkadder2015-10-16
Thank you!
I got a spst push button switch from Radio Shack (
Model #: 275-1565 | Catalog #: 2751565). I took off the top plastic, it just pulls off, painted it yellow, printed out a nuclear symbol, cut it as close as possible to the symbol, stuck it on top, then clear spayed it to seal an blend the edges of the paper. I then pushed it back onto the switch.
TN_Explorer (author)2015-10-12
Great first instructable! Your "vacuum tubes" are very clever and look cool - I will borrow this idea for some of my projects. I like the way you show where you sourced all your component parts. Thanks!
Thank you.
tomatoskins (author)2015-10-12
This looks great! I love the finished look! I took a look at your PDF, it would be great if you could upload that info into your instructable. I'm a bit confused as to how you made the clock. Could you give some more info on that?
Thank you. This is my first Instructable. I'll try and refine it. And maybe come up with a symatic.
schematic.
About This Instructable
1,946views
59favorites
License:
More by TheCutlassKid:LED "Vacuum" TubesBTTF Time Clock
Add instructable to:
