3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Baby Bear Knife for next to nothing!
How to make a Baby Bear knife for almost nothing! I saw this style blade on the web for over $100. So I decided to see if I could make one in my basement shop. I had all the materials lying around. And my tools were ready to go. So lets go and git- er- done!
Step 1Trace out your pattern onto metal
trace out your pattern onto metal
First, trace out your pattern onto metal of your choice.
62 comments
1-40 of 62next »
Apr 6, 2012. 7:14 AMSquare-Circles says:
I can imagine this as an assassination weapon... Very good work in other words!
Mar 2, 2012. 2:16 PMblack hole says:
Where did you get that bit?
Mar 3, 2012. 5:04 PMjackowens says:
Where can I find brass pins? And do you have to glue it in or something?
Jan 2, 2012. 10:35 AMomalachowski says:
This is very cool, but isn't it a little disingenuous to call this a project 'for next to nothing' and then use 2 grand worth of tools to make it? Is there somewhere I don't know where I can get an angle grinder, belt sander, drill press, band saw, bench grinder and all the rest for next to nothing?
No offense intended, but renting the use of these tools for long enough to make that knife would probably cost at least the $100 you're trying to save.
Unless I can come over and use your stuff, in which case we're cool.
-Olaf
Feb 27, 2012. 1:34 PMDeathcapt says:
A drill and a file is all you 'really' need to accomplish this. Of course, you're going to be doing a LOT of filing
Feb 24, 2012. 11:07 AMBasement_Craftsman says:
It seems to me like u would be paying a lot for your tools. I have an angle grinder that was 20 bucks. A drill press at my local harbor freight tools is 70 bucks a and the bench grinder i have was just over 50. Belt sander 50 and band saw is 130. I don't mean to sound offensive i just want to help u out. So if you happen to be starting from scratch with no tools u can have all the power tools for the knife making process for less than 350 dollars. So harbor freight tools is what i would recommend for you. Most of those tools you listed aren't even truly needed.
Jan 3, 2012. 9:48 AMtensegrity says:
It isn't much different than not mentioning the cost of a sewing machine in sewing projects.
Jan 3, 2012. 10:26 AMomalachowski says:
You are all right. I suppose the cost of tools shouldn't be a factor. I had a craw up my butt, apparently. I will try not to post when in a snarky mood.
I would like to see the hand-tool version of this instructable, Madrigorne. Please post that if you do it.
Jan 3, 2012. 9:50 AMtensegrity says:
My inner grammar fascist compels me to change that to "different from."
Jan 3, 2012. 8:54 AMbruce.desertrat says:
The key is to build up that toolkit over time.
Cheap chinese angle grinders can be had for $10, better made ones for not a lot more. I had a $9.99 ace hardware special for several years, then saw a much nicer model on the closeout table for $19 at Lowes, because it was missing the flat nut that holds on the wheel...which the one from my cheap chinese one fit.
My drill press is a $49 on sale benchtop model from Harbor Freight, with 20% off coupon bringing it down to $40.
Bench grinder is a monster old 8" thing I got for $25 with some haggling at the swap meet over 15 years ago. Needed new wheels and some grease on the axles. Had to come up with a rest for it, which I made from some scrap angle iron and some pipe.
I don't have the band sander, but again, a trip to Harbor Freight or a used tool store, or some time scrounging yard sales will get you one cheap.
Also, you can build this thing with nothing more than hand tools, it just takes time and elbow grease. A coping saw with some metal cutting blades, a hand drill and some files of various shapes and sizes are all you need.
Jan 3, 2012. 3:46 AMMadrigorne says:
I am going to make this but instead of the power tools I will be using my hacksaw, my drill, and my dremel.
Jan 2, 2012. 6:14 PMcharlesian2000 says:
The same job "could" be done with cheaper tools, it would just take a bit longer.
Cutting out the profile could be done with a hacksaw, the finger hole, could be made with a series of drilled holes, then cut out with a sharp needle file.
