iImage Information
Never bend over again to shovel snow! Add a second handle from any broken tool with a D-handle (or even a cheapy shovel cut off), two pieces of plywood and a few nuts and bolts. It works even better than those expensive curved handle shovels you see in the store.
Step 1A little prep
iImage Information
Cut two pieces of scrap ply approx 9x16", cut a handle down to about 20" long, buy six bolts, washers and nuts the appropriate length for the thickness of the second handle and two pieces of ply, typically 3 inches.
You can read much more about the design, it's advantages, and view extensive footage under pretty severe snow conditions at
theshovelmaster.com
I see some pencil marks on the plywood, which seem to suggest that the author has that in mind.
The real advantage of this rig is the load it takes off your lower back from being able to use two hands at waist level, and even a large shovelfull of slushy snow was manageable - the end of the driveway where the city plow plowed us in.
Free tip: use some car wax on the shovel blade to keep it slippery and light.
Happi Trails!
