3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Baby Tron Costume
Step 7Powering the costume
I purchased two lithium polymer batteries to power the costume.  When I placed the order, I wasn't sure how quickly it would drain the battery and I wanted to have a spare battery.  One of the batteries is a 2000 MaH and the other is a 1100 MaH.  I decided to use the 1100 MaH battery.  After several tests, I found that it lasted in excess of 2 hours (intermittent, but frequent use).
Just like the El-Wire and the inverters, you'll need to solder a JST connector onto it.  Its quite simple to do, and you should be a pro by now.
The other side to the equation is that you need to be able to charge the battery.  I decided to use the li-poly charger from Sparkfun, but not mount it in the device.  Since this was a one time use costume, I didn't plan on recharging it frequently.  If you already have a way to charge li-poly batteries, you don't need to purchase the one from the materials page.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:smounic
