3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Babe-BQ
Babe-BQ
I was looking at a few a gas bottle stoves which inspired this, basically it’s a log burner with the lid closed, the butterfly valve in the snout is to control the heat, with the lid open it’s a BBQ fuelled by charcoal, it's not quite finished yet but its only a grill and a ash tray required to finish it and also a flue if want to use it as a log burner But thought I'd share it
 click here to see more of my work
Step 1Step 1
Step 1
Empty the gas bottle, cut the handle and bottom off, cut the ring you get from the bottom in half then weld the two halves on for the legs, cut a desired size shape (doesn't have to be a square) out of the front and a section out of the top, I think I cut it about half way round about 30mm from the curves on each end, then add hinges
5 comments
Jan 20, 2012. 6:17 PMforgotengun says:
Great job. I like the piggy! Did you give the other end a tail?
Sep 20, 2011. 7:26 AMsmoligor says:
hm...very nice! good work
Sep 19, 2011. 9:05 PMkill-a-watt says:
love it!
I'd be careful and purge the tank with co2 before cutting into it.
Sep 18, 2011. 3:55 PMrimar2000 says:
Good work!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:abitdifferent(abitdifferent)
I work as a renderer in the day but my brain only starts working at night when I get in the shed
