Back-of-the-Envelope Note-Pad
751
4
Posted in CraftBooks-and-journals
Introduction: Back-of-the-Envelope Note-Pad
About: Math lover. Engineering communicator. Mad-lib enthusiast. Total nerd. I work at TELUS Spark as a champion of engineering communications. I love to fill my brain with stuff, especially math problems. When I'...
Oh, the pain of not having an envelope to scribble on the back off when the need strikes. Fear no more! Here's a note-pad that's always available when you need to do a back-of-the-envelope calculation. It's also a great and handy way to re-use envelopes before sending them to the recycler.
Trash to Treasure
This is an entry in the
Trash to Treasure
Step 1: Gather Supplies
You'll need:
  • About 15 envelopes of the same size (This is a good amount for making one note-pad. Make sure when you're opening envelopes to use scissors to cut the short end - this makes them lie flatter when stacked, and keeps them the same size).
  • Binder clips
  • A couple pieces of scrap paper
  • A whisk
  • Heavy blocks (like textbooks) or a book-press
  • Paintbrush
  • Padding compound (see below for ingredients to make your own)
DIY Padding Compound:
  • 1/2 tablespoon unflavoured gelatin
  • 3 tablespoons boiling water
  • 1 tablespoon white vinegar
  • 1 teaspoon glycerin
My acknowledgments to Andrea Arch , from whom I got the recipe and instructions for making a note-pad.
Step 2: Clip It Up
Make a stack of about 15 envelopes. Any more envelopes and it gets a bit bulky on one end as the envelopes fan out a bit.
Make sure the backs of the envelopes are all facing up (this is the blanker side that you' want to write on). Keep the openings facing the same direction as well (remember, you'll probably want to use scissors to open the envelopes on one of the short ends, not the long end where the envelope flap is). The openings will be the bottom of the note-pad. If you put padding compound on the open ends, you run the risk of catching some air inside and causing bubbling.
Put a piece of scrap paper on the top and bottom of the stack, wrapping it around the edges is fine. You'll be removing the paper at the end. Put binder clips near the top to hold the stack together (this is the short-edge where the envelopes are still closed). Leave the edge that you'll be putting the padding compound on un-clipped.
Step 3: Padding Compound
Pour 1/4 ounce (1/2 tablespoon) of gelatin into 3 tablespoons of boiling water. Use a whisk to stir mixture until it has dissolved and no grains of gelatin are visible.
Add 1 tablespoon white vinegar and 1 teaspoon glycerin. Whisk for 1 minute until well mixed.
Pour mixture into a mason jar and allow to cool to room temperature before use. The mixture will be a jelly-like consistency when ready to use.
If mixture becomes too stiff to work with, throw it in the microwave for 5 second bursts until it goes back to a spreadable consistency.
(Slightly modified from Andrea Arch's instructions)
Step 4: Pad!
Place the pad between two heavy blocks or a press, leaving the edge to bind just exposed. Paint the padding compound generously onto the edge. Use extra binder clips to hold the envelopes together, if necessary. Be careful not to let the clips touch the padding compound. Let the padding compound dry and apply another coat. Repeat until the padding compound seems to cover the edge (about half a millimeter thick).
Step 5: Presto!
There you have it! Now you'll always have a handy pad for back-of-the-envelope calculations!
    • Trash to Treasure
      Trash to Treasure
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    This is an entertaining project lol i always find myself using the back of the envelopes anyways so why not make one of these. Good job :)
