Introduction: Baby Saver or Prank in a Day
One day I was thinking about the stories I’ve heard about babies and small children dying from being left alone in a hot car and how easy it would be to help prevent this from happening. I wanted to make something that anyone could make from household materials with minimal effort and no soldering.
This entire project costs less than $10 and can even be free if you already have a greeting card with audio.
All you need is an audio greeting card (with or without recording option), string, tape, and a small piece of paper.
As a college student, I don't have access to a car at the moment, so I decided to test the project on my door and possibly scare my roommate a bit in the process.
Disclaimer: This project makes no guarantees about successfully reminding parents about children left in their car. The device gives an audio reminder which may be ignored or the device may not have been set-up to begin with. This device is only meant to be an additional reminder.
Step 1: Record a Message
Follow the instructions on the card to record your message. Leave a note in you own voice or make a special comment.
My recording welcomed people to my room, asked why they were doing, and eventually asked them to leave.
Step 2: Open the Card
Just peel the card open. There may be a little plastic tab to rip off.
Observe how the card works by opening and closing the card a few times. Opening the card allows the contacts on the pcb board to touch and sets the card off. We'll simulate this with a piece of paper between the contacts that is pulled away so the contacts can touch in the next step.
Step 3: Attach
Cut a piece of string long enough to reach from the moving platform (in this case the door) to the stationary platform (in this case the wall).
Tape or glue a small piece of paper to the end of the string. This will serve to separate the contacts on the card. It is convenient to cut a triangular piece of paper (I just ripped off the corner of the envelope the card came in) as you can slide the piece of paper underneath the tape sticking the string to the door when you're not using the device (as shown in the picture).
Tape the other end of the string to the moving platform.
Tape or otherwise attach the rest of the card to the moving platform.
Place the piece of paper between the contacts to set up the device. You'll need to reset the device by doing this every time you want the device to go off.
If you want to leave the device long periods of time then remove the string from the moving platform and leave the paper between the contacts, so that you don't drain the battery.
ShopBot Challenge
ShopBot Challenge
