Backsplash From Reclaimed Pallets
16,715
465
58
Published
Introduction: Backsplash From Reclaimed Pallets
Hey Thanks for stopping by. Check out the video for a more in depth take
For this instructable im gong to make a backsplash from old pallets.
The key reason is to hide the unsightly washer hose and electric cords.
The back splash is made to be removable so I can easily get behind for service.
To find out how I made this check out the next step.
Check out my Social site
Instagram www.instagram.com/diycreators2015/
Facebook www.facebook.com/diycreators
Youtube: www.youtube.com/c/DIYCreators
Step 1: Picking Out the Pallets
You can pretty much find pallets anywhere there is a business.
For this project I use various size of pallets, mainly three different side.
Since I planed the pallets in my thickness plane I separated the pallets by size.
You can totally use a hand sander for this process. Its just time consuming.
If your not sure what a thickness planer do. The thickness planer remove a layer from one side of your lumber.
Step 2: Ripping the Pallets to Strips
Since there is not straight side on the pallets. I passed the wood through the table saw to create a straight side .
Now that I have at least one straight side I can began to rip the strips.
I set the table saw fence 1.5 inches from the blade and began the ripping process. I did this till all was ripped to size.
Step 3: Final Cut
I cut off a small piece of wood from the end to make sure the end was straight.
I put stop block on the miter saw, so every cut will identical at 9 inches.
I gave an additional sanding on the ends to remote the wood blow outs.
Step 4: Cutting the Back Support
Since my backslash is removable. I used 1/2 inch plywood.
If you wanted to install this permanently 1/4 ply will be fine.
In my case I added an additional piece to onside to push the backsupport off the wall to clear the washer hoes.
Step 5: Attaching the Pallets to the Back Support
To keep this sweet an simple I used hot glue to attach the pallets. Of course you can use any method of attaching you feel is necessary.
I wanted a stack stone look, I have three different size as a starting point.
First is 9 inch, second 6 is inch, third is inch. Then repeat the same method every third row.
When I got to the end, I mitered the corner to give a clean wrapped look.
Step 6: Adding the Finish
I gave a quick sand to remove the sharp corners.
I use danish oil for the backsplash. Just follow the instrucation on the container. I applied with a rag.
Danish oil - http://amzn.to/1r2rypG
Danish oil unlike stain sits in the wood. I only applied one coat but apply as many as you like to darken.
Step 7: Installing
As stated before before this backsplash is removable. So I make a simple wood bracket for one side to lock the back splash in place.
On the other side I used the french cleat method to attach. This part was added at a later date.
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Stick It! Contest
      Stick It! Contest
    58 Comments
    Great idea. I plan to use this in my kitchen redo I am starting this next week.
    Very beautiful. The next time I will learn from you and write a post on how to decorate kitchen or bathroom with less time and money, using self-adhesive wall tile or smart tiles produced by aladdingpromo.com
    That looks fantastic. I love building stuff from pallets. There is some nice oak to be found in pallets. The stained nail holes often add some nice character to the projects. Right now I am working a rolling (onion, potato) oak counter with an oak end grain finish that is about 16x16x36 inches. It tucks away in the corner but can be moved anywhere in the kitchen where my wife needs that little bit of counter space.
    Thanks for the lovely video.
    I think your work is the some of the best in this community.
    You cannot/shoudn't usw a hand sander for this process. Pallet wood is treated with chemicals you don't want in your home/kitchen. Use an electric planer to atrip the wood to its untreated natural layer and you can be confident about the safety of living with it in your kitchen. It is probably about 3 mm of removal, a ridiculous amount to sand down. It is easier and cheaper to buy a used electric planar from craigslist/ebay.
    Yup I'm hot for this idea too! Going to start with the backsplash in our kitchen. This is so nice and unique I don't think it's going to look "dated" as fast as the tile backsplash look that is "in" right now.
    Also I've been wanting to replace some vinyl siding on the front of our house with stacked stone but have not because of cost. But you sir, have saved that day! I'll have to stain and waterproof them, but I'm going to get a planer and do the front of our house! And my son thinks this might be the start of a new business idea too! THANK YOU!!
    Thank you and that sounds awesome good luck.
    Excellent project, excellent presentation! Kudos!!
    This is brilliant! Your video is very well presented too :-)
    I have a load of old pallets which I collect mainly to use as firewood, but it seems a shame. Definitely going to have to borrow your idea, maybe in my bathroom which is due for re-decorating!
    Awesome.. very nice video. Thnx !
    Looked good, but why not fix the same kind of cleat at the other end? Just come back to the next stud & set it up. That way both ends will be secure.
    I went with a french cleat on there other end. It more secure and you have to pull out further to remove.
    Oh, this would look so good in my kitchen! Both as a back splash and a counter top! Though I'm sure that would take a bit more work and effort :). I just purchased my home a few years ago and am remodeling as I can. OMG! Built in 1970, yellow was popular at the time, and my counter top is dog barf yellow. So is most of the bathroom. YIKES!!! :-( You have given me some ideas, and I have plenty of pallets. WOOHOO! Thank you diycreators!
