Step 3Preparing acrylic
**WARNING**
DO NOT Use the pouring method as this has been found to result is Crazing (Cracking) of the Acrylic due to the Toluene.For best results use the spray method in thin layers. I suggest you to run some tests on spare acrylic before you do your final screen.
The silicone rubber layer helps coupling between the Rosco projection screen and the acrylic. It allows the user to have brighter blob for less pressure onto the screen. Without it users should have to press really hard to get decent blob.
You can watch a video that illustrate the differences at:
'''''Dowload my explicative PDF for rubber'''''
![Enable mouse and keyboard functionality on an iPod Touch or an iPhone! [Linux]](http://img.instructables.com/files/deriv/F09/VY6U/G9GQGXFB/F09VY6UG9GQGXFB.SQUARE.jpg)
I am making a multi touch table that also has to function as a desk and think that with the size that i am planning of making it in (aprox. 140cm * 80cm), acrylic will either sag and bend or just break.