The knife bevel could be done with a hand file, the grip material can also be shaped with a file.
Then it's a matter of heat treating the blade. If it's a high carbon steel, standard hardening and tempering with oil. If it's stainless then you have to do a sub-zero quench, or send it to a professional to harden the stainless blade for you.
Expensive tools aren't necessary to make a good knife, expensive tools just make it faster and easier to do.
Jan 6, 2012. 2:45 PMaristide202 says:
that's right , i absolutely agree. Anyway there are different grades in hand tools too. Prefer the best hand tools you can afford .Tungsten or manganese hacksaw blades cut faster than regular carbon steel blades. A diamond titanium coated file may give easier satisfactions in hand working and so on and not always the problem is related to price.
Feb 18, 2012. 11:27 PMcurious youth says:
LOVE IT ! have i commented yet ? i dont know ? lol but your third is my favorite. even though it isnt finished. i think it looks great already.
Jan 18, 2012. 4:00 AMowlart101 says:
I really like the wood(?) that you are using. What kind is it? I am also a knifemaker and am in the process of making a bowie.
Feb 9, 2012. 9:21 PMblack hole says:
Could be micarta.
Feb 10, 2012. 3:57 AMowlart101 says:
Cant you get micarta in brown and grey-ish? Then stain it? I have never worked with it. But I heard that you can polish it and it will look very much like ivory.
Feb 10, 2012. 6:47 AMblack hole says:
Don't know about staining it, but yes, you can get it in many colors.
Here's an 'ible on making it.
At KnifeKits.com
Feb 10, 2012. 3:59 AMowlart101 says:
Did you use scales?
Jan 28, 2012. 3:47 PMRteen says:
How sharp do you think this is?
Jan 6, 2012. 7:49 PMmjursic says:
My own attempt. What took the longest was getting the scabs just right. Used the middle of an old 12" circular saw blade. Thanks, triumphman. Great idea.
Jan 16, 2012. 7:40 PMCokehubby says:
I'm getting ready to make this one out of a lawn mower blade. Looks like a very use full little knife. Thanks for the great instructions.
Jan 2, 2012. 8:44 AM13thvulture says:
its a neat looking knife, but what sort of things is it used for?
Jan 6, 2012. 4:47 PMmjursic says:
Mine is almost done. It is a compact knife that can be used for anything. It just looks cool. Also, you can't really see it, but when you hold it, it fits into the hand really well.
Jan 2, 2012. 12:17 PMcriggie says:
I agree - why this shape?
It's not really a skinning knife, and push knives are classed as weapons in many locations.
Feb 11, 2012. 8:18 PMblack hole says:
It's like a natural claw when in this shape, an extension of the body
Jan 6, 2012. 2:51 PMaristide202 says:
It reminds me some sort of a push dagger
Jan 3, 2012. 1:27 PMMexicanPorkSword says:
Wow, you really made a great instructable here! May i recommend that you harden your steel for future projects by heating the steel to a red hot temperature, until it loses it's magnetism, and then dipping it in oil repeatedly. This infuses the steel with carbon, making it much harder and sharper. You would then proceed to putting it in the oven at 400 degrees fahrenheit for one hour to relieve stress on the blade, making it much less brittle. You really have it going and I truly enjoyed your guide. Also, you mentioned you had seen this kind of blade online? Would you mind telling me where I could find it or what it is called? -Thank you,
Mexican
Jan 4, 2012. 5:34 PMmjursic says:
Hey Mexican, it's called the Baby bear knife. Here's an example of where you can find it.
http://www.gpknives.com/alanfoltscustombabybearorangeg10.html
Have fun, I'm just going out to my garage right now to start one out of an old circular saw blade.
1-40 of 62next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
65
Author:triumphman(Triumphman)
Running the ranch, taxi, auto tune ups & maintenance, computer & printer fixing, chuck wagon (grilling & cooking good food), security, body-guard, you know, I do it all!
