If you've got concerns about consuming or cooking with booze, you can omit the whiskey, but really, why would you want to?
Step 1: Making Crust. . .
To make your own, you'll need. . .
Hardware:
- - one large bowl
- - muffin tins (I use one 3 cup by 4 cup, and two smaller 3 cup by 2 cup - because that's what I have)
- - measuring cups and spoons
- - a round cutter (I use one that's intended for biscuits - it's about a 3" diameter and has a scalloped edge which makes the tops of the crusts look rather nice)
Software:
- - 3 cups flour (all purpose) - additional will be needed when rolling out for dusting board and rolling pin
- - 1.5 teaspoons salt
- - 2 tablespoons sugar
- - 1 cup and 2 tablespoons butter (cut in cubes and kept nice and cold)
- - .5 cup cold water
- - 2 tablespoons apple cider vinegar (no, seriously)
And also:
- - parchment paper
- - plastic wrap
- - a rolling pin (I prefer a French rolling pin (i.e., one with tapered ends)
- - your hands (for mixing)
Step 2: This Could Get Messy. . .
- Cut your butter into cubes and put it on parchment and back in the fridge to keep it cool
- Add the flour, sugar, and salt to the bowl and mix it around a bit with your fingertips
- Form a little well in the center as shown
- Add the water (cold) and vinegar to the well
- Plop in the butter cubes
- Push up your sleeves and begin mixing with your hands. Try to mix in the liquid, but also break up the butter and get it combined with the flour
- Once it's pretty evenly mixed, turn out onto a piece of parchment and mix a bit more, but only until it's all come together
- Wrap tightly in plastic wrap and place in the fridge for at least an hour
Step 3: Making the Crusts. . .
- Divide your dough into four portions and work with one at a time, keeping the others wrapped to prevent them from drying out
- Sprinkle flour onto a sheet of parchment and dust rolling pin as well
- Place dough in the center of your work surface and roll from the center out to form a sheet about an eight of an inch thick (or up to a quarter, but thinner is better)
- Cut out rounds using the cutter and place each into the cup of a muffin tin, squishing them down into the edges gently
- Ball up the scraps of the dough after cutting as many as possible and repeat
- Repeat with remaining 3 sections of dough
- After cutting out all the dough, place the muffin tins in the fridge to keep the cool while you make the filling
Step 4: Making the Filling
Hardware:
- - a large bowl
- - a spoon or wire whisk
Software:
- - 1.5 cups chopped pecans or pecan pieces
- - .75 cups dark corn syrup
- - .75 cups dark brown sugar (firmly packed)
- - 1.5 tablespoons butter (melted)
- - 2 large eggs
- - 1 tablespoon pure vanilla extract
- - 1 tablespoon cinnamon
- - 1 teaspoon each fresh grated ginger and nutmeg
- - about a half a shot of good whiskey (can be omitted, but why would you want to?)
Step 5: Making the Filling (Part 2)
- Preheat oven to 350 degrees
- Melt the butter and add the brown sugar
- Mix well
- Add corn syrup and the eggs one at a time, mixing well after each addition
- Stir in the cinnamon, ginger, nutmeg, vanilla, and whiskey
- Gently mix in the pecans
Step 6: Bake, Cool, and Eat
- Spoon filling mixture into the chilled crusts
- Bake for 30 minutes, or until the tops of the crusts are golden brown and the pecan mixture has started to set up
- Allow to cool slightly and remove from the muffin tins. If the filling has oozed up a little, run a small knife around the edges of the cups and they should pop right out
- Enjoy!
Visit Our Store »
Go Pro Today »
http://www.instructables.com/id/SNWTGOEFSFOIO0U/
