This instructable is what i came up with based on ideas I found elsewhere and here:
Backpack-panniers-that-are-still-backpacks
Parts :
- Backpack
- Over Door Hanger
- Bungee Chord (approx 18" or 45cm)
Tools :
- Dremel Tool or Saw
Discalimer :
I am not responsible for any injury or loss incurred during the making or use of this Instructable.
Make and use at your own risk!
Step 1: Cut Over Door Hanger
+ Leave at least two hooks at either side of section to be cut
(Having more than two hooks might be useful as backup but if your bicycle rack is not perfectly straight then the bag might have a tendency to rock slightly.)
+ Using Dremel tool or saw cut the over door hanger to the width of backpack
(Make sure to follow safety procedures while using cutting tool)
+ Clean rough edges of cut by sanding or otherwise
Step 2: Shorten Straps
+ Ensure that the extended straps are folded or tied so that they do not get entangled with the spokes of bicycle wheel
Step 3: Pass Straps over front of Backpack
+ Pass the cut hanger section underneath backpack straps
Step 4: Hook Bungee Cord
+ Pass bungee chords around backpack straps
+ Hook bungee chord on to other side of hanger section
Step 5: Place on Rack
+ Loop bungee chord around bottom of bicycle rack
And you are done!
Visit Our Store »
Go Pro Today »
It's very simple and elegant.
Usually, pannier bags have stiff backs to prevent them from twisting at the bottom and hitting the wheel (since it is fixed from the top).
Maybe in this case a frame or some kind of insert(wood sheet) in the back of the backpack?..
I admit the backpack will sometimes hit the wheel if I hit a pothole or go down a curb but otherwise it was ok. Usually, backpacks have some padding in back, which helps the bag hold its shape to some extent.
Funnily enough, I did try hanging grocery bags once, but only for a couple hundred meters, I doubt they would have survived longer because they kept hitting the wheel, as you pointed out.
A skirt guard may be a solution...
